Old 19th April 2016, 16:36   #31
Dr.Naren's Avatar
Thanked: 16,915 Times
re: My 2011 Maruti SX4 ZDi - Remapped by Wolf Moto, EDIT: 10+ years & 1.3 lakh km done
Originally Posted by gatham.psb View Post
The SX4 D Zdi. I am planning to take it to the service center today or tomorrow. Fuel economy and low speed performance is fine. Need to get it thoroughly checked. Thanks for the reply.
Did you observe power loss when SVS light was on? How many kms have you run and what about EGR cleaning?
Dr.Naren is offline
Old 20th April 2016, 08:56   #32
gatham.psb's Avatar
Thanked: 34 Times
There was a slight power loss. Felt like the turbo was not kicking in at all. I shut down the engine and then started again, everything was back to normal. Spoke to the technician as the MASS and he asked me to figure our under what conditions the SVS light switches on so that he can reproduce the same. Today i tried accelerating to 80 kmph+ and saw no issues. I was logging data and found that the peak boost value is around 20 psi while i thought the max was 18.9 psi. As far as my experience with my STI is concerned, some peak values are normal. This is when the wastegate should let the boost out. Will drive it more and get it checked during the weekend.
Car has run around 49K. EGR cleaning should have been done in the last service. I will get this checked again as we recently purchased this vehicle used. Service history is available and the car was only serviced in MASS by the prior owner. Just need to confirm once.
Last edited by gatham.psb : 20th April 2016 at 08:58. Reason: Add more details regarding the question
gatham.psb is offline   (1) Thanks
Old 20th April 2016, 09:09   #33
Dr.Naren's Avatar
I had similar problem and turbo was replaced under warranty. But my car used to go into limp mode after SVS light. Error code showed turbo boost high.
Dr.Naren is offline
Old 23rd April 2016, 00:40   #34
Dr.Naren's Avatar
Brake Pads
My present set of brake pads have given up in 10k kms. What would be the reason for this short life? I have observed scratch marks/uneven surface on brake discs. Would it lead to reduced brake pad life? Should I change the discs or send it to lathe for facing?
Dr.Naren is offline
Old 2nd June 2016, 08:57   #35
Dr.Naren's Avatar
Kat Kat sound from Rear Suspension
My car has run 1.1 lakh KM now. I have observed kat kat sound from rear suspension while driving on bad roads. Similar sound was present from front and I had got left side front lower arm replaced. I hope it's some bush gone kaput.
Dr.Naren is offline
Old 7th June 2016, 15:13   #36
Dr.Naren's Avatar
Hello.
Any update on your car buddy? Did you opt for EGR cleaning?
Dr.Naren is offline
Old 8th June 2016, 02:26   #37
gatham.psb's Avatar
Thanked: 34 Times
Hello.
As suspected, it was the turbo. After a couple of tries, we were able to log the p0243 error code. Once the new turbo was installed, the car was driving fine hitting triple digits easily. However, there is still a issue of intermittent power loss with no warning lights. This happens only at accelerating at very high speeds and easing the throttle in case of overtaking etc. Searched the forum and online and see that this is a common problem with the 90bhp engines. Since this happens at very high speeds, didn't really give attention to this.
Old 8th June 2016, 10:17   #38
Dr.Naren's Avatar
My SX4 also had exactly same issues. P0243 code and turbo replacement was done under warranty. Intermittent power loss issue without any error code could never be solved. But I have not faced this issue in last 15K KM post Wolf remap. EGR is switched off in map. I guess EGR is the culprit for Intermittent power loss.
Dr.Naren is offline
Old 6th July 2016, 13:59   #39
Dr.Naren's Avatar
Brake pad wear indicator was broken and was making noise. I got new brake pads and also did brake disc facing because brake disc had few scratches. Facing costed 500 rs and got after market brake pads for 1200 Rs.
Dr.Naren is offline   (1) Thanks
Old 6th July 2016, 19:35   #40
amitpunjani's Avatar
Thanked: 109 Times
Is there a Brake Pad wear indicator in Sx4? I have never seen one in my Sx4 Doctor! I have never seen any wiring attached to Brake pads.
amitpunjani is offline
Old 6th July 2016, 20:36   #41
Dr.Naren's Avatar
It's a metal strip which would make sound when brake pads are almost worn out. My brake pads were almost worn out, but that metal strip was broken and stuck in between leading to sound.
Dr.Naren is offline
Old 6th July 2016, 22:42   #42
Thanked: 109 Times
Doctor, how are the aftermarket brake pads, I also need to get one. The MGP are about Rs 2,200. How about the rear drum brake drum shoes, have you changed them till now? My car has done about 60k, only once I have changed the disc pads.
Old 6th July 2016, 23:20   #43
Dr.Naren's Avatar
This is my 2nd set of aftermarket brake pads. It is quite good. I don't find any significant difference between MGP and aftermarket brake pads. I do not have pics of brake pads (forgot to click before I installed). I will post few pics of the box
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img20160706wa0020.jpg
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img20160706wa0021.jpg
My 2011 Maruti SX4 ZDi | Remapped by Wolf Moto | EDIT: Sold at the 12-year mark-img20160706wa0022.jpg
Dr.Naren is offline   (2) Thanks
Old 7th July 2016, 10:13   #44
Thanked: 109 Times
Many thanks Naren! How about the rear brake shoe? Have you ever replaced them? My car has done about 60K, planning to get them replaced now, along with the brake pads.
B/w, the brake bite of Sx4, is just fabulous.
amitpunjani is offline   (1) Thanks
Old 7th July 2016, 10:22   #45
Dr.Naren's Avatar
I have never replaced rear brake drums. SA said rear brake liner is almost worn out. There is little squeaking noise while braking fro rear.
