-   In-Car Entertainment (https://www.team-bhp.com/forum/car-entertainment/)
-   -   pioneer 5850 problem (https://www.team-bhp.com/forum/car-entertainment/26397-pioneer-5850-problem.html)
deepak_ms 16th July 2007 12:17
Hi Gurus,
have a pioneer 5850 which is around 7 months old. From past few weeks its giving me strange problem.. after running for an hour or so if i try to increase the volume or change the track etc. the light gets switch off but the system will be on and song will be playing.
What may be the problem. I had taken it without bill. so its not in the warranty. whats should i do??? please help me out.
low_bass_makker 16th July 2007 12:20
the connector between the face plate and the HU base is dirty...clean it.
deepak_ms 16th July 2007 12:28
thanks LBM.. had done the same few days back. but the problem is still there.. Will clean it again and check it.
one more question if there is a dirt between the face plate and the HU why does with happen when its run for more than 1 hr. it works fine when i used it for less than 1 hr
low_bass_makker 16th July 2007 12:36
it might be that the face plate might got loose at some place which causes the failure...
check out for any loose connection. it might be also that the connector which goes in the pcb might also have dry solder which is causing the blackout.
angelfire 16th July 2007 16:17
I too have the same prob...but when i press the face plate..light comes back...is it due to the dirty connector??...wel how do you clean it..??..what solution can i use??
low_bass_makker 16th July 2007 17:41
clean it with a lint free cloth. remove any dirt on the connector which can be seen visually.
