-   -   why swift faster than esteem? (https://www.team-bhp.com/forum/indian-car-scene/18521-why-swift-faster-than-esteem.html)
revvesteem 29th October 2006 23:51
hi everybody..
i ve been thinking about why does swift have marginally more top speed than an esteem? according to autocar, swift has a top speed of 174kmph while esteem has mere 165 . why does it happen eventhough esteem is more aerodynamic and has more power-to-weight ratio?
abhijit 2284 30th October 2006 09:39
it seems to me that the swift should have taller gearing ,enabling it acheive a better top speed and it definately has a better drag coeffecient .
Atlest thats my personal opinion, anybody facts to support or disprove my ideology are welcome
goldie_malhotra 30th October 2006 09:44
Perhaps it could be that people are scared to take the esteem beyond those speeds - at least I would be.
Vid6639 30th October 2006 09:54
I believe the gearing for the 2 cars are different as well as the engines are tuned differently.
Also the tyre sizes for the 2 cars are different. The swifts being bigger.
n_aditya 30th October 2006 10:00
I dunno how much of this is really true but you can't believe everything you read... lol:
btw my stage 1 esteem does 160 in III gear :I Rule:
ravibhat 30th October 2006 10:02
Yes thats right vid6639. Swift is new design new car.
sreenivass 30th October 2006 11:04
I think its because of new engine design & tuning. Infact swift is a heavier car than Esteem.
Is it possible that Esteem wont be stable beyond that speed so manufacturer limited the speed despite having a capable engine ?
Iknowthisguy 30th October 2006 11:11
Swift engine is more refined & tuned ...one can see the output of the engine for esteem & swift
Also..Swift is more aerodynamic(from the looks of it) & its better planted on the road, maybe one is more confident of doing such high speeds on swift
IMO, esteem would give a "take-off" feeling on those stock tires
yogesh sarkar 30th October 2006 12:50
swift = 87bhp @ 6000rpm & 113Nm @ 4500rpm
esteem = 85 bhp @ 6000 rpm & 110 Nm @ 4500 rpm
however swift weighs 80kgs more than esteem, i guess swift has taller gear ratio compared with esteem
theMAG 30th October 2006 13:07
hi everybody..
Immediate factors are the
Swift | Esteem
Higher torque 113 NM @ 4500 rpm | 110 @ 4500 rpm
Higher BHP 87 | 85
Higher Compression ratio 9.0:1 | 9.0 +- 0.2
Taller gear ratios
Different ECU mapping etc.
Vid6639 30th October 2006 13:12
The engine is the same as that of esteem It's only tuned differently. There will be many factors which can make the swift quicker. The Exhaust design, gear ratios, ECU mapping and other stuff will differentiate.
I dont think manufacturers put any restrictions just because the car wont be stable. there will be a limitation to performance only for better mileage.
revvesteem 30th October 2006 13:17
these factors (torque, compression ratio, ecu mapping) help to incerase bhp. so we shall only conseder the final output i.e BHP. but how can mere 2 bhp more can make the car faster by 9 kmph?
I dont think swift is more aerodynamic than esteem.
Vid6639 30th October 2006 13:30
Torque and BHP are not the only factors. The bhp and torque figures are of the engine. So if the gear ratios and ECU mapping are different the preformance will vary.
Finally these numbers will not be accurate and will be exagerrated. No manufacturers actually give true speeds.
Even the mags ACI and OD will have different numbers.
Dont go by these numbers.
esteem_lover 30th October 2006 16:09
please do not believe everything the automags write. the swift sports a slightly modified esteem engine to compensate the extra weight of its body, thats all. i have done 165 on my 8 yr old esteem & stopped at that for fear of something coming off. Also my engine is not exactly fresh. so a newer MPFI esteem will certainly do more than 174. Or perhaps the speedo error in the swift is slightly more than that in the esteem. :)
hellspawn 30th October 2006 16:21
i think it has more to do with the gearing than anything else.for eg:swift
the esteem's 0-100 time is 11.43sec while the swift's 0-100 time is 12.xxsec.(as per autocar) but the esteem has a lower top speed than the swift.this shows that the swift has a taller gearing.
contrary to the first post i have touched 177 in my stock mpfi esteem.
