The Bolero player in my Skoda Superb is starting to feel dated, especially the interface and touch response. Therefore, I started looking for alternatives. Special thanks to Team-Bhpians
maddyguage and
Gannu_1 for their valuable inputs, I zeroed in on the RCD 330 Plus, inspite of a few compromises.
I started looking out for RCD 330 Plus (Noname version) with green backlight on Aliexpress. Sadly, there are very few sellers dealing with green backlight versions. Upon having a conversion with the seller, I came to know that the player is a standard VW version with the red LED's changed to green. The carplay version was available as well, with upgraded RAM. However, the button bug and soldering of upgraded RAM put me off. The newer version with out of the box carplay functionality wasn't available then. Therefore placed an order for the noname version with green backlight on Aliexpress. It costed
$169 with free shipping(wasn't charged any customs duty). The package was shipped on 16/01/2017 and delivered to my place on 03/02/2017 by Gati. The packing was superb. Aux cable, antenna adaptor and a camera adaptor were included as well.
The Superb, when launched in 2009 came with the RCD 510, surrounded by a trim panel.
Source: Google
Later, the audio system was changed to bolero with piano black finish.
Source: Google
My Superb came with the bolero player, so placed an order for the trim with the authorised dealer, who was kind enough to hand it over to me directly.
Part number: 3T08580691QB
Price: Rs 2619/-
Firstly, remove with the the black fascia with a trim removal tool. This exposes the four Torx T20 screws. Unscrew the Torx screws and the system slides out easily.
I was expecting a Bosch unit, but it turned out to be a Delphi unit.
Unplug the quadlock connector and radio connector from the existing system, connect the same to RCD 330 plus. Slide the system in and tighten the Torx screws. Install the trim in place.
The park assist looks much better after the upgrade.
Few key points
1)The maxi dot display no longer displays audio info from the player. So you no longer see the audio menu on the display. It is not a compromise for me as I don't use the audio menu on the maxi dot display at all.
2) Climatronic info isn't displayed when you alter fan or temperature settings.
3) Only minor issue is the player's green backlight doesn't exactly match with the interior's green backlighting. It does look odd, but I am ok with it.
4) The steering controls work perfectly.
Surprisingly the phone button works and the caller ID is displayed on the maxi dot display. I wasn't expecting it to work as the bluetooth 9W7 kit is already in place.
The system does turn off when the key is removed.
5) Pressing the voice command button on the steering wheel activates SIRI when the phone is connected via bluetooth.
On a concluding note, I am in love with the system. It is a refreshing change from the Bolero system's overdose of green. The interface feels a whole lot modern, slick and the touch response is great. The bluetooth functionality is improved, with the addition of favourite contacts on the screen. A highly recommended upgrade for Skoda Superb/Laura/Yeti/Rapid.
Mod note: Thanks for sharing, moving out from Assembly Line section.
hey i am in the same boat! and contemplating. What about sound quality? do you see a degrade/Improvement? also about Bluetooth, did you check if the roof mounted mic serves better than the one on the RCD330g plus? also during the boot, do you get Welcome to Volkswagen pic?
Originally Posted by newtonMeter
(Post 4154454)
hey i am in the same boat! and contemplating. What about sound quality? do you see a degrade/Improvement? also about Bluetooth, did you check if the roof mounted mic serves better than the one on the RCD330g plus? also during the boot, do you get Welcome to Volkswagen pic? |
Hi newtonmeter
Sorry for the late reply. The sound quality feels marginally better. No problem with the mic on the RCD 330 plus, my voice is clearly heard. Yes i get the VW logo on startup. But i have come across units with Skoda logo on startup lately.
Originally Posted by csr9
(Post 4170202)
Hi newtonmeter
Sorry for the late reply. The sound quality feels marginally better. No problem with the mic on the RCD 330 plus, my voice is clearly heard. Yes i get the VW logo on startup. But i have come across units with Skoda logo on startup lately. |
any leads to aquire these units with Skoda logo??
(Post 4170492)
any leads to aquire these units with Skoda logo?? |
Please have a look at this listing. Looks like the green backlight is an exact match. Please verify at your end. Do make sure you get the noname version
LINK.
Here is the carplay version
LINK.
(Post 4146119)
The Superb, when launched in 2009 came with the RCD 510, surrounded by a trim panel. Attachment 1608501
Source: Google
Later, the audio system was changed to bolero with piano black finish. Attachment 1608502
Source: Google
My Superb came with the bolero player, so placed an order for the trim with the authorised dealer, who was kind enough to hand it over to me directly. Attachment 1608503 Part number: 3T08580691QB Price: Rs 2619/-
Hi, just had a doubt regarding fitting the RCD330 and 340. Didn't your Superb had a wooden panel? Is there any way to retain that and retrofit the HU? It currently has a Swing system.
I am planning to upgrade it on my Laura Elegance, which has a faux-wood panel, similar to the Superb and a black or silver insert might look out of place.
Also attaching a picture for your reference. Any leads would be very helpful.
Thanks in advance.
Originally Posted by Akshitsi
(Post 4442432)
Hi, just had a doubt regarding fitting the RCD330 and 340. Didn't your Superb had a wooden HU? It currently has a Swing system.....
Also attaching a picture for your reference. Any leads would be very helpful. Attachment 1789037
The Superb has the HU with integrated piano black facia. Hence, I had to get the trim to install the RCD330. Finding a faux wood trim to support RCD330 would be difficult. The silver trim
Link is easily available.
