UPDATE:
A lot has happened since my last update on this thread, and I simply could not put together these updates as quickly as I would have liked to, simply because there was a huge spike in my workload after the lockdown was relaxed last month.
So I will be putting this together step by step and may have to split the post into two so that I can accommodate all photographs and updates.
Update No. 1 - Service:
My car was last serviced in November 2019 at the 34,000 mark. Having done just 4,500 km since then, a service was not really necessary but having put the car through some severe punishment during the summer (data logging, constant 0-100 runs and daily 100 km drives in and around the city) a service would not be the worst idea.
While getting it serviced, I had asked Azaan to have a look at my car's steering rack as I suspected that it was on its way out. (I could hear a knocking noise from the front axle and after repeated diagnosis of the suspension we simply could not zero-in on the sound).
As I had suspected, it was the steering rack that needed replacement - as it was absolute knackered.
Old rack:
New rack:
The new rack has made the steering feel a bit tighter and heavier than it used to be. But the knocking sound from the front axle has disappeared!
No service is complete without a quick stop over at Madhus for road-force balancing and alignment:
Madhu's new state-of-the-art facility at Wilson Garden is so well appointed that I don't mind the extra 3 km drive, even though the old facility at Richmond Town / Shanthinagar is literally 2 minutes from my flat!
Update No. 2 - Magnaflow Exhaust:
Regulars on this thread would know that I had initially opted for a Borla ProXS muffler. But after installing it, I realized that it wasn't suiting my cat-less + non-resonated setup.
I found it a bit too bassy and that was largely due to the cat-less setup I feel. The larger muffler box probably allows the exhaust gasses to linger a bit longer before being evacuated, giving it the bassy note that it's known for. I wouldn't have had this problem if the cat-con was still in place, I'm certain.
Anyway, the hunt was on for a replacement and I found this used Magnaflow muffler for sale somewhere on the internet. Upon contacting the seller, I found out that this muffler was actually the same one doing duty on Philip Mathew's erstwhile GT TSI!
Having heard the exhaust note on YouTube, I wasted no time in having it shipped to my place and getting it installed:
I must say, the exhaust note is now fantastic! It is louder than the ProRace catback setup that I had on the car last year, but it's much nicer than before. It is still a bit too loud for everyday driving though and it does drone a bit especially at around 3000 RPM.
Fitting the stock resonator quietens it down completely and it almost sounds like a stock car. Without the resonator, it's pretty wild! I may have to consider fitting a sports resonator to hit the sweet spot / middle-ground that I am after.
Update No. 3 - Whiteline Swaybar:
Other than maybe a revised Stage 2 map to take advantage of the potential unlocked by the divorced coolant circuit, I think I may have finally hit a road block when it comes to engine-related modifications for this car. There really is nothing else left in it now, other than an engine swap.
I have decided to make my peace with that for now, by focusing on other areas were I could improve the car like the handling. The Sachs + Cobra has no doubt transformed the car's ride and handling characteristics. The dampers and stabilizer links in particular have sharpened the car's steering and handling. But I knew there was more that can be had from the setup without going the Coilover route.
Some time last year I had identified UK-based Whiteline's 3-way adjustable swaybar to be an interesting mod worth considering. The part itself was around 177 pounds and during the Thanksgiving sale, it fell to a mouth-watering 150 pounds. I had to have it, but the shipping costs and custom duties threw a spanner in the works, as the landed cost would make it twice as much as it retails in the UK. It simply wasn't worth the money, in my opinion.
However, being an enthusiast has its perks. You invariably reach out to people for their views and opinions on all things car-related, and people reach out to you for the same. I have met several people as a result, some of whom have turned out to be absolute gems!
One such person is this friendly dude named Haritabh from Gurgaon who used to own and regularly track his Polo 1.5 TDI. His car was equipped with this Whiteline Swaybar that I had my eyes on for a while, and when Haritabh was looking to sell off his car lats month, I requested him to sell the swaybar to me. He gladly obliged and parceled the swaybar to my flat late last month.
Picture of the swaybar, along with washers, end-links and bushes:
Picture of the swaybar installed:
As some of you may know, the rear sway bar further stiffens the rear torsion beam axle and in the case of the Whiteline swaybar there are 3-Points of adjustability: Low - Med - Hard.
For now, I have left it at the medium setting. Immediately, I can tell that the car feels extremely responsive to steering inputs and has a much better turn-in.
The stiff rear can actually be felt especially over uneven roads, and if one side of the car traverses over an undulation while the other side remains on stable ground. But the whole car feels a lot grippier. Lane changing on the highway is crisp and body roll is non-existent.
I think I may have found the perfect setup for Bangalore and KA road conditions!
I am extremely pleased with the setup as it is now. The handling is great and the ride is not compromised too much.
The Sachs dampers give it a near-Bilstein-like feel without the added layer of stiffness that Bilsteins are known for. The Cobra progressive springs help reduce the violent rebound at the back whilst allowing the rear to feel settled over the rear rough / sharp stuff. And now with the swaybar installed, lateral movement is controlled and I can really throw the car into any corner and it will hold its line! I can't wait to try it at its stiffest setting!
For those who are not familiar with swaybars and their advantages / disadvantages, I am quoting Philip's post from his Polo thread:
Originally Posted by Philip.Mathew With a FWD Car which has a setup for understeer we have to stiffen the rear to reduce this understeer. The Polo already comes with a front anti-roll/sway bar from factory. Stiffening the front further in a FWD will only further increase understeer which is something we don't want. So on a GT TSI a simple rear sway bar can significantly improve the grip & handling characteristics, and reduce the understeer. Whereas on a Stage 2 Polo GTI, other than a rear sway bar you'll also need a slightly stiffer front sway bar. So on extremely powerful FWD Car's like a K04 Laura, Stage 2 GTI which has so much power going into the Front Wheels, we'll need to get both upgraded front and rear anti-roll bars to make sure that the rear doesn't get too stiff compared to the front, although we still want the rear to be slightly stiffer than the front to reduce the understeer and have a hint of oversteer. If the rear gets too stiff compared to the front it can lead to lift-off oversteer if you brake mid corner or in some really powerful FWD cars a simple lift off the throttle mid corner can send the weight balance forward(FWD cars are already front heavy) and as you take the turn the stiff and light rear comes loose and goes into a slide, the only way to correct this is by resetting the weight balance to normal by accelerating which will straighten out the car. |
Update No. 4 - freshening up the ol' girl with botox and a butt-job:
Most of you may be aware of the fact that Volkswagen India has facelifted the Polo about 26 times since it was launched in 2009-10. Not only did it receive the global facelift in 2014, it also received another one in 2019 exclusively for the Indian market - VW merely recycled the GTI's tasty kit by reusing it on the 2019 Polo. Good news for those looking to buy the garden-variety Polo, bad news for the GTI owners who up until then had something to differentiate their cars from the regular Polos other than the 3-door configuration.
I too wanted to give the ol' girl a facelift (or in this case - an arselift
) and some botox to keep her looking fresh after 5 years of ownership, but I did not want to go down the GTI route like everyone else. I was particularly interested in getting a nicer rear bumper especially after ProRace butchered my rear bumper to accommodate the dual exhaust finishers.
However, while Volkswagen India went in the forward-direction with their 6C GTI kit facelift in 2019, I went a bit backwards and got myself the old '6R' 2010 pre-fcelift GTI kit installed on my car, courtesy good friend and BHPian speedkills.
I personally prefer the old GTI's kit over the new one.
The kit consisted of front and rear bumpers, front fog lights, side skirts and a rear diffuser. I decided to retain the front bumper and only use the rear bumper + side skirts on my car. The reason why I decided to retain the stock front bumper is because - if you notice carefully, the old 2010 6R GTI's front bumper and the 2014 facelift Polo share the same front bumper, the only difference being the GTI bumper had a honeycomb grill whereas the 2014-15 Polo's bumper had horizontal slats. That being considered, I saw no point in changing the front bumper.
However, I had immediately noticed that there were issues with the 6R kit that needed to be addressed.
Firstly, the rear bumper had provisions for bumper reflectors on either side of the diffuser, just like on the new GTI. The diffuser also has a detachable piece that cane be removed to access the rear tow-hook.
Both the tow-hook cover and the rear bumper reflectors were not part of the kit. No amount of late-night detective work on the internet looking for the tow-hook cover and bumper reflectors helped, and after several months of browsing I decided to give up and improvise. And so I did! For the diffuser, Sachin Raju who is a good friend helped by identifying a fiber-glass fabricator who closed up the provision for the tow-hook access with fiber-glass. Similarly, I decided to get the provisions for the reflectors closed up using filler and then painted over.
Once the diffuser was ready, I got it sent to Azaan's workshop who then took the parts to his booth to get them painted and installed on my car.
I had also requested him to paint the side skirts, B / C pillars and the rear diffuser in gloss-black, so that it ties in together with the black ORVM covers and rear spoiler.
To complete the “facelift” I decided to procure the new GTI style tail lights. VW Palace Cross made me jump through hoops to get a set for these new tail lights but I finally managed to get my hands on a set. It wasn’t a straight forward swap either (please refer TheLizardKing’s brilliant thread for more details) but Azaan managed to get it done for me.
The results can be seen in the next post:
