Old 28th May 2020, 09:02   #841
paragsachania's Avatar
Thanked: 22,045 Times
Default re: A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!
Stopped at a good wide clearing and started tightening it - and soon this happened :
So what function is this broken cable from the ring terminal serving?
Is this your Headlight upgrade relay wiring kit? Or some other auxiliary device? Guess the terminal broke due to perpendicular pressure on it while you attempted to torque the main battery terminal nut.
paragsachania is online now
Old 28th May 2020, 09:17   #842
CrAzY dRiVeR's Avatar
Thanked: 50,900 Times
It broke off before I really started tightening, so mostly was already on the edge of material failure.
Looks like the negative earthing to the body. Switches off immediately with the cable disconnected. Car just keeps cranking without the engine firing.
And this warning lamp came on -
PS: Spotted your car parked on the road outside Royal Mart last week, but didn't see anyone around for a few minutes that I was there.
Old 28th May 2020, 09:31   #843
For sure a crucial one as you explain the symptoms. A loose or disconnected earthing to chassis can really make a car a lot more dramatic while things still continue to function normally.
A friend's Punto serviced at one of the reputed FASS near Hebbal had this loose terminal but on the chassis side and was driven for 500 Km till it started showing symptoms (with all possible warning lights on instrument panel) till the Service Center at Belgaum diagnosed it to a loosely hanging Battery negative to chassis ground terminal. So most of the sensors were functioning merely on battery power for those few hours till they finally started throwing warning on the cluster and the car stopped.
Generally, with Marutis, this one is to do with your car's security system (Immobilizer/Key Battery etc). Not sure if it signifies the same for your Punto too.
Ah that's nice. Never spotted you till now though we are less than 2 minutes away.
Which Royal Mart was this? One next to the Resort? I am now trying to recollect when was this because lockdown or no lockdown, I have mostly stepped out every alternate day on an average to either buy essentials for self or for my friend who stays at our apartment who insists that I go along with him as he doesn't want to confront the cops and cannot speak in Kannada.
Last few days, I am mostly taking out the WagonR as this has half a tank fuel left while the Ertiga is already on low fuel warning light .
We must catch up sometime soon!!
paragsachania is online now   (1) Thanks
Old 31st May 2020, 20:17   #844
Somehow I felt it was your Punto that I saw around 6:30ish on Ananthapura Road yesterday. I was being driven in a Ciaz of my friend in the opposite direction and I glanced into your car's driver seat and noticed someone who looked like you but without your glasses. Checked with Arun about your Registration number (could only see initial part) and he too feels it was you who I spotted .
Old 2nd June 2020, 08:38   #845
Yes, that's the one. Sure we should catch up someday soon.
That should have been me.
We just went out for the weekly shopping!
Old 8th June 2020, 22:16   #846
The key finally started showing signs of old age with the soft buttons developing a minor crack. Will think of replacing it later - but for now - ordered a nice looking silicon case for it.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200608_155053_1600.jpg
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200608_155208_1600.jpg
Boot release button obviously doesn't work for the Punto! Used the chance to replace the battery as well -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200603_170544.jpg
While out on a short drive yesterday (and no social distancing norms violated ) to keep the battery charged. Odo reading finally crossed 1,92,500.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200608_162349_1600.jpg
CrAzY dRiVeR is offline   (9) Thanks
Old 20th June 2020, 14:08   #847
Feels wonderful to be back on the long highways again (with Interstate travel pass and all safety precautions, ofcourse!).
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200620_175702.jpg
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200620_180202.jpg
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200620_221010.jpg
Last time I drove down - the suspension was almost dead - and still it felt miles ahead of our Xcent! The changed suspension struts, along with the upgraded 195/65 section tyres are now smiling at almost everything the roads are throwing at it. Bliss!
Will use the boring quarantine after-work hours to do some proper cleaning of the car, hopefully - inspired by 'GG'.
CrAzY dRiVeR is offline   (8) Thanks
Old 21st June 2020, 09:58   #848
Quarantine with Punto
Oh hello there! This little guy game to check out the new visitors. Used to people alright, he settled right in after having some milk, even though seeing us for the first time.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_220207.jpg
BS6 fuel effect? Fuel economy was rather less this time around, even though I was cruising at 100kmph for the most part and almost never exceeded 110kmph. Wasn't driving to conserve fuel, nor taking it easy during the last 100 kms of two-lane roads though! Was shifting down eagerly to stay in the turbo zone.
Will need to keep an eye during future runs.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_091629.jpg
Marking its territory - hmmm!
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_082910.jpg
Looks like the lower hose for the radiator. Coolant was topped up before the drive and doesn't seem to have reduced significantly (barely enough to even notice) over 800kms. So shouldn't be critical - just old age getting to the rubber parts.
Will try my luck with the local service center post the quarantine period.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_165440.jpg
Anyways - another brilliant highway drive completed successfully. Time to relax and take a nice bath:
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_174543.jpg
Clean and ready to spend quarantine at the spa -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_174656.jpg
Alloys were only cleaned with regular wash shampoo till date - and the dust was starting to show. Stubborn dirt inside the bolt area and the centre caps were also starting to look a bit faded.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_090943.jpg
Trying out Sonax Xtreme Wheel Cleaner - Full effect. Spray on -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_074847.jpg
Let it bleed -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_075636.jpg
Brush away the stubborn particles -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_080908.jpg
And wash!
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_174811.jpg
Some scratch marks inside the bolt area can't be helped - but looks satisfactory otherwise.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_082532.jpg
Good to see some lustre return to the paint. Will polish and wax later!
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_090127.jpg
Told ya he settled right in! Not much interested in the alloy wheels though - will need to see once the polish and wax stage is completed.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_065451.jpg
Last edited by CrAzY dRiVeR : 22nd June 2020 at 11:13. Reason: Added title to post
CrAzY dRiVeR is offline   (14) Thanks
Old 22nd June 2020, 11:12   #849
Quarantine with Punto (continued...)
The final product after polish, wax and tyre conditioner -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_150232.jpg
Rear wheels -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_150323.jpg
He's still not interested! Oh, well!
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_150525.jpg
Body panels still seem to have some shine left in them - but swirl marks are evident now. Will not be much bothered into such finer details. Will just do another round of proper cleaning, polish and wax later on.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_173720.jpg
Interior and plastics need attention first -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_081401.jpg
Exterior plastics were a problem area with the Punto and fades really fast. Has not been a major concern till date with the occasional application of Meguairs Natural Shine Protectant -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_091054.jpg
Post the application -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_095441.jpg
Steering wheel given a generous dose of protectant as well. Note - The extra gloss is because the protectant is yet to dry completely. It has negligible extra gloss (unlike the products used by service centres) and only helps to enhance the natural shine of the plastics.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_104915.jpg
a/c vents, CD player area etc screaming for attention -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_102332.jpg
Post cleaning.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_154902.jpg
Toothbrush is the best tool!
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_083849.jpg
Had never noticed how much of fine dust particles were stuck in these knobs - although they appear fine when viewed from the driver's seat.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_101335.jpg
Toothbrush and protectant to the rescue once again -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_155115.jpg
Dirty footwell area! May replace the worn-out pedals by next service - though not decided whether to go stock or after market.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200620_093343.jpg
Cleaned -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200620_095309.jpg
Guess I am guilty of not having paid much attention to the plastics in the lower half. They do really help make the car feel fresh again.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_083323.jpg
Passenger side - Before
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200620_091314.jpg
Passenger side - After.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_083230.jpg
Rear door pads -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200620_074619.jpg
Boot -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200620_095404.jpg
Parcel tray supports and tail lamp area -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200622_081106.jpg
Another area I've been guilty of ignoring - is the music system. They've only been vaccum cleaned, but never properly treated.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200622_063446.jpg
The JBL Amplifier especially is an older unit gifted from a friend's car - and it had a lot of dust on the sides. The DLS 4 channel seems to have been designed for colder climates and the plastics have become soft and sticky to the touch. It has also been removed and installed about 3-4 times - and that has left some marks too.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200622_063538.jpg
Cleaned.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200622_080904.jpg
Good amount of toothbrush work helped clean up the JBL amp. DLS needed some extra use of Meguairs Bug and Tar remover. (Not the ideal product, but have to make do with what I have available during the quarantine period).
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200622_080708.jpg
Sub cleaned and ready to rock! Lol.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200622_081156.jpg
Pending work -
1. Vaccum cleaning (Will need to wait till after the quarantine).
2. Underbody cleaning (Will need to go to shop and hence after the quarantine).
3. Engine bay cleaning.
4. Polish and Wax.
5. Areas around the Bonnet, door sills etc.
6. Fix the radiator lower hose (Service center later).
For now, will just enjoy the monsoon rains with a simple cup of chai in hand.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up!-20200621_074904.jpg
CrAzY dRiVeR is offline   (13) Thanks
Old 26th June 2020, 09:33   #850
Thanked: 66 Times
Sorry to bump in your ownership thread but it's bit urgent.
My fiat avventura has clocked 90500 km and needs urgent timing chain replacement as mandated by its service manual .
I am trying to source the timing kit from outside the authorised service centre and get it replaced by the mechanic working in Fiat ASC at my home .Now the problem is timing kit which is available is meant for tata quadrajets .
I am bit skeptical about the quality of tata timing kit .
Are there any better options or I have to settle for tata spares .
blueblooded is offline
Old 26th June 2020, 09:43   #851
nkrishnap's Avatar
Thanked: 5,949 Times
The ones available in Tata is the normal ones and the refreshed one which runs for 90k kms interval. So get the FCA one and replace it. Else use TATA ones and change at 50k or 60k kms interval.
If you can source FCA one nothing like it.
nkrishnap is offline   (2) Thanks
Old 26th June 2020, 09:44   #852
It is best to get the FIAT kit - the updated design (was changed sometime in 2018 IIRC) which allows for better lubrication of the chain. This was done to resolve some of the issues with timing chain in the earlier batch of 90HP Multijets.
I'm not familiar which version TATA comes with - will try to check and update.
Edit - Looks like Krishna has clarified regarding the TATA one. Skip it and get the FIAT design if you plan to retain the car for 50k kms or more.
Old 26th June 2020, 14:06   #853
Thanked: 66 Times
Well I will keep it till it starts falling apart ..
I ll try to procure FCA kit ,please do suggest ways to get it.
blueblooded is offline   (1) Thanks
Old 26th June 2020, 14:12   #854
Thanked: 20,250 Times
Did you check 99rpm.com website?
I think they must have what you need.
a4anurag is online now
Old 26th June 2020, 14:21   #855
KPR
KPR's Avatar
Thanked: 1,063 Times
Infractions: 0/1 (5)
Contact nearby FASS for over the counter spares? Or 99rpm to the rescue.
Get your mechanic to inspect the water pump too. If needed change it along with this repair. I had mine leaking at 80k odo.
KPR is online now   (1) Thanks
Copyright 2000 - 2021, Team-BHP.com
