Re: S-Cross DIY: TPMS & 12V socket installation Quote:
Originally Posted by benzinblut A solution that comes to my mind is to cut out a section for the fuse tap and put the over back. The main reason is to protect it from dust. |
The fuse box is inside the cabin, so it should be OK. My i10 has its fuse box open though. If you cut the box to accomodate the fuse tap, then it will also remove the fuse markings around that area. I don't recommend it. It's always easy to refer which fuse each slot represents instead of using the manual
