Old 28th May 2018, 00:52   #1
sushil_n79's Avatar
Thanked: 239 Times
DIY: Changing the battery terminals of your car
Hi Everyone
Hope this finds you all in the best of health and spirits. This is my third thread with teambhp after a long time. I am once again thankful for this opportunity.
Why this need?
This DIY was done on my brother in laws car because the crimp that held together the positive terminal broke resulting in the positive terminal wire getting disconnected. Thankfully it happened in my parking.
As the said car is a 2007 tata Indica v2 diesel which my BIL exchanged with the mechanic for a 2002 diesel fiat uno with overheating issues. Lack of spares and good mechanics who were willing to work on a fiat led him to take the decision.
Time consumed:
Although the process is fairly easy and can be done in 30-45mins. But for Me it took 2 hrs because I tried to connect it in the new terminal without removing the crimped piece which was hard to remove one the 1.5cm thick wire.finally I decided to cut it and do it.
Tools required:
10 x 11open spanner.
12 x 13 open spanner.
1 wire cutter.
1 cutting plier.
1 Electrical insulation tape.
New terminal connector
some waste cloth.
Some sandpaper
Vaseline
Industrial gloves
Last but not the least a DIY enthusiast willing to try new stuff on a weekend.
Steps to follow :
1.open the bonnet and remove dust off the battery using old cloth. Be careful not to touch the spilled over ash like dry acid near terminals as it may burn the skin if touched with bare hands.
2. Once dust is off disconnect the positive (Red)side first by loosening the connector bolt using 10 x11spanner.
3. Then follow the above procedure once again to disconnect and remove the negative (Black) side terminal.
4.Once the battery is disconnected completely, remove it from the car by lifting and keep it safely. Be careful not to drop it as it can be pretty heavy.
5. Now that we have removed the battery, we get so space to work on.
6 In this case since I was replacing only the positve terminal I did not bother much with the negative side as it was OK. Unscrew the nut of the old terminal to remove it.
7.Using the wire cutter remove the copper from the wire by stripping the red cover. Be careful not to cut it. Once the copper or seen clean it with sandpaper.
8. Once the wire is exposed insert it in the new terminal and tighten the connecting nuts using Size 12 spanner in this case to secure it tightly.
9. Place the battery back to the tray n tighten it. Take some sandpaper and clean both the terminals and the inside of old connectors.
10.Then connect the negative side terminal to battery first and then the positive side terminal. Pls ensure the connection Bolt is tight n not loose. Do Not hammer the terminals to the connectors.
11. Pls ensure to insulate any exposed copper wire outside with insulation tape then apply white petroleum jelly a.k.a Vaseline to the terminals to avoid current leakage.
Note : Since the battery was removed It's advisable to top up the battery with distilled water as we seldom get a chance to check it during out daily run.
I will upload all the pictures in the following post as the thread was created through the teambhp app and it's giving Me a security error.
Sushil Narayanan
sushil_n79 is offline   (6) Thanks
Old 28th May 2018, 01:02   #2
sushil_n79's Avatar
Thanked: 239 Times
Hi everyone
I forgot to mention the cost factor.
Since I had all the tools commonly available at home had to only purchase the new brass connection terminal which costed Rs50/- per piece
Uploading pictures of the same for your reference. Sorry for the quality as were taken in my parking with my mobile phone.
Sushil Narayanan.
DIY: Changing the battery terminals of your car-1527449158821.jpg
DIY: Changing the battery terminals of your car-1527449183165.jpg
DIY: Changing the battery terminals of your car-1527449201206.jpg
DIY: Changing the battery terminals of your car-1527449220296.jpg
DIY: Changing the battery terminals of your car-1527449235653.jpg
DIY: Changing the battery terminals of your car-1527449252122.jpg
DIY: Changing the battery terminals of your car-1527449272526.jpg
DIY: Changing the battery terminals of your car-1527449292263.jpg
DIY: Changing the battery terminals of your car-1527449315053.jpg
sushil_n79 is offline   (7) Thanks
Old 28th May 2018, 09:27   #3
Mr.Boss's Avatar
Thanked: 7,464 Times
re: DIY: Changing the battery terminals of your car
Originally Posted by sushil_n79 View Post
2. disconnect the positive (Red)side first
IMO it should be other way around.
Remove the -ve terminal first and then the +ve.
Please correct me if I'm wrong.
Mr.Boss is offline   (4) Thanks
Old 28th May 2018, 16:51   #4
R2D2's Avatar
Thanked: 5,742 Times
ALWAYS disconnect the -ve/ground terminal first.
It will prevent a serious short circuit that can occur if your spanner or other metal object touches the car body whilst removing the +ve terminal.
R2D2 is offline   (4) Thanks
Old 28th May 2018, 18:55   #5
Scarlet_Rider's Avatar
Thanked: 1,658 Times
Nice DIY Sushil!
As others members have pointed out, always disconnect the -ve first.
Disconnecting: First -ve and then +ve
Connecting: First +ve and then -ve
Check out: https://www.amaron.in/images/batteryinstallaion.pdf
Scarlet_Rider is online now   (4) Thanks
Old 29th May 2018, 19:28   #6
sushil_n79's Avatar
Thanked: 239 Times
Re: DIY: Changing the battery terminals of your car
HI everyone
Good Day
Thanks for the valuable inputs everyone. I was so engrossed in focussing on the final output that I missed this basic element. Thanks everyone for the help and support . Yes it should be negitive first and then positive.
Sushil
sushil_n79 is offline   (2) Thanks
