Old 16th September 2019, 17:09   #286
Thanked: 1,295 Times
Default Re: My new Toyota Altis D-4D: The first one on TBHP! EDIT: Sold!
Originally Posted by drmohitg View Post
Toyota is loved in our home probable because since 2005 (our first Toyota) they have never given us any trouble at all. The Altis Diesel is a great car - spacious, comfortable and fuss free.
We too looking for a similar experience. VW/Skoda are luring but it shall always dent the pocket post a certain shelf life. Moreover, between Etios Platinum Diesel and Corolla Altis there is no Toyota Diesel car. Etios Platinum although a segment lower is bare bones, even the top end or else we may have even considered it. The higher list price of Altis is worth?
Spares are not cheap but at par with the segment, perhaps less than VW/Skoda. Average yearly/10k km service cost would be approx. 5-7k.
My vote is a yes if you are looking for a car from that segment.
Thank you. 5-7K is as good as a premium hatchback, which is great for a D segment sedan. The major wear and tear parts would be the clutch kit, brake pads and suspensions. Approximately how are they priced?
After few strings pulled, got details of a pre owned Corolla Altis D of 2016 but have been driven 1.45 lakh Kms. The dealer is asking 9.5 Lakhs for it. Time is fine with us but 1.45 Lakhs is a lot (may be not for a Toyota)
Thank you for the details. I have been reading the thread and trying to get as much as I can to make a near perfect decision.
VWAllstar is online now
Old 16th September 2019, 18:27   #287
Thanked: 26 Times
You will have to provide more details like year of manufacturing. It this the diesel variant you are talking about? 28000 kms is a bit too less for a steering noise. My car had absolutely no rattles at 90k km when I sold it. The brake pads would cost you approx. 15k and IIRC the ORVM costs around 30k ( you can check with your local Toyota after sales service to know the present cost).
Sir itís G variant Petrol of 2011. Done 28000kms. Asking was 4.50 and I got it down to 3.80 considering that I will take the car as it is. Which means Iíll have to sort out the steering box issue, replace new brake pads and the orvm. Should I go for it ?
I am so sorry for bugging you with my questions. I donít want to go wrong with the purchase as we are facing some financial issues and I canít find any better place than team Bhp to clarify my doubts!
Thank you.
Tulok
Tulok is offline
Old 16th September 2019, 20:32   #288
vigsom's Avatar
Thanked: 7,257 Times
Originally Posted by Tulok View Post
looking for a corolla altis. I got one that has done 28000kms. I guess itís G model, The brake pads needs too be changed. The steering makes rattles in bad roads and the left side orvm is damaged. Kms done is genuine as He is a neighbour of ours, the car was used for his office duties.
I think it is not the steering rattle that you're hearing; it is rattle from the brake caliper pins.
While driving on bad roads, press the brake slightly and see if the noise disappears. If yes, then the pads are partially worn out.
The ORVM needs replacement only if it is non functional, doesn't open close on actuating the switch, orthe assembly has broken off.
If it is just the indicator lens that is broken just carry on.
ORVM assembly should be approx 19,000 rupees.
If it is only the mirror cover that is damaged, that would be 1,500 rupees and the ORVM indicator assembly is again approx 1,500 rupees.
vigsom is offline   (1) Thanks
Old 16th September 2019, 22:04   #289
Thanked: 26 Times
Thank you for your concern, sir.
I will try that tomorrow before finalizing the deal. But I guess it’s only from the steering box since the steering also vibrates. The brake pads needs to be replaced, it’s making that strange noise of two iron scratching against each other. And the ORVM, I guess some car just broke the whole thing.
So should I go for it for 3.80 ?
And regarding the ORVM I found some at OLX. Quoting was around 5-6 k for the automatic ORVM. What do you guys have to say about that ?
Thanks.
Tulok
Tulok is offline
Old 18th September 2019, 09:15   #290
R2D2's Avatar
Thanked: 5,040 Times
I will try that tomorrow before finalizing the deal. But I guess itís only from the steering box since the steering also vibrates. The brake pads needs to be replaced, itís making that strange noise of two iron scratching against each other. And the ORVM, I guess some car just broke the whole thing. So should I go for it for 3.80 ?
The steering assembly including the electric power assist motor is an expensive part. I would get it checked before finalising. The assembly is known to give problems if the car is used on very rough roads.
The other cause could be tie rods and bushings. Get those checked too.
Brake pads and rotors need to be checked. The grating sound is a classic case of worn out pad backing plates contacting the rotor. This will score the rotor which needs to be resurfaced or if the rotor is beyond its service life, replaced. Rotors cost about 5-6K a piece and genuine brake pads are about 7 to 9K for a set depending on which one you change (front or rear).
If the mirror assembly isn't operating automatically i.e. via the switch you can chose to operate them manually. As @vigsom said the assembly costs about 19-20K each.
Toyota replacement parts (not consumables) are expensive.
R2D2 is offline   (1) Thanks
Old 18th September 2019, 11:17   #291
Thanked: 26 Times
Ok, thank you so much sir for your valuable advice. Today, I’ll go and check it at a reputed garage as we don’t have A.S.S of Toyota in my town. It’s around 70+ kms away from here.
I still didn’t finalise it because I had doubts about the steering and now that I have got some clue, I am glad that I didn’t finalise the deal. Thank you so much again guys!
Will update about the purchase later.
Thank you.
Tulok
Tulok is offline   Received Infraction
Old 19th September 2019, 23:26   #292
drmohitg's Avatar
Thanked: 7,057 Times
That is for you to decide. If you want to go into the D segment then why not. If you ask me, then I will opt for a cross over SUV like the Seltos rather than a new Altis in today's car market.
Regardless of the brand, I would never buy a car done 1.5L kms and that too @ close to 10L asking price. Look around in the NCR and you will find a car run half with price under 5L due to the NGT rule.
drmohitg is offline   (1) Thanks
Old 23rd September 2019, 19:00   #293
Thanked: 30 Times
Hi dr. Mohit, I bought a diesel altis based on your thread in 2013 January. Has served me faithfully and I have kept it in good condition. Was looking to sell it and wanted to get an idea from you as to the price I might get. It's done 52000 KM's, Gurgaon Regn. Thanks in advance
mohananuj is offline
Old 24th September 2019, 18:54   #294
Thanked: 26 Times
So sorry for violating the rules of the forum. It was my carelessness and I will make sure to be careful in future. Anyways thank you so much guys for your valuable inputs. I just wanted to let you guys know that I just got the corolla altis that I was referring to in my earlier queries. Realising the fact that it got some issues with the steering box, I had to it to close the deal at 3.80 due to some unavoidable circumstances. I just got the brake pads changed and the car drives like a brand new car except for the sound from the steering box, which I will soon look into. And I am looking forward to a happy ownership with the help of you guys.
Regards.
Tulok.
Tulok is offline
Old 20th November 2019, 14:31   #295
drmohitg's Avatar
Last week I had requested the new owner to share some pictures of the car. The memories had come back after actually getting a message from Toyota dealership in Kerala that my car had gone in for service. I was quite happy to know that the new owner is taking care of the car. Anyways today morning he was kind enough to share some pictures and I thought I will post them here.
My new Toyota Altis D-4D: The first one on TBHP! EDIT: Sold!-img20191120wa0002.jpg
My new Toyota Altis D-4D: The first one on TBHP! EDIT: Sold!-img20191120wa0003.jpg
It was a pleasant surprise to see that the other car the owner had was a Toyota too. The hate for NGT comes back everytime I remember this car.
Sorry for the late reply. The resale is going to be very poor primarily due to the NGT rule. I would suggest driving it till the 10th year and then sell specially if you have maintained the car well. Otherwise honestly it is a buyer's market right now in DELHI NCR due to the NGT rule specially in case of diesel vehicles.
drmohitg is offline   (7) Thanks
Old 6th October 2020, 13:21   #296
drmohitg's Avatar
Unfortunate turn of events
What a week it has been. Just as we welcomed the new entrant into the garage, destiny had other plans. And for the first time in our lives, the Brezza got stolen yesterday night from outside our house.
Have registered an FIR but of-course I know there is near zero chance of the car's recovery.
Twists and turns
Surprise surprise! After a year and 3 months later since the theft, got a call from the Cops yesterday that the Brezza has been recovered. It was being driven in Punjab with a fake Punjab number plate and got caught at a random check point. More details unavailable right now.
Unsure of the process now since we received our insurance settlement amount long time back. I believe the car would be handed over to the insurance company to be sold off in the used car market. I am not sure of the exact process here.
drmohitg is offline   (6) Thanks
