Originally Posted by Akshay1234 Since my car had an amplifier connected over optical fibre I had to buy a converter for that. |
Interesting. Can you post a link to the converter you bought? Is it analog-to-optical or USB-to-optical?
Originally Posted by Akshay1234 I've noticed when I use apple music which is loaded on the HU, the sound quality is much better than BT streaming. |
By BT streaming - you mean streaming from your phone to this tablet?
I'm not a fan on Bluetooth streaming. There's a noticeable loss in sound quality, and I guess more so on the older (yet recent) versions of bluetooth.
Originally Posted by Akshay1234 Also the home screen seems to be custom, along with the BT streaming app and a few others. |
The program that runs the Android "home screen" is called the "launcher". (Basically what shows up when you hit the 'Home' button).
You can install multiple launchers and even switch between them easily (there's apps for switching between launchers too!).
Armed with that information, you might find it easier to locate one that suits you better:
Google: Android launcher for car use Quote:
Originally Posted by Akshay1234 1) For any app loaded on the HU, I have to provide it a hotspot to work from my phone. Now for that it seems to work only through wifi, which is another cumbersome process. Any way to get the HU to take the hotspot off my iphone via bluetooth? |
What you're looking for is "Tethering over Bluetooth". I think it was added around iOS 4 -- but not sure if it still exists. Check your iPhone settings.
If it does - then just pair your android HU to your phone and see if it accepts it as a source of internet (would depend on the BT version of the tablet and what features it supports).
Speeds will be lower this way, but probably still manageable.
Better yet -- why don't you just get one of those portable Jio hotspots and leave it in the car?
Originally Posted by Akshay1234 Its only the built in BT streaming apps which work. / how do I get a better BT streaming app |
I don't follow... What are thse "built in BT streaming apps"?
Originally Posted by Akshay1234 3) There is an equiliser also, same question as above, can I download a different equilizer or dsp to replace the built in one, which may also improve sound quality? |
If you're talking about over bluetooth... I'd say "Garbage In, Garbage Out" (but that's also greatly my bias
Why are you so reliant on bluetooth though?
Why don't you download Spotify and whatever else onto the Android HU?
Also PowerAmp is pretty much the top Android music player app (if you have MP3s saved), and it has a good equalizer.
Originally Posted by Akshay1234 4) Can I change the custom home screen, or UI? Does anyone know if these can simply be downloaded and installed on android? Or is it very complicated? Are there ready made ones available for download? |
Yep - Launcher. As answered above.
Also have you tried installing
Android Auto? It will work directly on your Android HU screen, and beats trying to add a launcher etc etc - as it should have everything you want.
^ This would be my top pick in terms of features, ease of use in the car & overall polish. Quote:
Originally Posted by Akshay1234 ....and make the initial set up easier (hotspot through wifi means I'm wasting 2-3 mins just sitting in my parking connecting, etc). |
If you had an Android phone, I'd say set a Tasker task, and maybe use an NFC sticker to trigger it.
However, with iOS in theory all you have to do is turn on tethering, and then the HU should connect to the "wifi" soon after right? Why is it taking so long?
Is there any way to have a one-click "Enable tethering" option on iPhone? Maybe some app / widget that enables it?
