What's called good music? This is unknown to me and many of us, and that's where gradual equipment upgrade makes sense we listen and come to know about the shortcomings.
Starting a basic Rs. 30,000 setup to a mid-range setup swap, I was still not happy with the output of the install. Having spent so much, I decided to explore why is it even a mid-range setup that cannot sound marginally better than OEM. This is a highly manipulative market where the hype is often created and there's a huge mismatch of equipment used, so sad but's it's the truth.
Let's dive right into it!
Front Staging -
BLAM Signature S 165.100 (Made in France)
Speaker Wiring- Platinum Crystal 16AWG, pure copper
Power Wiring- 4AWG wiring kit
Headunit - Pioneer AVH-Z9190BT
Integration- Connects2 driving control adapter
Damping- CTK silver
Yet to be upgraded-
DSP/Amplifier - Helix M Four, which will be replaced by
Helix P SIX DSP MK2
Sub - DD212 in a 1.75cu ft enclosed ported enclosure. To be decided…
RCA Cables- to be upgraded to a good shielded one
Why this component? Relatively new to India, premium offering at a good price. Materials used are absolutely top-notch. Pure magnesium dome tweeter, carbon fiber mid-range woofer.
The Install-
Headunit still needs the connects2 integration to make the steering controls work. The delivery is on the way from the UK. This model has a high res display along with better touch as compared to headunits falling in 20k bracket and that was the main reason I paid such a premium for this device.
All wiring is done with help to installation tools. The wire joint points soldered and heat-shrink sleeve applied on the top. Wire ends crimped with y-crimpers for a tight and conductive fit, again ends secured with heat-shrink.
Midrange- MDF ring with a rubber gasket between the ring and the speaker. A form baffle ring on top of the speaker so the mid base does not find it’s way into the door panel. Unfortunately, I don't have a clear picture of the baffle ring install.
Front doors and the door cover both are damped, absolutely no rattling. These components set 6.5inch drivers are high power (125w), capable of producing good controlled mid-bass.
Leather-wrapped A-pillar nicely done with all black stitching, tweeters pointing to opposite passenger headrest.
Listening Experience-
The vocals are crisp and clear, the mid-bass is tight! I can feel it pushing from left and right! So far the best audio hearing device I had was a headphone pair - Bose QC35. Now I can actually make out how muffled my headphone treble is. I'll upload a youtube video soon of the music output when the build is completed.
'Live Today, Love Tomorrow, Unite Forever' - Tomorrowland
More words to follow...
