Re: DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift Quote:
Originally Posted by Drbhavesh 1) Will the stock fog lamp wiring be enough to power the 55W fog lamps or I will need wiring harness? Will it be safe to use stock wiring in long run? |
Maruti stock fog light wiring will not support 55W HID setup. The start up surge of the ballasts is very high, and its not just about the 55W wattage of the bulb in stable run.
You must use a separate relay harness powering directly from battery. A good quality relay harness includes an inline fuse in the power wire to be connected with battery +ve terminal. This ensures better safety. Quote:
Originally Posted by Drbhavesh 2) I saw pictures of OE fog lamp switch. Could you please add Little more details on that? Which wire to connect where? |
Does your car have existing OEM fog light switch? If not - you need to source it. Please refer to this thread - Link - Alto K10 HID Fog light install (DIY - Maruti Alto K10 - HID Fog Light Installation)
I have mentioned the OEM switch link in it along with the wiring to be done to make the switch work. Exact pin details of the OEM switch connector in case you need them are available in @audioholic's thread here - Link - OEM Maruti fog light switch pin and wiring details (Maruti Celerio DIY - Fog lights and DRL installation)
If your car already had fog lights & OEM switch - you don't need to change anything here. Just connect the switch trigger wire of the extra relay harness you use to one of the fog light connectors in the bumper (LHS generally due to the limited length of wire). So that when you press the stock fog light switch, the power going to that connector actually triggers the external relay harness to draw power directly from battery for the new fog lights. Quote:
Originally Posted by Drbhavesh 3) Use of chocolate box connector is to just connect two wires right? There is no special purpose of it. |
That is the only use. But it is the best approach. Certainly far better than taping wires together. Quote:
Originally Posted by Drbhavesh 4) I find doc’s idea of getting power supply directly from battery easier and more convenient. But I read some discussion about adding a fuse. Would you mind explaining little more on this aspect please? |
If you get a good quality relay harness - it already has an inline fuse in the source wire. If you get a relay harness that doesn't have one (I'd say don't get it!) - you can add a 10 Amp fuse (available at auto spares store) and connect it at the start of the wire that you connect to battery +ve. This should be as near as possible to the terminal in the circuit so that in case of any short / failure - the fuse immediately blows and avoids melting / short circuit / fire in the rest of the wiring harness.
In his picture - the white-yellow small square box like thing you see inside the red rectangle that I have drawn - is an inline fuse for sample. The loose end of the wire after it - is to be connected to the +ve terminal of the battery directly. The black box near the bottom edge of the image is the actual external relay. The pin connector you see between the relay & the black ballast on the lower right of the image (just above "2019") is the trigger wiring in an H4 connector. If you can source a relay harness with the connector same as your stock fog light pins - you just have to insert this socket into the LHS stock wiring and you are done. Quote:
Originally Posted by Drbhavesh 5) Suppose after this, I upgrade my headlight to either 90/100 or another projector housing, will it create too much load on battery or electrics of the car? |
After you install 55W projector HIDs - you won't need to upgrade to 90/100 halogen bulbs. If you do - yes there will be excess load on the alternator and battery charging. It won't damage anything immediately of course. But its load that you can avoid.
If you install projectors within headlamps via retrofit route - the setup will be 55W again - which is same as stock halogen bulbs, so no extra load on the electricals at all.
