Re: Virgin hyperloop completes first test with passengers onboard, hits 172 km/h Quote:
Originally Posted by Samarth 619 We already move at 220 kms/ second in the Milky Way Galaxy, so speed is not an issue (although we can argue this speed is not within our gravity zone).
More than the speed, its the acceleration (increase rate of speed) that matters here. And in terms of acceleration, we can keep it low, quite like an airplane.
In fighter jets, females face the problems you mentioned more severely than males, and they go upto 9G acceleration (9 times the original gravity!). But that's clearly a very high level which this Hyperloop won't achieve...
Most airplane related health problems are again due to cabin air pressure, not speed/ acceleration.
The bigger issue, I would stress is, vacuum and its disasterly consequences. One leak and the system collapses like a crushed Bisleri bottle... It needs to be rethought. |
Your argument of us already moving at 220km/sec is not a valid argument (because gravity prevents us from taking off).
Acceleration and deceleration (rapid) are the main issues, as you said. Air force pilots have to train and accustom to supersonic speeds; they don't hop on just casually.
Also assuming, cabin pressure is normal, the circulatory problems will still occur in predisposed and otherwise seemingly healthy individuals simply owing to dynamics of blood flow - even a sudden change from recumbent to upright posture causes postural hypotension in normal individuals)
Airplanes are pressurised only to prevent hypoxia of high altitude - oxygen concentration in the atmosphere at 30000 feet is simply not enough to sustain human breathing. Why, even at altitudes above 24000feet (Everest high camp), even trained expeditioners need supplemental oxygen. However, at ground level, this won't be the problem.
So basically, 2 issues - control of rate of change of speed (acceleration/deceleration) and vacuum management. The second system is already at work in many hospitals in India and abroad, where all patient samples, drugs, consumables etc are rapidly transported through vacuum "chutes" from wards, to labs, from stores to the OT, nursing stations etc (without any damages to the contents) within seconds across many floors. |
