![]() | #16 |
BHPian ![]() Join Date: Jan 2020 Location: KA01/AP31
Thanked: 460 Times
![]() | #17 | |
Senior - BHPian ![]() Join Date: Sep 2015 Location: Manipal / Udupi
Thanked: 4,412 Times
| ![]() Quote:
![]() | #18 | |
BHPian ![]() | ![]() Quote:
![]() This is what I have done in my apartment basement parking. Can be switched on only with key. Connection taken from the meter room at ground floor - taking from home will be a waste of money in terms of wiring length and also overloading the incoming wiring to the apartment. Last edited by salbin : 2nd March 2020 at 18:26. Reason: Correction | |
![]() | #19 | |
The image was taken from the Hyundai website and has basic explanation on the layout and functions of different components in a typical EV setup. https://tech.hyundaimotorgroup.com/a...l-about-evs-1/ | |
![]() | #20 | |
BHPian ![]() Join Date: Jan 2020 Location: Pune
Thanked: 341 Times
| ![]() Quote:
![]() ![]() Link : https://twitter.com/Tesla/status/629...912326146?s=19 Last edited by ADI7YAK : 2nd March 2020 at 23:35. Reason: Added link. | |
![]() | #21 | |
BHPian ![]() Join Date: Mar 2008 Location: Southern Calif.
Thanked: 1,750 Times
| ![]() Quote:
![]() I also want to point out that if one is charging their car in the driveway, outside the house, a thief cant disconnect that cable and start charging his/her EV. (steal power at night). The charging cable stays locked, and stays connected, until the EV is unlocked. The charging may stop based on the setting in the app, but cable cannot be removed. I mostly charge inside the garage, but I have left the car in the driveway while it charges. I do not have to worry about someone stealing power at night. Last edited by GutsyGibbon : 3rd March 2020 at 00:06. | |
![]() | #22 |
BHPian Join Date: Feb 2017 Location: Pune
Thanked: 90 Times
| ![]() There is no trickle charging for EVs, especially those running on Li Ion batteries. The charging current, voltage etc is determined by the control algorithms sitting inside the battery management system and onboard charger/charging station. These two and maybe a master vehicle ECU, if there is one, talk to each other on CAN bus and ensure that the battery is charged optimally. Plus there are contactors (basically high voltage-high current relays) inside the vehicle, which can disconnect the charger from battery if required (even if the charger cable remains plugged into the vehicle). Therefore, even if you leave the charger cable connected for a long time, the charging will automatically stop when the vehicle detects that the battery is fully charged. |
![]() | #23 | |
BHPian Join Date: May 2008 Location: GA-08
Thanked: 135 Times
| ![]() Quote:
Better yet i suppose in future we will have wireless (super)charging capability between cars and the garage floor. No need for Plug or fancy robots! | |
![]() | #24 | |
BHPian ![]() Join Date: Dec 2014 Location: Chennai
Thanked: 786 Times
| ![]() Quote:
![]() More over the charging cable is “locked” into the car till you unlock it or deactivate charging using the RFID card so it’s not like someone can walk up to a charging car and take the cable and plug it into theirs. There is a setting on my Kona where at public charging points the cable will unlock once a desired level of charge is reached so that others can pull out the charger and use it for their own car. But it’s all entirely in your control. Last edited by reihem : 8th March 2020 at 17:00. | |
![]() | #25 | |
Senior - BHPian ![]() Join Date: Feb 2010 Location: Wellington
Thanked: 2,927 Times
| ![]() Quote:
On charging, a more practical approach would be induction based, similar to placing your phone on a charging mat. Some car manufacturers are trying to implement this on their EV's. Could be a lot slower to charge. | |
![]() | #26 |
Newbie ![]() Join Date: Mar 2020 Location: Hyderabad
Thanked: 60 Times
| ![]() I am curious to know more about charging these EVs. Here are few of my questions and few of them are hypothetical too! 1. I believe regular fast charging is not recommended, so typically people will use a regular charger at home at charge overnight once in few days/week based on the car usage. So most likely a car used for regular office commute would unlikely see a fast charger ever? 2. Most of the apartments have parking in basement level-1,2 or more where there is no network connectivity. How will we monitor the status of charging in this case? 3. Will there be provision to share charge from 1 car to another car. Typically fast charge. On a long drive will there be a provision where 1 car can rescue the another car with depleted battery or will you suggest towing as the easy alternative here. 4. Will charging technologies and plugs for fast charging have standardization/plug-n-play across different manufacturers. This will be crucial to build an interoperable network for highway driving. 5. Will the cars come with a provision to add on battery booster pack for long drives. May be these can be rented/subscribed from the car manufacturer and fit in the boot |
![]() | #27 | |
BHPian Join Date: Dec 2010 Location: Mumbai
Thanked: 132 Times
| ![]() Quote:
![]() | #28 |
BHPian ![]() | ![]() Noob Alert! ![]() I am a novice when it comes to battery mechanism and IC engines. However I have seen batteries performing weird when exposed to Sub-Zero temperatures. I have experienced this first hand when on a visit to Shimla my friends car wouldn't start when parked overnight and had to be jumped. My XUV-500 too started in the 2nd go (Battery was 1 year old). I have seen Electric buses in Manali but those wouldn't be parked for long and are run daily. I assume the chemical process of the battery slows down due to the temperature. How EV manufacturers are dealing with this situation? Just curious. |
![]() | #29 |
Thanked: 90 Times
| ![]() 1. One of the major reasons why 12V battery (or even the 12V bus itself) is present in the bus is the legacy 12V systems. 2. 12V has been the standard for past so many years and entire vehicle electricals (i.e. lamps, relays, fuses etc.) and electronics (i.e. semiconductors) have evolved around it. 3. Since EE components are in production, available easily and prices have pretty much settled down, OEMs have no incentive to develop new 48V or higher voltage based systems for auxiliaries. Plus, they can just use proven parts from their existing parts bin by having a 12V battery with DC-DC converter on board. 4. Higher voltage systems do have advantages over the 12V bus when it comes to saving copper and in turn, reducing the weight and cost. For a proper EV that translates into smaller battery -> even lesser weight -> less cost or same battery -> more range. But unless there is an industry-wide shift to higher voltage systems, we shall continue to see good old lead acid batteries in vehicles. 5. This may happen sooner or later as pure ICE based vehicles are also slowly giving way to hybrids. Even a mild hybrid has a 48V battery on board which can be upsized to power heavy duty loads like the AC compressor and EPAS. Last edited by Rudra Sen : 9th March 2020 at 14:57. Reason: Line space added for better reading |
![]() | #30 | |
BHPian ![]() Join Date: May 2015 Location: New Delhi
Thanked: 310 Times
| ![]() Quote:
![]() Can anyone please clarify if EV batteries should also be half charged when the car will remain unused for a long time? | |
