Originally Posted by graaja I don't know the details, but I think you will definitely need VCDS coding to make this work. Also, if the car does not have necessary BCM wiring to control the central locking, then this may not work.
Try to search international forums if someone has already done this hack. |
VCDS is not an issue, I do have it and able to recode whole BCM from old to new (6RU937084A to 6R0937086H).
I assume, wiring from BCM to central lock should not be an issue, as central lock is already there and BCM is able to control central lock, i have tested it via VCDS - output test (able to control lock/unlock via VCDS).
It should be just BCM which sends command to central lock and remote give commands to BCM. correct me, i may be wrong :(
Now, if i try to grab another 2nd hand remote what should be configuration, as replaced BCM i got it from Germany (6R0937086H, most probably came out of VW polo car, and what FCC ID and MHz will work.
I just want to give a try with an old Key Fob (again transponder/Immobilizer is not an issue here) just the remote lock/unlock is my concern.
I'm pasting VCDS scan just for ref., if anything knock towards fix.
Monday,16,March,2020,15:23:39:00008
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.0.2 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: TMBFRA5J2CG010404 License Plate: 6638_16MAR2
Mileage: 72580km-45099mi Repair Order:
Chassis Type: 5J-SK25 (6N0)
Scan: 01 09 17 19 25 44
VIN: TMBFRA5J2CG010404 Mileage: 72580km-45099miles
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
Address 01: Engine (J623-CJLA) Labels: None
Part No SW: 03E 906 019 F HW: 03E 906 019 F
Component: SIMOS11.2 H03 9493
Revision: --H03--- Serial number:
Coding: 00110002030000000000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12MPI02103E906019F 001005
ROD: EV_ECM12MPI.rod
VCID: 275D4D9C5EED1C77F0-8072
No fault code found.
Readiness: 0000 0000
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 086 H HW: 6R0 937 086
Component: BCM PQ25 M++4 H46 0230
Revision: BD046001 Serial number: 0392 036110453
Coding: 73980B1808010040003000002E0810000040400F6000004000 0000000000
Shop #: WSC 124697 483 00190
VCID: 4189F304D889C247DE-8014
Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3211
Serial number: --------------------
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3211
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3211
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3211
Coding: 020000
2 Faults Found:
03431 - Activation of Left Parking Light
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 43
Mileage: 72580 km
Time Indication: 0
Date: 2014.08.07
Time: 04:05:58
03432 - Activation of Right Parking Light
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 43
Mileage: 72580 km
Time Indication: 0
Date: 2014.08.07
Time: 04:05:58
Address 17: Instruments (J285) Labels:* None-SRI1
Part No SW: 5JF 920 801 HW: 5JF 920 801
Component: KOMBI H05 0103
Serial number: 00000000000000
Coding: 110000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04120
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 79F95BE4F8D95A87D6-802C
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 086
Component: GW-K-CAN TP20 0230
Coding: 032300
VCID: 70EF66C0A3A31BCF61-8024
Address 25: Immobilizer (J334) Labels: None
Component: IMMO H05 0103
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09.rod
Address 44: Steering Assist (J792) Labels:* 6Rx-909-144-V1.clb
Part No SW: 6RF 909 144 J HW: 6RF 909 144 J
Component: EPS_ECU H26 0401
Coding: 0000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SteerAssisUDSNSK 005005
ROD: EV_SteerAssisUDSNSK.rod
VCID: 53A5C94C3AF540D77C-8006
End-------------------------(Elapsed Time: 01:22)--------------------------
