Came across this very interesting article from AUTOCAR UK.
Apparently VW is planning a POLO based compact SUV to take on the Nissan Juke et al. Article mentions a 2014 launch.
Same article also mentions that VW is also contemplating an UP! based mini SUV.
Link
http://www.autocar.co.uk/car-news/ne...lo-suv-plotted
Source: Autocar UK website
Originally Posted by arjab
(Post 2933334)
Same article also mentions that VW is also contemplating an UP! based mini SUV. |
Isn't there alerady one called CrossPolo in some markets - most probably South African markets?
http://en.wikipedia.org/wiki/File:VW...t_20080828.jpg
On second thought, CrossPolo is basically the same car wih some mods. But I guess the compact SUV would be different car altogether - platform sharing.
Volkswagen is poised to enter the booming compact-SUV segment with a new model based on the next-generation .
The Polo SUV will be the first compact Volkswagen to be spun off the VW Group’s versatile new MQB platform, underpinnings that will be used across an expanded next-generation Polo range.
‘A0 segment’ — VW’s code for supermini-sized models — was at the top of the firm’s priority list for new model development.
The Polo SUV would be adapted for different markets.
A more basic version is likely to offered in emerging markets, while European versions will be more technically sophisticated and premium in both look and feel.
Cheers!
Source : Autocar
A mini Touareg! Looks nice. Compact SUV is the next big thing!
Hope it will be under 4m and gets a proper 1.5L Diesel for India.
VW, to complete family of SUVs built with models in all classes with the VW POLO SUV to debut in 2016. A model to sit above the Tiagun( Crossover based on UP)
Rendered as,
Concept could be displayed in March Geneva show. Pricing estimated to start at 20k Euros.
Engine options remain unconfirmed but speculated as:- A 1.0-liter three-cylinder with 110 HP (81 kW) and 175 Nm (129 lb-ft) of torque
- A 1.4-liter TSI with 150 HP (110 kW) and 250 Nm (184 lb-ft) of torque
- A 1.8-liter TSI with 185 HP (136 kW) and 280 Nm (206 lb-ft) of torque
- A 1.4-liter TDI with outputs of 90 HP (66 kW) and 105 HP (77 kW)
- A 2.0-liter TDI with outputs of 150 HP (110 kW) and 184 HP (135 kW)
There could also be an R variant with a turbocharged 2.0-liter four-cylinder that produces approximately 220 HP (161 kW).
Source:Autobild
Polo based SUV could debut at the Geneva Show.
The new crossover that is likely to adopt the MQB-A platform upon which the next-generation 2015 Polo will be based.. The Polo based crossover could bridge the gap between the production version of the Taigun and the Tiguan crossovers.
For India VW could target the Taigun as an entry level SUV while the Polo based crossover will be positioned slightly higher in par with Yeti or a bit below.
So come 2016, VW would have the NEW GEN Polo, Taigun and the POLO SUV heading to India!
http://www.cartoq.com/2015-volkswage...ing-to-geneva/
VW's New T-Roc Crossover - Could this be the golf based SUV? To premiere in the Geneva show.
Removable tablet at the control integrated in the interior mirror HD camera - designed to be mobile. These devices can also be used outside the T-Roc
The T-Roc is slightly bigger than a Polo at 4,179 mm long, 1,831 mm wide and 1,501 mm tall (164.5 x 72.1 x 59.1 inches), but significantly smaller than the production Tiguan.
Tiguan, Touareg, Taigun: VW has not just discovered the segment of SUVs early for, but now will display their intentions at the Geneva show.
With a length of 4.18 meters, the T-Roc has not quite golf format and sorted between the Taigun (3.86 meters) and the
Tiguan (4.43 meters).
One of the highlights of the four passenger interior is the fully-digital 12.3-inch instrument panel, which seems to be a recurring theme lately in the VW Group. There's also a tablet-like, user-configurable infotainment screen and, digital climate controls.
The T-Roc sits on VW's scalable MQB platform (same as the TT, Golf etc.) and according to the Germans, it weighs in at 1,420kg (3,130 pounds). Motivation is provided by the same 181hp (184PS) and 380Nm 2.0-liter turbocharged diesel found on the Golf GTD.
Paired to a seven-speed dual-clutch DSG transmission and 4MOTION all-wheel drive system with Haldex coupling. It can run up to a top speed of 210 km/h (130mph), accelerate to 100 km/h (62mph) in 6.9 seconds and return a combined fuel consumption of 4.9 l/100 km (58.6mpg UK or 48.0 mpg US) with 129 g/km of CO2.
http://www.carscoops.com/2014/02/vw-...pt-sounds.html
Golf based T-ROC SUV on test.
Disguised in the body of a Tiguan, VW's mid-size SUV in the international market, this mule is believed to be chassis testing for the new T-Roc, which should reach the market in two to three years' time
At 4179mm long, the T-Roc is some 200mm shorter than the current Tiguan, accounting for the shorter wheelbase seen on this test mule. VW is believed to be targeting a kerb weight of 1420kg for the production model.
Based on the flexible MQB platform, power for the production T-Roc should come from a turbocharged 2.0-litre four-cylinder common rail diesel engine with 181bhp and 38.7kgm of torque. Drive will be sent through a six-speed dual-clutch auto transmission, while four-wheel drive and selectable driving modes are also likely to be offered.
http://www.autocarindia.com/auto-new...uv-388030.aspx
VW shelves the entry level compact SUV Taigun shown in 2012, will now bring the T Cross as the concept for the C-SUV.
It is all set to reveal an entry level compact SUV.
The New Volkswagen
T-Cross concept to hint at Nissan Juke rival and will be shown at the Geneva show.
The new high-riding Volkswagen is described as a sister model to the earlier T-Roc – a larger VW Golf-based SUV concept revealed in 2014 and due to reach showrooms in five-door form in 2017.
The T-Cross and T-Roc form part of a volume-segment SUV model strategy being fast-tracked
will position production versions of the T-Cross and T-Roc underneath the Tiguan and Touareg in a part of the market that is currently experiencing large growth for SUV models
The models will be based on the German car maker’s highly flexible MQB platform and are planned to be offered with the choice of either petrol, diesel or plug-in petrol-electric hybrid drivetrains, together with either front-wheel drive or four-wheel drive.
The reference to the letter “T” in their names suggest the T-Cross and T-Roc will continue the Volkswagen tradition in which each of its existing SUV models have received a model name beginning with the letter “T”, including the Tiguan and Touareg.
http://www.autocar.co.uk/car-news/mo...san-juke-rival
