Old 25th March 2020, 12:02   #1
TusharK's Avatar
Thanked: 32,918 Times
Default Rumour: Maruti Swift to get 1.2L Dualjet petrol engine
According to a media report, the Maruti Suzuki Swift could be offered with the 1.2-litre Dualjet petrol engine.
Rumour: Maruti Swift to get 1.2L Dualjet petrol engine-2017marutiswift01.jpg
It has been reported that a BS6-compliant 1.2-litre Dualjet petrol engine could replace the existing 1.2-litre engine. The engine could be tuned to produce 89 BHP and 113 Nm of torque and is likely to be paired with either a 5-speed manual or 5-speed AMT.
The report suggests that the Swift might not get a mild-hybrid system, but it might come with an idle start-stop system.
In addition to the new engine, the Swift could also get a minor cosmetic update. It is also rumoured to get an updated 7-inch Smartplay Studio infotainment system.
Source
Link to Team-BHP News
TusharK is offline   (5) Thanks
Old 8th April 2020, 12:08   #2
volkman10's Avatar
Thanked: 45,581 Times
Default Re: Rumour: Maruti Swift to get 1.2L Dualjet petrol engine
Maruti Suzuki 1.2-litre Dualjet petrol engine likely to power Swift, WagonR, Ignis in the future'
The Maruti Suzuki Dualjet engine was being tested on the Indian roads from late 2015 and has been fine tuned to meet future emission norms.
This 1.2-litre K12C, dual VVT petrol engine makes more power as well as is fuel efficient. Maruti has ensured that there is more thermodynamic efficiency associated with this engine, with two injectors per cylinder (four). These are placed very close to the combustion chamber. The latter itself is now smaller. The compression ratio is higher than the older 1.2-litre engine. There are also redesigned water jackets whereas the coolant route too has been modified. Plus, the pistons have a lower friction. All these technologies together contribute to a far more cleaner running motor along with better fuel economy. While the earlier engine used to return 21.21kmpl in its BS6 avatar, the new one boasts 23.26kmpl with the manual transmission and 24.12kmpl with the AMT.
The big news is that this engine in the wake of the upcoming CAFE 2022 norms, might be used in all the Maruti Suzuki cars. This will be a replacement only for those 1.2-litre K12B engines that can be found under the hood of the Swift, Ignis and WagonR.
Link
Old 18th July 2020, 13:40   #3
DCEite's Avatar
Thanked: 1,335 Times
Any more information when the Swift will be updated with DualJet ?
DCEite is offline
Old 26th July 2020, 11:12   #4
volkman10's Avatar
It receives some exterior changes and interior updates. To be offered in six single tone and two dual tone colour options, the Swift facelift will be powered by a 1.2 liter K12C DualJet SHVS engine generating 91 hp power at 6,000 rpm and 118 Nm torque at 4,400 rpm. Its engine will be mated to a 5-speed manual or AMT gearbox. We don’t expect the full-fledged hybrid variants that are available in Japan to be introduced in India.
Launch is expected by Diwali 2020
Link
Copyright 2000 - 2021, Team-BHP.com
