Originally Posted by mxh Basically I need a unit with excellent sound quality and Bluetooth pairing. I do not need a touch screen or GPS. |
mxh, I would be lying if I said I wasn't in the exact same boat as you about 2 months ago. So, I do understand what you're trying to say.
Also, I wish to clarify that when I said Infotainment, I meant it in a very broad sense. As in, OEM HUs are no longer standalone decks and 2/4 speakers. They are connected to other parts of the car as well - including steering mounted controls.
Originally Posted by mxh I am wondering if it's worth just changing the head unit rather than spending separately on a DSP. |
So, yes - if you wish to change the HU - you definitely can.
The reason I personally wouldn't recommend changing the HU is because:
- You may have to do a lot of trial and error to find the correct HU that not only accepts steering wheel controls but actually executes the assigned task.
It's pretty common to hear people say that their new HUs aren't responding correctly to the steering mounted controls. For example, the HU may change tracks when one presses the Volume button. In some cases, many claim that they find that the buttons go dead / unresponsive due to incorrect mapping.
Originally Posted by mxh If the steering mounted buttons can be mapped easily to the new HU. |
You hit the nail on the head with this statement. This "If" is a huge problem when upgrading the ICE with steering mounted controls.
- Let's assume you manage to overcome Troubling task number 1 of finding the perfect HU. You also have to consider its size and the whole fitment process. While the modification is relatively easy at any good installer, it'll eat away into your budget.
- There's also the marriage of the new HU with the new speakers. Just like your current HU, the new HU will also have its preset audio signals being sent to the speaker. Does the speaker receive it correctly? Is the output good enough? Can the new HU be configured to ensure that you get max bang for your buck?
- And finally, the cost - both in terms of time and money. The Pioneer DSP would cost you about 12-13k (including installation) while keeping the stock HU and controls perfectly intact. It'll also cost you less time to procure 1 since it's easily available. The cost of putting in a new HU while retaining all the controls, will be quite time consuming on the other hand. Whether it saves cash or not - is a different thing.
Originally Posted by mxh Also, would an amplifier required or can it be omitted? I'm not interested in a subwoofer. Just 4/6 speakers with audio that is faithful to the source with best clarity. I listen to all sorts of media from audio books to online radio (I don't use local FM/AM or CDs). |
Like I mentioned, I'm in the same boat here. In my opinion, an amp is really not necessary per se. Some do install it if they find that the current output is not loud enough.
In my opinion, I would classify that as a Level 2 installation and something that can be added later -
if you feel the need for it.
I installed a pair of 6" components in the front, and co-ax in the rear along with the DSP. The sound is excellent as is. I have neither installed an amp nor a sub and I really don't find the need for it.
Originally Posted by mxh BTW once the HU has already done its stunts I don't see how this signal can be "neutralized". It's basically guesswork being done by DSP / tuner since the original signal isn't known and the resultant audio would be something which is processed twice by different DACs (OEM HU, DSP). |
I'll leave this to the audio gurus. They'll probably be able to explain this better.
Originally Posted by navin This is a beautifully well written post. Thank you for this. |
Thank you @navin.
