Re: VW Polo DIY: Adding a boot lamp! Quote:
Originally Posted by SuhairZain But if one wanted to turn the light on only when the boot is open, would it be a good idea to run an LED strip in parallel to the boot status switch? |
As indicated in the wiring diagram, you can connect one end of the light to the boot lock's pin #2 of the T4ag 4-pin connector or pin #1 of T5h connector. Check the wiring diagram. |
