Job well done. Did you manage to get the headlamp leveler coupler as well? Looks great!
If possible please share some pics of the headlight side leveler connector
What gauge of wires are you using in the fuse box? Can you share the headlamp part numbers
Originally Posted by sagarpadaki
(Post 4915122)
What gauge of wires are you using in the fuse box? Can you share the headlamp part numbers |
Thanks Sagar:)
Yes, i got the headlamp leveler to work, got the required couplers from a Youtuber who did the same mod in his Tigor. He had no need for the couplers so he sent it to me for a very reasonable price. I am attaching three pics below for you. The first one is headlight side coupler, second one plugs into the stock factory wiring and the third one is the complete coupler assembly that you'll need to pull this off.
The wires i used were salvaged off of a dead Computer UPS a few months ago, the wires connected to negative and positive of battery are the same that were connected to UPS battery. Don't exactly know the gaugestupid: and the remaining two (High Beam and Low Beam) came connected with the Fuse Tap itself.
The headlamps that i have installed are the one's from Tigor/TigorJTP/Tiago JTP (They have chrome border surrounding high beam and low beam housings)
Part numbers are as follows:
542554400126
542554400127
Boodmo Links :
Headlamp Left Headlamp Right
Originally Posted by pritanshchandra
(Post 4915779)
Thanks Sagar:)
542554400126
542554400127 |
I see you have the boot lamp ordered from boodmo. Do post a seperate thread if you install the boot lamp as DIY
(Post 4915914)
I see you have the boot lamp ordered from boodmo. Do post a seperate thread if you install the boot lamp as DIY |
Yes, i did order the Boot Lamp during sale on Boodmo along with the Headlamps. I am planning to complete the DIY as soon as possible, also bought the rear fog lamp yesterday, will also install it and tap it's connection with front fog lamps for practical functionality. Have already planned the wire routing of the bootlamp and also managed to pull out a long wiring kit(from dashboard to boot) from a totaled Maruti 800. I've basically got everything needed just need some time alone with the car to complete it. Will surely post it in a separate thread. :)
If the original headlamps are replaced with the Tigor headlamps, only the connector on the headlamp would be different. So why not cutoff the connector from the old headlamp and connect it to the new headlamp? If the soldering is done neatly same the wires are insulated with shrink sleeves, it should look and work perfectly. This saves the time and effort of finding the new connector.
Originally Posted by Motard_Blr
(Post 4916852)
If the original headlamps are replaced with the Tigor headlamps, only the connector on the headlamp would be different. So why not cutoff the connector from the old headlamp and connect it to the new headlamp? If the soldering is done neatly same the wires are insulated with shrink sleeves, it should look and work perfectly. This saves the time and effort of finding the new connector. |
Cutting wires/soldering on connections etc generally tends to be questionable when it comes to warranty claims. Hence they went through the longer process of making conversion pigtails. All their changes are completely reversible to stock setup. The cars are in warranty.
