Originally Posted by knrn Aha just when I was thinking I stumbled upon this thread and voila.
I have reached the stage in life when I can now devote some time for my hobbies that I had to leave during studies. Photography being the latest one. With a one year old kid, me and my wife love taking portraits and also try to capture scenic beauty. Previously I used my iPhone. Then my brother in law bought a canon 1300 d and he lent it to us to try out. With an 18-55 f2.8 af lens. And boy Did we love it. I have gone through the thread and it's the same itch, I want to buy a camera for my own and in my opinion I have outgrown the 1300d canon.
My requirements I have already mentioned. Budget of around 60k. But not more than 70. .............
I feel an 18-140 mm lens will suit all my requirements as a one in all lens.................
I will be really thankful if you brethren can point me in the right direction.
Ps- I am a bit biased towards canon but I appreciate quality and product satisfaction more than anything else as I consider this as an investment.
Thanks in advance |
As you have just begun and have yet to figure out where your interest lies and what type of images you will be shooting mostly, I suggest that you start with a base body with a couple of lenses. After shooting for six month to a year, you will learn both the camera as well as figure out where the current system lacks, and what sort of purchases will enhance your photography.
I am a firm believer in having excellent camera with minimum frills. What more expensive models have over the base models is -
. More buttons, makes life easier if you are constantly changing settins - I do not.
. Better build and weather sealing - I really do not need it as I neither shoot in rain, nor in dust storms.
. Two Card slots - for me one is enough. In last four years and 90+K images I have yet to have a card failure.
. Swivel screen in some - I forgo that as I use the optical finder always.
. More and faster AF points - I usually use the central AF point so more are not all that useful.
So on the whole, as long as the sensor is of the same resolution and sensitivity, I will go for the base model. As I am Nikon user, I can only comment on Nikon range.
For a beginner the Nikon D3300 (not the D3400) with 18-55 kit lens is the best bet. The kit lens is surprisingly sharp. Add a few F1.8 primes like 35mm F1.8DX and 85mm F1.8, and you are set for most of the situations. The D3300 + 18-55mm + 35mm combination will set you back by less than 40K if you take advantage of online discounts. Keep the rest of your budget for later acquisitions.
In general the larger the zoom range, the less the optical performance, especially at the extremes. 18-55 is one of the best budget zooms. Lences ranges - 18-140 or even 18-300 are at best lenses that you use when you want to travel light and want images that will document your travels. Not if you want relatively sharp images and fast AF.
For birding and shooting wildlife the minimum that you should use is the 70-300 VR. If you can afford then 200mm-500mm. Do not fall into the trap of buying cheap zooms, They will leave you frustrated.
One thing that you must keep in mind is that camera bodies change every couple of years, so that you are always changing them, if you want the latest features - MP, High ISO, AF speed etc. What changes much less is the Prime Lens, which are where your investment will pay off. So rather than splurging on an expensive body, get a reasonably priced one and start buying better prime lenses (or if required professional grade zoom lenses)
At a later stage if you are more into landscape and/or high ISO shooting you can upgrade to full frame bodies. D750 is ideal combination of high ISO and low cost. For ultimate in resolution you can always get the D850 or its equivalent at that time.
