Old 6th July 2011, 19:23   #91
AWD
Thanked: 369 Times
Re: Mahindra Thar MDI - Driven!
Any update on A.C. fitment on Mdi, on both 4x2 & 4x4?
Considering one has to carry out a jugaad job on Crde, can a somewhat similar job be done on this one?
AWD is offline
Old 18th July 2011, 17:08   #92
dhanushs's Avatar
Thanked: 11,492 Times
As per my friend in ITL motors, there is no update for AC in Thar Di. Though many owners have done it from outside.
Also, numerous 4x2 owners have been reporting one common and irritating problem: The openable windshield of the Thar Di leaks during rains.
Yesterday, I could spend some time with the CRDe and take to some places it deserved to go. Overall I feel the refinement of the machine is leagues ahead of the Di version. The engine and drive-train is very good. Rattles are very much less, when compared to the Di.
If only Mahindra had improved the plastic, interior quality. As in a brand new Thar:
  • The front passenger door cannot be opened from the outside.
  • The door lock on the inside passenger door is broken.
  • It takes ages to open the rear door from the inside.
  • All the AC vents were absolutely pathetic and were rotating around freely.
  • I wish there were no control for the AC, as the ones there are just
Other than this, IMO the Thar is a quite capable vehicle.
The update regarding 4x4 Di is that they have started the delivery and its said to be an absolute workhorse. Rugged.
dhanushs is offline
Old 18th July 2011, 18:24   #93
Rajith's Avatar
Thanked: 756 Times
AC fittment for Thar DI 2wd/4wd is an easy task, can be done out side very neatly.I have done the same task for 4wd Bolero DI at coimbatore with all original M&M OEM spares.
Rajith is offline
Old 18th July 2011, 20:25   #94
SPIKE ARRESTOR's Avatar
Thanked: 1,545 Times
Rajith, do share about your AC fitment if possible with pics. How much did it cost you (total)?
Spike
SPIKE ARRESTOR is offline
Old 18th July 2011, 21:07   #95
DirtyDan's Avatar
Thanked: 1,666 Times
Spike, is there any interest at all at M&M in lockers or limited slip diffs for either Thar?
DirtyDan is offline
Old 19th July 2011, 00:08   #96
AWD
Thanked: 369 Times
Could you get info. from any of the Di(4x2 & 4x4) owners about A.C. performance & functioning?
Should be but guys from MM posted here that A.C. in DI is not possible, so the concern!
AWD is offline
Old 19th July 2011, 08:44   #97
Rajith's Avatar
Thanked: 756 Times
Boss the concern is due to the presence of pumkin of the front differential exactly below the AC compressor for the DI engine.(Check 2wd Bolero DI SLX or SLE).One has to fabricate a adjustable clamb on top of the FIP, ie near the filter , Battery side fitted to timing case.All works fine.i have clocked 65000kms on this as of now.
Rajith is offline
Old 19th July 2011, 08:50   #98
Rajith's Avatar
Thanked: 756 Times
Spike
Spike it costed me @ 60000/- with Santen compressor and M&M blower.
.it was freezingly chilling.Unfortunately i dont have the engine bay pics.I sold the same and taken Major 4wd in 2010 for better offroading.
I can suggest South India Motors at coimbatore for the same.He has did a fantastic job.
Rajith is offline
Old 19th July 2011, 09:22   #99
Rajith's Avatar
Thanked: 756 Times
some more action pictures of Bolero DI converted to SLX spec in action at MGE 2008 Coorg.
Rajith is offline
Old 19th July 2011, 11:33   #100
AWD
Thanked: 369 Times
Boss the concern is due to the presence of pumkin of the front differential exactly below the AC compressor for the DI engine.(Check 2wd Bolero DI SLX or SLE).One has to fabricate a adjustable clamb on top of the FIP, ie near the filter , Battery side fitted to timing case.All works fine.i have clocked 65000kms on this as of now.it costed me @ 60000/- with Santen compressor and M&M blower.
Is it completely same in Di? 60K for A.C is little too much!
Great to see you vehicle doing offroading. Did you get it converted to 4x4?
Edit: So, XLS came 4x4 from Company. Great.
AWD is offline
Old 19th July 2011, 11:41   #101
Rajith's Avatar
Thanked: 756 Times
Its 4wd by birth.Not converted.
Rajith is offline
Old 19th July 2011, 19:04   #102
e4gleeyez's Avatar
Thanked: 24 Times
I am newbie to Jeeps and wanted to start of somewhere but am running short of cash and wanted to know if we can convert THAR DI to a 4*4 at a later stage?
If Yes what will be the approx cost and will there be a challenge in terms of reliability.
e4gleeyez is offline
Old 19th July 2011, 20:32   #103
dhanushs's Avatar
Originally Posted by e4gleeyez View Post
..wanted to know if we can convert THAR DI to a 4*4 at a later stage?
The Thar Di is also available in its 4x4 avtar, and now deliveries too have started. There is just a 50,000 price difference between the 4x2 and 4x4.
IMO, buy a Thar 4x4 instead of converting the 4x2 later on.
http://www.team-bhp.com/forum/4x4-ve...ml#post2223519
dhanushs is offline   (1) Thanks
Old 20th July 2011, 15:07   #104
e4gleeyez's Avatar
Thanked: 24 Times
Great news I hope Mahindra is using IFS in DI 4*4
Any update on the drive and handling of DI 4*4? Is it the same as CRDE 4*4
Old 20th July 2011, 16:11   #105
Shubhendra's Avatar
Thanked: 2,352 Times
Hi e4gleeyez,
Mahindra DI 4x4 does not come in IFS. it is using leaf springs with rigid axle.
Shubhendra Singh
Shubhendra is offline   (1) Thanks
