Notorious's Verna Iced
https://www.team-bhp.com/forum/car-entertainment/53547-notoriouss-verna-iced-4.html)
At what ohms is the ID V3 running?
Originally Posted by NOTORIOUS
(Post 1176181)
Thank You Sir , The Cost Of The Components Is 12k. Sir , Come To Delhi , You Will Forget The Pics After Live Examples !!!
I Will Give You This Enclosure For 4k. You Can Give Me Rest Of 10k :D |
Arey by components i meant the whole system pricing individually. Including everything that got installed.
And i was just telling the price of the sub 14K.
This thread has turned out to be very confusing and teasing!
Originally Posted by abhinav.gupta88
(Post 1176607)
At what ohms is the ID V3 running? |
I think 4 Ohms.
nope its got D2 written on it so it has to be 2 ohms
Originally Posted by navpreet318
(Post 1176742)
nope its got D2 written on it so it has to be 2 ohms |
D2 can either run at 1ohm(parallel) or 4ohms(series).
Its a single sub Abhinav. So wats with parallel?
Sorry for my noobness
(Post 1176761)
Sorry for my noobness |
V3 is a dual voice coil sub, with each of its coil rated at 2ohms(since its a D2).
The coils can be wired either in series or in parallel depending upon the specifications of the amp.
Oh Thanks for the info. I guess it would be run on 4 ohm since i see no details on the ipaul power at 1 ohm.
(Post 1176774)
Oh Thanks for the info. I guess it would be run on 4 ohm since i see no details on the ipaul power at 1 ohm. |
:thumbs up that's wat i think.
ok.yes my bad.forgot the series parallel thing.
(Post 1176761)
Its running on 4 ohms as i said earlier.
There are 2 coils in IDV3 (2 ohm each).
Series Connection:
In a series connection you simply connect the positive terminal of
COIL 1 to positive terminal of the amplifier. Then you connect the negative terminal of
COIL 1 to the positive terminal of
COIL B. Then you connect the negative terminal of
COIL 2 to the negative terminal of the amplifier. The total impedance will be
4 ohm in the case of the above mentioned sub.
Parallel Connection:
In parallel connection the positive terminal of
COIL 1 & 2 are connected to the positive terminal of the amplifier and negative terminal of
COIL 1 & 2 are connected to the negative terminal of the amp. In this case the the total impedance is
1 OHM on amp.
notorious bhai
That's a pretty notorious setup u got. Love the comps n the sub n the amp n the wiring too.
cheers
bharti22shresth
(Post 1176181)
Thank You. Audition Can Be At Gyro (a planned Visit) Or At 1st March !!!. |
so, is the install on the cards on 1st March or already done? I didnt see install pics except for macro snapshots of products (being planned or installed already).
Originally Posted by panky12345
(Post 1177445)
so, is the install on the cards on 1st March or already done? I didnt see install pics except for macro snapshots of products (being planned or installed already). |
Is it me or you cant see Pics on Page 2?? I can see pics of Rainbow installed on the Car with a MDF Ring and Damping done.
I can See a pic of a AMP and cross-overs in the boot, I can see tons of pics of the wiring being laid in the car. What else do you call a install??? According to me there are many pics of Install taking place
Now thats One Happy Man with his Car and his ICE. :D
Chill darling! I was just asking for the complete install pics! How does the car looks like with all the gear put in.. :-)
EDIT: Notorious, is that your phone earphone ya naada in your pic :-)) BTW, you look smart.. gabru jawaan punjab da putt!
