Re: Cheap but effective DIY WiFi Mesh Setup for my home Hello, Quote:
Originally Posted by shipnil My understanding is the behavior is on the client side and it doesn't change whether you have old type of router+AP setup or Mesh network. |
You are right, they are called "Sticky Client". This logic is more or less baked into the client WiFi Card firmware & OS. Some devices (due to their configuration) are more willing to roam and some are more stubborn. Ultimately, the final decision is with the clients. Quote:
How did you address this problem?
Pardon me, but I am no expert and my knowledge is limited at best. Whatever reading I have done, I see following options.
1. Use of k or v protocols with their advance settings to assist / nudge the clients into roaming
2. HeatMap and load calculation -> For effective AP placement
My network is just a simple home network. Number of devices are limited, even if I am having party at home with many guests. So per AP load factor and extra effort to configure 802.11K or V stuff didn't feel worth the effort. So I have avoided that.
What I did do is the heat map calculation for proper AP placement to avoid too much of overlap between APs. One can also play with the transmission strength of each AP to reduce the signal travel to achieve this. Quote:
Many times I have to force switch the handheld device.
In case of Mesh setup, clients do move much easily compared to multiple separate WiFi. Unless mesh is running, what you have observed is common client behavior.
I have shared some screenshot of roaming process in this post (Cheap but effective DIY WiFi Mesh Setup for my home)
Now the above is from network side. There are few things can be done at client side also for better roaming performance.
Here is an example with MS Windows. One can adjust the roaming sensitivity and decision making. Similar for Android via advance developer options but Apple devices are tough, don't see any way of changing their factory default roaming sensitivity.
Thanks. |
