Old 16th July 2018, 21:14   #511
karan561's Avatar
Thanked: 16,871 Times
Originally Posted by poloslg View Post
What is a Quanto doing at a BMW Workshop?
Not sure, probably some staffs personal car.
karan561 is offline
Old 27th September 2018, 10:17   #512
Couper72's Avatar
Thanked: 42 Times
Default Re: The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Mo
I had a few months started noticing the occasional stutter / jerk in my 328i, esp during the shift from P > D or while coming to a halt while in D. The same is not the case if I manually downshift to 1 early on, before coming to a complete halt.
After noticing it a few times in a couple of weeks and a Drivetrain error, I decided to have it looked at in the service center in Hyderabad (BMW KUN). The first thing they did was remove the mods (CAI, Race chip and the ER charge pipe) and restored it to stock and ran diagnostics.
Though they couldn't find any errors or observe any jerks / stutter, they did however replace the front passenger side suspension (apparently had a small leak) and the vapour canister (all under warranty tho). The car was at the workshop for nearly 3 weeks and i was regularly updated on the status by the GM himself. I have also been advised not to mod the car to avoid any future issues.
It's been a while since i faced any issues again and my hands are itching to put the mods back in . I really miss the boost. I would like to know if any of you faced a similar issue or any suggestions you have. Also recently I was reading about clutch slipping and was wondering if a faulty transmission had anything to do with this episode.
Cheers!!
The error that triggered it.
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-20180203_222552.jpg
Last edited by suhaas307 : 26th February 2019 at 11:41. Reason: Removing additional spacing
Couper72 is offline   (2) Thanks
Old 27th September 2018, 10:24   #513
Akshay1234's Avatar
Thanked: 10,037 Times
It would take a lot to have the ZF trans give issues. Unless its been abused, I doubt the transmission would have any issues.
BTW I read racechip in your post, please change that ASAP. Its a very basic way of increasing power and definitely not good for the engine.
So put your charge pipes back in, put the CAI but get a better box or a good tune for your car and see the difference.
Akshay1234 is offline   (3) Thanks
Old 27th September 2018, 10:43   #514
Couper72's Avatar
Thanked: 42 Times
Thanks Akshay, the dealer too was very confident that the trans is NOT the issue (air & fuel were their diagnosis). I have not put in any mods now and will take your suggestion to leave the Racechip out. I am considering the post by Karan on the Steinbauer tho..
Last edited by suhaas307 : 26th February 2019 at 11:42. Reason: Removing additional spacing
Couper72 is offline
Old 27th September 2018, 11:41   #515
ecclipse78's Avatar
Thanked: 48 Times
Similar problem in my 328i yesterday; I was overseas for two weeks and car was not used while I was away. On the first crank the engine stuttered and the drivetrain warning came on. It does not rev beyond 1200 rpm or so and on throttle the rpm drops too 800 or so; as if the engine choking.
Dealer is sending a flat-bed to collect the car tomorrow and suspects a fuel contamination issue. I find it a bit strange as I only tank up at Shell and the vehicle is only used personally by me. (clocked only 5400 km in 5.5 years !!)
Let's see the dealer's verdict in a day or so.
Cheers!!
Attachment 1802560
ecclipse78 is offline
Old 28th September 2018, 08:54   #516
Couper72's Avatar
Thanked: 42 Times
Hey Ecclipse do you have any mods on your 328i or is it stock. Were there any evident fuel leaks.
Also I have asked my dealer to give me a copy of the complete diagnostics run on the previous episode. Lemme know the verdict on yours.
Hope it is just a small glitch and wish your beamer a speedy recovery.
Last edited by suhaas307 : 26th February 2019 at 11:43. Reason: Removing additional spacing
Couper72 is offline
Old 28th September 2018, 11:41   #517
ecclipse78's Avatar
Thanked: 48 Times
Hi, nope my car is bone stock and literally babyed !!
Thing is this car and my X5 does'nt run much as I travel a fair bit and also no one else at home uses these vehicles.
Old 29th September 2018, 11:22   #518
quickdraw's Avatar
Thanked: 2,121 Times
I've covered the drivetrain issue extensively in my 328i ownership thread it's because of fuel quality.
quickdraw is offline   (1) Thanks
Old 3rd October 2018, 12:04   #519
Couper72's Avatar
Thanked: 42 Times
Hi Quickdraw!! I think my problem is not due to fuel, as I have always stuck to only one petrol bunk (Indian Oil - COCO) and last used the BMW fuel additive in Jan this year. Never the less, i haven't faced this issue again, so keeping my fingers crossed.
Couper72 is offline
Old 3rd October 2018, 12:10   #520
quickdraw's Avatar
I'm sorry to say COCO doesn't mean that their tanks etc are always maintained properly. Check and replace your fuel filter if necessary should give you more insight. Contaminants can get into fuel during transport and transfer stages and these tanks are not cleaned as often as they should under our conditions hence I'm always skeptical.
Old 5th October 2018, 10:51   #521
Couper72's Avatar
Thanked: 42 Times
Thanks Quickdraw.. I will definitely check my fuel filters for any signs of contaminants.
Couper72 is offline
Old 25th October 2018, 21:55   #522
karan561's Avatar
The BMW's sharing garage space with a very angry visitor
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-imageuploadedbyteambhp1540484680.997793.jpg
Video in the making
karan561 is offline   (11) Thanks
Old 4th November 2018, 23:29   #523
karan561's Avatar
Had organised yet another German Car Drive, this time to NH3 for a Kasara ghat lap. Here are some pictures;
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_20181104_095412_1.jpg
Mid-Drive fuel stop conversations are always epic
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_20181104_222852_511.jpg
Probably the best sounding 530d of India;
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_20181104_174431_909.jpg
The line up - F30 320d, F10 530d, F10 LCI 530d, F30 328i, Skoda Octavia RS & F30 320d.
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_20181104_100949.jpg
All BHPians
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_20181104_220357_947.jpg
karan561 is offline   (15) Thanks
Old 13th January 2019, 12:14   #524
karan561's Avatar
Default Maintenance !
Long time i hadn't updated this thread but finally have a worthy post to share. So since the last service which happened on July 2018 (Post #509) the car was running perfectly fine, but as a precautionary measure carried our 2 jobs which are described as under;
1) Spark Plugs;
Last service which was done in July 2018 the car had crossed 30,000 kms so decided to change the spark plugs. This was decided as globally many people did recommend this job specially for the early gen N20 engines in which the spark plugs used are not long lasting.
Also changing spark plugs is always a good move to gain back the performance of the car. Hence went ahead & performed this job at Infinity BMW.
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_9209.jpg
Patiently waiting for the jobs to start;
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_9210.jpg
These had to be ordered as it wasnt in stock.
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_9213.jpg
^ Aprox INR 1750/spark plug.
Old Spark Plugs & Coil Pack out;
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_9212.jpg
With the New Spark Plugs by the Side;
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_9214.jpg
Ready to go in;
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_9216.jpg
In the meanwhile the Injen Air Filter was cleaned too;
^ Should make the car breathe better
However the next up was this;
2) Electronic Wastegate Actuator;
So, the car had got hesitant a few times in the extreme high rpm range and had thrown a Drivetrain Error at me. This when the car was scanned pointed out to replace this particular part. Interestingly, when researched on the web & other BMW forums with age a lot of F30 328i (N20 Engines) owners have faced this part failure issue & my car being 6+ years old with 30k + kms on the odo it was not a surprise. Thankfully its not that expensive to replace this part (INR 9705/-) hence went ahead & did this job at BMW Infinity itself.
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_20181117_125536.jpg
New Wastegate Actuator being fixed in its position;
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-mvimg_20181117_125729.jpg
After a quick wash it was ready for delivery
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_20181117_135140.jpg
Yet again, Special thanks to friend, BHPian & Technical Head BMW Infinity, Turbhe workshop Maverick5490
Result;
With the precautionary maintenance of spark plugs, a new properly functional electronic wastegate actuator, cleaned out air filter & pleasant winters this car is all you need to thrill you out for our road conditions.
karan561 is offline   (14) Thanks
Old 30th January 2019, 15:07   #525
karan561's Avatar
Default Late Post !
SOME PICTURES CLICKED ON THE NEW YEARS EVE;
The Fortuner was driving along;
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_20181231_174931.jpg
En route Lonavala;
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_20181231_194920.jpg
At the Tungarli Lake on 1st Jan 2019;
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_20190101_164157effects.jpg
Looking Forward to more such drives with these 2 in 2019;
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_20190101_101248.jpg
Trip Log;
The ULTIMAT3- F30 BMW 328i. EDIT: Upgraded with ///M Exhaust, Injen Intake & Steinbauer Power Module-img_20190102_132928.jpg
Copyright 2000 - 2021, Team-BHP.com
