Originally Posted by Sutripta Any truth to the rumour that he wanted more money than we were agreeable to?
Sutripta |
I doubt it. As many might know, Dr. Tank and many of his Focke-Wulf co-workers moved to Argentina after the end of WW2. Dr. Tank's last aircraft design in Argentina was the IAe Pilqui II, which was based on the FW Ta-183. Work on the Pliqui II was stopped in the early 50s because of severe financial crisis in Argentina. Many of the Germans moved to US . But Dr. Tank moved to Madras to teach in the Madras Institute of Technology.
No matter how much Pandit Nehru is criticized today, it was Pandit Nehru's dream and vision for India to be modern and self reliant in all fields. As a part of that in the early-50s, he he laid emphasis on indigenous design & manufacture of aircraft in India to lessen dependence of foreign manufacturers. While short term import of fighter aircraft was inevitable, the national policy envisaged license production of aircraft in technical collaboration with foreign manufacturers in the initial stages, followed by design, development and manufacturing facilities which would be geared towards fulfilling requirements of the IAF. So the govt was on the lookout for aircraft designers. As luck would have it, Dr Tank was in India about the same time.
Moving back to Dr Tank, He was introduced by the German Embassy to the Indian Defence Minister. Several meetings later, in the mid-1950s he was invited and contracted to design a modern supersonic fighter for the Indian Air Force.Dr Tank accepted it without any reservation and in August 1956,Dr Tank arrived in Bangalore with his deputy and his team of German engineers who went on to give shape and substance to India's first jet fighter - the HF-24.
Dr . Tank was so involved in the HF-24 project, that he himself flew in the full scale HF-24 glider model (in the back seat) many times. It was a proud moment not only for Dr Tank but the entire country when the first HF-24 flew for the first time in 1961. Pandit Nehru described the HF-24 as a Gazelle in the Air. The HF-24 was formally christened as the Marut by the then Defence Minister Yashwantrao Chavan in 1964. Barely a fortnight later, Pandit Nehru passed away, but one his dreams for India had already taken form and flight.
Dr. Tank moved back to Germany in 1970 after his contract was over. The inability to find a suitable engine plagued the HF-24's development. As I wrote earlier, he remained involved in some way or the other in Indian aeronautics. So it probably would be unfair to speculate in rumours about him being greedy.
Another aspect of the HF-24's development not many know about was the Egyptian involvement. Like Dr Tank,. another Legendary German aircraft designer - Willie Messerchmitt had begun a similar aircraft programme in Egypt in the 1960s. The Egyptian jet was called the HA-300 and it was powered by the E-300 engine designed by an Austrian engineer. In the 1960s, at the peak of the non-Aligned Movement and the particularly close ties between Pandit Nehru and President Gamal Abdul Nasser of Egypt, decisions were taken at the highest level to collaborate on new aircraft and aircraft engine technologies and developments .
In 1963, and Indian test pilot was deputed to Egypt to the parallel HA-200 jet trainer programme, but the chief the Egyptian Air Force asked him to keep an eye also on the HA-300 programme. The HA-200 was powered by the same Orpheus engine that powered the HF-24.
As a part of the Indo-Egypt collaboration, the reheat(afterburner) equipped E-300 engine of the HA-300 was being considered as an option for the HF-24. HAL meanwhile had built an HF-24 prototype with a reheated Orpheus engines which had an enlarged rear end. It would have been a relatively simple job to modify it to replace one or both Orpheus engines with the E-300. This HF-24 prototype, referred to as HF-24M.1BX, was shipped to Egypt. Shortly thereafter the aircraft was assembled and the starboard Orpheus engine was replaced by the E-300 engine and this HF-24 even sported Egyptian Air Force markings.
It was assumed by HAL that the Egyptians would be interested in E-300 powered HF-24 for their Air Force. But soon, it became clear that it wasn't the case. The Indian interest in the E-300 dissipated and the HA-300 programme ended when German engineers began to leave Egypt.
Originally Posted by confused.geek All though I find this a little weird considering the Jaguar in its current DARIN II avatar is under powered due to additional weight and the DARIN III makes the power problem worse. |
Externally, the single seat Jaguar DARIN III is the same as the original Jaguar IMs. The DARIN III Jaguar IS loses its chisel nose and gets a radar equipped nose dome like the Jaguar IM. The radar equipped, maritime strike Jaguar IMs too are getting upgraded to DARIN III standards which means their original Agave radar is being replaced by the Israeli Elta multi-mode radar.
After the Sea Eagle AShMs were retired, the Jaguar IM was left without its primary weapon. Jaguar IMs also are now compatible with the Boeing AGM-84 AShM which I assume the DARIN III Jaguar IS fleet too would be and I would like to think the radar re-equipment plan as a part of the DARIN III single seat Jaguar fleet was a part of the pan to make the entire Jaguar fleet maritime strike capable. The twin seat DARIN III Jaguar ITs do not get the radar for obvious reasons.
The F125IN engine re-equipment for the Jaguar fleet was deemed expensive and shelved. Also, let us remember the Jaguar was never meant or designed to be a high altitude bomber. It was , like the MiG-27, designed to be a low level intruder - a role for which it is still good. The same mistake is in a way being repeated with the Tejas which was deigned to replace the MiG-21, but is being expected to do the role of a Mirage 2000!!!!
