Re: BMW 530d M-Sport (F10) : My pre-worshipped beast Quote:
Originally Posted by Chetan_Rao The LHS drain channel under the front windscreen can sometimes cause cabin leakage, esp in heavy rains.
The outlet (which usually drains somewhere behind the front quarter panel) gets clogged over a period of time due to assorted grime/leaves/twigs | Quote:
Originally Posted by Sankar The water ingress i am told is from the windshield cowl area (passenger side) and as per the technical head there | Quote:
Originally Posted by v12 More than the door or sunroof channel , I believe the seepage may be through the area below the windshield. |
Thanks guys! I'm not putting the car cover in the monsoon, hence that area does get full with leaves, twigs & junk. Remember cleaning it a couple of times. Quote:
Originally Posted by Vid6639 More than anything what worries me is the electronics below the seat! |
AFAIK, at the floor level, there's only the subwoofer. Will check. Quote:
Originally Posted by Strella On a lighter note, first you have to be careful of the hydrostatic lock, you have to watch out for the run flats and now this. |
Undoubtedly, with these cars, you have to be extremely careful. Quote:
It is reassuring to have warranty on your side, but what if somebody did not have the extended warranty. Besides the financial implications it becomes greatly inconvenient to send/ drop the car at the dealership.
| Quote:
Originally Posted by stanjohn123 The best part is that GTO's got the 6 year warranty with him handy. So he doesn't have to worry about anything even if it goes kaput. |
Buying a used European without warranty is akin to cutting the branch you're sitting on . Quote:
Originally Posted by ajmat You might want to check the pollen filter. The seal might not have been fitted properly hence alowing the leak |
Thanks! Will do. Quote:
Originally Posted by pixantz Most of these scenarios happen when the car has been in small accidents which needed denting work and the denter leaves out some small crevice like a chink in the armour and that causes these mysterious leaks. |
No such damage on my car. Quote:
Originally Posted by ashish22 The dreaded thing has happened with my 530d as well. Today i took my car out for a drive and ac was not cooling at all. I could hear faint yet noticeable hissing sound from the air vents. |
Hissing sound = leak. Any update on the culprit? Quote:
Originally Posted by pixantz Yes, given the mileage you have on the car, it would certainly be very premature a failure if it indeed is the evaporator core. |
Mercedes evaporators, in particular, are awful. There was a time when the C-Class (including my C220) and E-Class needed a new evaporator every two years. Auto Hangar themselves used to joke that 'these cars need a new evaporator with every 2nd oil change". Quote:
Originally Posted by djay99 Hi GTO. I read your entire review recently and was amazed at attention to detail. Its like a manual with lots of information. |
Thanks! Quote:
It looks like I should be able to get a 320D for 20 to 25L INR.
That's a very healthy budget. You'll easily get a low mileage car under warranty for that. Be sure to take the extended warranty. Quote:
Is extended warranty of 6 years valid from date of first sale or from date when you availed it?
From date of first sale (always the case). Quote:
Originally Posted by Axe77 Apparently Laukik has left Navnit BMW. Would you recommend speaking to anyone else in particular there in his absence? |
Very saddened that Laukik left Navnit, but hey, he's with Renault (the company) now, so good for his career .
No experience with the new guys yet. Let me try them out a couple of times before putting up a recommendation.
All I can tell you is, stick to Navnit. Infinity - especially the Worli outlet - are horrible. |
