Old 9th April 2012, 01:20   #1
ghpk's Avatar
Thanked: 212 Times
DIY : Car Windshield Cleaning. Low cost method to get the Best Shine
Frankly speaking this is not my original Idea, read about this cleaning method on some thread on Team-BHP itself but it was not a detailed procedure, So thought of giving it a try.
Need for cleaning was frequent driving in dusty condition as roads in my entire town is dugged-up for new sewer line installation, and its dusty like hell, this also gives lots of mud splash if you pass on area where they sprinkle water to suppress/control the dust, this yellow mud splash/dust is a curse for windshield and one can scratch the windshield easily by dry wiping.
Used a small piece of foam
small non-Gel toothpaste, had it left somewhere for few years.
Half a bucket of water
small cloth, was a smooth Rag.
Washed the windscreen with little water, Applied two drops of toothpaste on windscreen from outside, rubbed it using the foam, washed it with water and kept rubbing with the foam and finally rubbed using the cloth to remove any water mark left from water used in washing.
Results are brilliant, and you can go through self explanatory pics.
Important:
anybody following this method should wash the car before cleaning windshield else you would need to clean the windshield with cloth again as dirty water from roof would come to windshield for sure
Same method used on read windshield and got similar shiny results .
DIY : Car Windshield Cleaning. Low cost method to get the Best Shine-20120408-1.jpg
DIY : Car Windshield Cleaning. Low cost method to get the Best Shine-20120408-2.jpg
DIY : Car Windshield Cleaning. Low cost method to get the Best Shine-20120408-3.jpg
DIY : Car Windshield Cleaning. Low cost method to get the Best Shine-20120408-4.jpg
DIY : Car Windshield Cleaning. Low cost method to get the Best Shine-20120408-5.jpg
DIY : Car Windshield Cleaning. Low cost method to get the Best Shine-20120408-6.jpg
DIY : Car Windshield Cleaning. Low cost method to get the Best Shine-20120408-7.jpg
DIY : Car Windshield Cleaning. Low cost method to get the Best Shine-20120408-8.jpg
DIY : Car Windshield Cleaning. Low cost method to get the Best Shine-20120408-9.jpg
DIY : Car Windshield Cleaning. Low cost method to get the Best Shine-20120408-10.jpg
DIY : Car Windshield Cleaning. Low cost method to get the Best Shine-20120408-11.jpg
DIY : Car Windshield Cleaning. Low cost method to get the Best Shine-20120408-12.jpg
DIY : Car Windshield Cleaning. Low cost method to get the Best Shine-20120408-13.jpg
DIY : Car Windshield Cleaning. Low cost method to get the Best Shine-20120408-14.jpg
DIY : Car Windshield Cleaning. Low cost method to get the Best Shine-20120408-15.jpg
Last edited by noopster : 9th April 2012 at 14:02. Reason: Added note from later post
ghpk is offline   (49) Thanks
Old 9th April 2012, 01:42   #2
rahul4640's Avatar
Thanked: 430 Times
re: DIY : Car Windshield Cleaning. Low cost method to get the Best Shine
Brilliant result! But what type of cloth do I need? Will any old handkerchief serve the purpose? Do I just have to wipe the watermarks before the water dries?
rahul4640 is offline
Old 9th April 2012, 02:01   #3
ghpk's Avatar
Thanked: 212 Times
Cloth can be any household rag, but it should be a soft cloth, like in my case it was a Rag made from Old smooth cotton shirt, don't forget to REMOVE the buttons and collars to avoid scratching.
you can wipe it for final touch once most of water has been rubbed or evaporated.
I forgot that I had to wipe water twice as I decided to wash the car roof after this process which again brought some dirt and water on windshield.
IMP: 20 Minutes passed, can't edit the original post now, anybody following this method should wash the car before cleaning windshield else you would need to clean the windshield with cloth again as dirty water from roof would come to windshield for sure.
Mod note: Done! Note added to opening post. Please use report post for such requests.
ghpk is offline   (1) Thanks
Old 9th April 2012, 08:18   #4
dot
dot's Avatar
Thanked: 734 Times
Great DIY! Other than toothpaste one could have used a shampoo too, followed by an spray of all purpose or glass cleaner.
Soft old cotton clothes like old vest and socks are best for this purpose.
dot is offline
Old 9th April 2012, 08:38   #5
condor's Avatar
Thanked: 16,889 Times
@ghpk - hope you did not forget to rinse the pastey water from the outlet
But good idea. Toothpaste helps in a lot of places.
condor is online now   (1) Thanks
Old 9th April 2012, 10:00   #6
Thanked: 2,736 Times
@ghpk - I hope that foam was made wet by immersing in water before starting rubbing on windshield.
True, I use it to clean monograms/logos and space between letters of car name, variant et al. It cleans the area very well & restores some amount of shine.
sukiwa is offline
Old 9th April 2012, 10:43   #7
ilangop's Avatar
Thanked: 928 Times
Hi GHPK,
That was a nice idea to make the glass shine. But taking a look into the contents of the toothpaste can help you better. Apart from the fluoride salts in it, there are also micro granular abrasives (Remember the toothpaste ad, "Has your toothpaste got any salt in it?") that give shine to the teeth. Toothpaste - Wikipedia, the free encyclopedia
And the windshield also shines because of the same. What I feel is that, over time & continued usage of toothpaste can leave microscratches on the glass and blur the vision during night driving, and will also scatter the light from the On coming traffic.
I would rather stay away from toothpaste & better go with shampoo.
ilangop is offline   (4) Thanks
Old 9th April 2012, 10:59   #8
FasterPhene's Avatar
Came to know from an uncle of mine that there is another method of getting your windshield clean and speck free. All you need is a small chunk of raw potato (read as not cooked) which you rub on the windshield and then wash off the same with water. This apparently is a trick employed by most truck drivers for a clear windshield.
FasterPhene is offline   (1) Thanks
Old 9th April 2012, 11:04   #9
siddharthp's Avatar
Thanked: 20 Times
I have added gel toothpaste(Such as Close-up) to my water reservoir which actually helps in cleaning the Nozzle spray as well as windscreen.You can avoid manual work by doing this.Moreover,gel toothpaste never clogs pipes,small holes on nozzles.I will suggest not to use toothpaste with more calcium contents.(For eg.Colgate)
Gel toothpaste can be used to clean monograms using old toothbrush very effectively as somebody already suggested.
siddharthp is offline
Old 9th April 2012, 11:52   #10
Thanked: 9 Times
IMHO one must wash the windsheild first with water (not sprinkle water) first to get rid of the grime stuck to it & to aid the same one can also use their palm / fingers to wash it off then proceed with shampoo / tooth paste for further cleaning.
The procedure of SPRINKLING water and applying tooth paste and rubbing it with a foam will cause more harm than good to the glass, for the dislodged fine grit particles will still be in the glass and you will be rubbing the same all over the windsheild (like a rubbing compound)
the best way would be
1. wash with plain water (read running water) from hose / continuous pouring. use your palm / fingers to dislodge grime.
2. pour water to wash over any left out sand particles
3. Apply tooth paste / shampoo & work out a foam with a sponge, cloth or even with bare hands to remove the oiliness
4. Thorough rinse followed by pat dry with a absorbent towel
5. wipe with good quality soft paper towel / tissue / absorbent news papers
Go Ahead enjoy a speckle free wind shield for long
TN_37 is offline   (7) Thanks
Old 9th April 2012, 12:42   #11
mjothi's Avatar
Thanked: 233 Times
Good you document it here
And you now what, these are the usual cleaning methods of those long distance bus drivers driving in the night. Yes, I remember the then TTC doing this. This along with the Tamil news paper was their best friend!!!!
mjothi is offline
Old 9th April 2012, 16:26   #12
sierrakamat's Avatar
Thanked: 77 Times
Re: DIY : Car Windshield Cleaning. Low cost method to get the Best Shine
team bhp must be the only place where not only is someone telling me that toothpaste is good for the windshield and someone else is actually suggesting a brand.way to go guys.
sierrakamat is offline   (5) Thanks
Old 9th April 2012, 16:56   #13
Thanked: 93 Times
Originally Posted by ilangop View Post
Hi GHPK,
+1 on reason to avoid tooth paste.
Leftover / rinse liquid handwash also works fine.
Soap concentrate (called "Soap Oil") also works fine. One / two teaspoons of it in reservoir clean beautiful, esp. when using with wiper in rains!
babu.sundaram is offline
Old 9th April 2012, 20:34   #14
ghpk's Avatar
Thanked: 212 Times
wow so many responses.
thats the beauty of Team-bhp, you come across so many ideas of smartly maintaining your wheels.
I would not like the idea of Rubbing Potato as it looks little more risky than using a toothpaste.
truck/taxi drivers rub tobacco also in rainy season, but I haven't tried and would not try it on my car atleast.
For Cleaning with shampoo, I've seen rainbow colored spots on windscreen it may be due to left over shampoo on screen or whatever.
toothpaste currently looks Promising, I am sure cleaning using toothpaste once in a month or two would not harm when handled carefully.
Old 9th April 2012, 21:04   #15
Tejas@perioimpl's Avatar
Thanked: 9,764 Times
Good job. Thanks for sharing.
Now for some "gyaan" from the resident dentist:
Hi GHPK,
All toothpastes have some basic things:
- abrasive to scrub the tooth
- detergent to dislodge stuck particles
- alkaline base to neutralize acid in the mouth that has been formed by bacterial attack on food
- flavoring agent
- colouring agent
- anti bacterial agents
- flouride
Now there are guidelines the manufacturer has to follow for each of these ingredients:
- abrasive cannot be so abrasive that it scratches and wears away enamel.
- detergent cannot be strong to cause oral ulcers
- can't be too alkaline so that it causes GI problems
- flavoring agent not to cause caries themselves
- colouring agent to be non staining
- antibacterial agents in small quantities that do not affect normal oral micoflora
- flourides not to be more or else will make teeth spotted
Let's take this in our car's context:
Abrasive: go ahead and use freely on glass. if it doesn't scratch enamel, it won't scratch your glass. What wears away enamel and causes sensitivity is over zealous brushing. its the bristles that harm and not the paste.
PS: gel toothpastes are more abrasive than regular pastes.
PPS: there are no free calcium radicals in the paste. The abrasive is mostly calcium carbonate / chalk in a very fine grit and water soluble.
Detergent: again good to wash your windshield. no controversy here
Alkaline base: won't affect the car adversely, but may neutralize the acid in bird ****. I'm guessing it's acidic since the damn thing really affects paint if not removed for a long time)
Flavoring and coloring agent may make the car happy especially for those who name their cars and treat them like people literally. (just kidding... )
Antibacterial agent useful if you wanna bake an omelet on your glass on a hot day
Flourides will do nothing to your car.
Not propagating the use of pastes, just putting things in perspective.
PPPS: salt, spice and limca in toothpastes are a marketing gimmick.
PPPPS: no calcium can ever be absorbed from the toothpaste onto your teeth. EVER.
Cheers.
Last edited by Tejas@perioimpl : 9th April 2012 at 21:09. Reason: added PPPS & PPPPS
Tejas@perioimpl is offline   (68) Thanks
