Old 19th April 2020, 21:54   #151
Dr.Naren's Avatar
Thanked: 15,311 Times
Default re: My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto, EDIT: 10+ years & 1.3 lakh km done
I drive only 2 kms per day now. I have noticed a metal rubbing kind of noise from engine while idling. Any idea what it is ? There is no issue with performance.
Somewhere near Manipal
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20200419_215421.jpg
Dr.Naren is online now   (3) Thanks
Old 31st May 2020, 15:31   #152
Dr.Naren's Avatar
Key Remote Assembly
The remote stopped working and I suspected a dead battery as usual. I had gone to Maruti service to renew insurance of S-Cross and remembered about my SX4 Key remote. SA opened up the remote and said the chip is broken.
They had the part in stock and it costs just Rs. 585. Battery is also included. The remote has to be matched with the car after new chip, hardly 1 minute job.
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20200531_152341.jpg
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20200531_152406.jpg
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20200531_152429.jpg
Dr.Naren is online now   (8) Thanks
Old 31st May 2020, 19:53   #153
Thanked: 8,292 Times
The noise could be just about anything, really.. catcon internals may have metal bits and bobs peeled loose, may be audible at idle, loose heat shield, belt tensioner loosening etc. A once over by a mechanic top down might point to the weak area, or even you can do it, keep at idle and poke around. Since you're on top of everything in terms of maintenance, I'd doubt its anything to do with the engine itself.
Btw is that a custom headlight assembly? Looks fantastic on the SX4, looks exactly like my stock Elantra lights.
dark.knight is offline   (1) Thanks
Old 1st June 2020, 10:46   #154
Dr.Naren's Avatar
I really wish that's the reason , planning to get decat downpipe anyway .
Yes, the OE headlights are painted black and after market HID projectors are installed.
Old 28th June 2020, 12:42   #155
Thanked: 170 Times
My SX4 ZDI has completed 95K km. During the recent service I asked them to check the suspension noise. As expected they came back with lower bush having cracked/worn out on both sides.
Cost of replacement is 7K a piece
Dr Naren, how is the swift lower arm working for you? Do you recommend that I replace the SX4 lower arms with that of the swift?
rakirank is offline
Old 28th June 2020, 23:35   #156
Dr.Naren's Avatar
I have run more than 5000 Kms with lower arm of Swift. No issues faced. I have not noticed any difference while driving too.
Old 31st July 2020, 19:01   #157
Dr.Naren's Avatar
The car has done 1.28 lakh Kms now. It's been 7k+ Kms with Kenda tires and I am very happy. Wet grip is decent too, really VFM tyres I got till date. Planned to get the service done soon, need to change all fluids and filters.
Clicked this pic today
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20200731_061418_1.jpg
Thanks to ongoing pandemic, I am using only SX4 since March as I couldn't go home and swap the cars. S-Cross is safe and secure in Kerala
Dr.Naren is online now   (12) Thanks
Old 13th August 2020, 21:23   #158
Thanked: 170 Times
I enjoy driving my SX4 diesel, it's fine in the city and great on the highway.
Quite sure footed around curves (unless you really push it around corners).
The only hitch is when it has to climb inclines. This is when things are not as smooth.
Be it climbing out of a steep basement or trying to negotiate a steep climb, the car struggles and requires me to slip the clutch. Please note, that while I have driven many km, most of my driving is on flat roads, so this could well be something that I need to adapt too.
When I traveled to Kotagiri with my family, the upward climb to exit the stay in a fully loaded car was simply impossible. I had to get my family off and then was able to climb the incline. Now in comparison (though it may be apples to oranges), a few weeks before that I had been to the same place with my friends in a XUV. Now the XUV had no problem exiting the place with 5 grown-ups who are all well built. In-fact the car was stopped midway up the incline and was able to continue without any wheel spin or dramas. Please note that this was a 2WD.
So, is the SX4 diesel a little off when climbing steep inclines? Is there something that can be done to make this less stressful for the car and the driver?
PS: Completely overhauled the clutch, pressure plate, etc @ 65K km. Currently car is at 95K KM. This was done at a MASS.
rakirank is offline
Old 15th August 2020, 11:45   #159
Dr.Naren's Avatar
Better low end and reduced turbo lag can help here. There is significant gain in low end after Wolf remap in my SX4.
But, I have not faced such issues even with stock map..Yes it's little off if you encounter stop go traffic on steep inclines, but I could manage. After the remap, it's much more easier..so do give it a try
Dr.Naren is online now   (1) Thanks
Old 6th December 2020, 21:33   #160
Thanked: 13 Times
Hello Dr Naren, very well written experiences with your sx4. Mine too is a diesel 2011 model, has clocked 1.2 lakh kms. Haven't encountered any major issues except for routine wear and tear replacements. Clutch and timing chain were replaced at 1 lakh, all 4 suspension setup, rear engine mount, rear wheel bearing done recently. Has been running well. Have noticed recently that gear shift is not very precise slotting and feels as if it's rubbing against something while shifting, planning to get liqui moly gear oil additive n try. A full repaint is due. Also I have put a fanless led headlight bulb from AliExpress 3 Years back from HLXG. brightness is very good, neat cut off line and it's 4300k so feels like regular halogen bulbs to look at.
Sudhamshu is offline   (1) Thanks
Old 16th November 2021, 17:29   #161
Hi Dr Naren. In 2016 Mar you did your first remap costing 27k. Later you did multiple remaps. They all costed around same eveytime?
I have 2009 SX4 VXI petrol running on CNG from day one. Done 1L50K km. Can remap be done on petrol/CNG also?
In mountains I canít use AC while going up. Will remap help me with that situation?
arvindtayal is offline
Old 17th November 2021, 06:17   #162
Dr.Naren's Avatar
I had tried remap from Petes, TOT, and Wolf Moto. The pricing was different. Currently the car is on Wolf map and I am satisfied .
In mountains I can’t use AC while going up. Will remap help me with that situation?
Remap should be possible. You can expect better drivability and throttle response. The gains won't be as much as remapped turbo charged engines.
Dr.Naren is online now   (2) Thanks
Old 25th November 2021, 18:44   #163
Dr.Naren's Avatar
10+ years / 1.3 lakh km done!!
The car wasn't used much in last one year. I got the service done recently at Wagen Tunen, Mangalore.
What was done ?
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211112_105540__01.jpg
1. Mobil 1 FS-X2 5W40 engine oil
2. Zip oil filter
3. Zip fuel filter
4. Engine RR mount (Technix)
5. EBC Ultimax2 brake pads
6. Caliper sliding pins
7. Rear drum brakes cleaning
8. Cabin air filter
9. Car wash
WIP
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211112_134836.jpg
Engine Oil
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211112_135147.jpg
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211112_135201.jpg
EBC Brake Pads Installed
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211112_125543.jpg
Engine RR Mount (Old)
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211112_155229.jpg
This was badly worn / damaged. MGP cost is around 5.5k. I got it aftermarket (Technix make) for 1k. Part was ordered from Boodmo.
Wagen Tunen also installed cabin air filter. SX4 doesn't get it from factory, but there is a provision to install it.
Service done
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211112_163724.jpg
Wagen Tunen did a good job and I am satisfied as always
Engine air filter:
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211115_173624.jpg
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211115_173710.jpg
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211115_173721.jpg
I got it from Boodmo, Purolator brand and changed it myself.
New gear lever boot
It was worn. I got it from Boodmo and replaced it on my own. The gear knob has to be pulled out , remove the old boot , install the new boot and put the gear knob back.
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211117_145449.jpg
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211117_145627.jpg
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211117_145638.jpg
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211117_150348.jpg
Yes that's gear knob from Ciaz, had put this couple of years back.
The aftermarket projector headlights stopped working all of a sudden. I thought it was relay or ballasts and opened the bumper.
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211107_145207.jpg
I had spare relay and ballasts. Both didn't work and it was the HID bulbs itself. I had old HID bulbs from Baleno and installed the same and it worked.
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211107_170949.jpg
I took the car for a quick drive to Coorg. It doesn't even feel like 10+ year old car. I enjoyed the drive. We stayed at Club Mahindra Madikeri. It is a beautiful property.
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211124_184029.jpg
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211124_184343.jpg
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211124_140231.jpg
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211124_142900.jpg
Visited my grandpa's house on the way back
My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done-img_20211125_125210.jpg
I feel confident enough to drive this car for another 50k km easily. I would like to repaint the car fully and also plan stage 3 upgrade. Buying a new sedan today is expensive and it is very logical to keep my SX4 for longer.
Cheers!!
Dr.Naren is online now   (32) Thanks
Old 26th November 2021, 15:50   #164
sagarpadaki's Avatar
Thanked: 3,734 Times
Default Re: My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto. EDIT: 10+ years & 1.3 lakh km done
Naren, the SX4 does not look like a 10 year old at all! Kudos to you for maintaining it so well.
BTW, where do you procure the EBC brake pads from? I need a set of Greenstuff for my i20
I noticed that old brake hardware is used with the new pads. This is not a good practice and can cause the new pads to get stuck. If the brake pad clips are available as child part kindly procure and change them. There is a reason why a new set of OEM brake pads always come with brake hardware bundled with the pads in the box. That is to ensure that the new pads are able to slide on the hardware easily.
sagarpadaki is offline   (5) Thanks
Old 26th November 2021, 19:51   #165
Dr.Naren's Avatar
Thank you
I had got this set from GT Motorwerks. You can also check with KS Motorsports Mumbai.
Maruti OE pads also don't come with brake clips. It is available as child part, will get it
