I was travelling from Shimla-Delhi on my Esteem VXI - 2001 and on way a big rock/boulder got entangled beneath the car. Rock rolled under my car for 10-15 seconds. By the time I stopped, my gearbox got locked. Fortunately i could find a mechanic nearby who identified the problem to be arising due to bending of gear shift rod. He then opened the car bonnet and manually hammered the gear shift rod to remove the bend. Though the gears are working now,but as a result now my gearbox has become a little heavy to work around. Can anybody advice me as to what all things do I need to get replaced and approximate expenditure for the same.
ot:
not sure whether this is in the correct section or not.i think this shoukd be in the technical stuff section.
Originally Posted by gaurav.28ch
(Post 1039890)
Though the gears are working now,but as a result now my gearbox has become a little heavy to work around. Can anybody advice me as to what all things do I need to get replaced and approximate expenditure for the same. |
A bent shift rod is not a good thing. Please have it replaced immediately. Should not cost you more than 600 bucks including labour. Get this done ASAP.
I would also suggest you to take the car to a good mechanic or a good service centre and get it sorted out or replaced even if it comes a little high in price. Because if something comes up with the gearbox during long drives or so, you might not even be able to push the car aside
