Old 30th December 2020, 08:54   #346
amol4184's Avatar
Thanked: 5,977 Times
Re: Call of the wild - Mahindra Thar CRDe
Originally Posted by KkVaidya View Post
I have done the change to Bolero IRVM. The quality level is tad better then the one that comes standard in Thar but not as good as other mainstream cars.
I used a cork sheet behind the mirror and the body to rule out the vibrations. You will have to get longer bolts though - but putting cut cork sheet as a damper worked really well.
You will get an A4 size sheet at your nearby stationery shop.
Good call. Went to Mahindra service center but Bolero IRVM was unavailable. I will be doing the dampening like you said on existing mirror. I do have nitrile foam sheet and foam tape that I guess will be as effective. Hardtop gets delivered sometime this week. While installing that I'm planning to fix some other rattles too - specifically from the door's latches and something around right bottom corner of rear door. Thanks for the tips you guys.
amol4184 is offline
Old 30th December 2020, 10:44   #347
KkVaidya's Avatar
Thanked: 860 Times
I stopped the rear door rattle by using Insulation tape. Just wrap some tape on the male stud of the door. The rattle is cause due to inherent play around the latch.
KkVaidya is online now   (1) Thanks
Old 30th December 2020, 19:38   #348
Kosfactor's Avatar
Thanked: 11,069 Times
Call of the wild - Mahindra Thar CRDe-img_20201230_164047_exported_3394776496703005367.jpg
This is the one I got. Looks legit and works very well.
Kosfactor is offline   (2) Thanks
Old 15th January 2021, 11:37   #349
amol4184's Avatar
Car looks like this now. Hardtop from Vin4x4 is here, just waiting for my mechanic to get some free time. Those limb risers have been immensely useful although I installed them a little late.
amol4184 is offline   (1) Thanks
Old 15th February 2021, 20:48   #350
amol4184's Avatar
My mechanic contracted Corona and is out of service since last month.So I tried finding someone else who was willing to do the work. I did but the guy hadn't worked on such installation and was going to experiment with my hard top.
Father disliked that idea of some guy experimenting considering how jugaadu most mechanics are, especially the ones with whom you have never worked before.
As the time passed waiting for my primary mech to recover, we decided to take it upon ourselves and fit the HT at home. After all why not break it ourselves than someone else break it?
Long story short: don't try to install Bimbra designed FRP tops at home at any cost. You can buy that design from various manufacturers: I bought from Vin. There is someone in Mumbai too and of course a lot in North India. My warning should apply to all.
I will soon write up all the things we had to go through to fit the HT. It is simply not feasible as a DIY project unless you are sucker for pain and frustration. Lots and lots of it.
amol4184 is offline
Old 22nd April 2023, 20:03   #351
cpbopanna's Avatar
Thanked: 976 Times
Nearly 11 years, 75000 km on the odometer - still wanting to pounce
cpbopanna is offline   (12) Thanks
Old 24th August 2023, 23:03   #352
cpbopanna's Avatar
Thanked: 976 Times
11 years, 2 months, 81,150 km - time to indulge!
That's what I did with my Jeep today, indulged!
Years of running the engine and gearbox caused sufficient wear in the syncro rings to cause grinding, especially in the second and third gears.
So I decided to completely overhaul the transmission and replace all lubricants.
Stripped the transmission completely and replaced the hub with synchronizers for the first and second gears since they had worn out the most.
For the third and fourth gears, only the synchronizing rings were replaced. Since the gearbox was already opened, replaced the needle bearings, clutch (driven) plate and release bearing.
All the components were thoroughly washed with diesel and re-assembled.
The gearbox was filled with Motul Transmission Oil 80W-90 meeting API GL-4 specification and was laced with two tubes of Liqui Moly gear box additive.
The front and rear differentials were drained and filled with Valvoline Differential Oil meeting API GL-5 specification, each laced with two tubes of Liqui Moly gear box additive.
Since the engine had run more than 10,000 km after the last oil change (Motul Excess 5W-40), I decided to go one step further and use the best possible oil!
I have now switched over to Liqui Moly Molygen 5W-40 Engine Oil that meets ACEA A3, ACEA B4, API SN specifications and is a long-drain oil!
Along with this, the rocker-arm cover gasket, air-cleaner element, oil and diesel filters were replaced.
The Jeep runs as good as a new vehicle and the engine gently growls - I wouldn't call it purr, what with an output of 130 bhp and 330 Nm of torque!
Waiting to take him for a spin sometime on the Bangalore-Mysore expressway, preferably late at night and give him a chance to flex all his muscles
Last but not the least, full credit to the team at Chrome Motors, Bangalore - from the GM Mr. Maqbool, the Service Manager Mr. Dinesh Shetty, the Service Advisor Mr. Chandru and the mechanic Mr. Manju.
What fabulous service! With such a customer-centric team, I don't have to look elsewhere!
cpbopanna is offline   (11) Thanks
Old 27th August 2023, 09:21   #353
cpbopanna's Avatar
Thanked: 976 Times
At the end of a trail in a rocky mountain near Doddaballapur
cpbopanna is offline   (7) Thanks
Old 3rd September 2023, 22:13   #354
amol4184's Avatar
One of my favorite thread is alive after a long time! Good to see the update. Jeep looks great as always.
Old 27th January 2024, 20:23   #355
cpbopanna's Avatar
Thanked: 976 Times
Relaxing after a hard day's journey
cpbopanna is offline   (3) Thanks
Old 28th January 2024, 17:03   #356
cpbopanna's Avatar
Thanked: 976 Times
Jeep CRD in coffee country!
Old 16th June 2024, 16:54   #357
cpbopanna's Avatar
Thanked: 976 Times
My Jeep CRD on his twelfth birthday.
90,000 km with a heart and soul as strong as ever!
cpbopanna is offline   (6) Thanks
Old 23rd August 2024, 10:28   #358
Red Liner's Avatar
Thanked: 18,893 Times
Immaculately maintained Bopanna. A treat to the eyes!
Red Liner is offline   (1) Thanks
Old 12th January 2025, 13:37   #359
This one will last for decades, if it has an owner like you Bopanna.
Praveen.gr is offline   (1) Thanks
Old 26th January 2025, 00:03   #360
cpbopanna's Avatar
Thanked: 976 Times
Call of the wild
No gizmos, no bling, pure Jeep!
cpbopanna is offline   (2) Thanks
