Old 21st July 2017, 11:17   #271
bigron's Avatar
Thanked: 2,706 Times
re: My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 5 years & 72,000 km up!
Is Rs 12000 the average service expense of the S cross with the usual oil/air filter change routine?
bigron is offline
Old 21st July 2017, 11:31   #272
Dr.Naren's Avatar
Thanked: 16,915 Times
3rd service / 10k KM : ~4000 Rs
4th service / 20K KM : ~8000 Rs
I have mentioned the total cost spent at Maruti service centre till date
Dr.Naren is offline   (1) Thanks
Old 23rd July 2017, 12:23   #273
Dr.Naren's Avatar
Roulunds Brake pads :
I have driven more than 500 KM with new pads. The feedback is :
1. Initial bite is much better than OE pads
2. There is good improvement when braking at high speeds.
3. Brake dust is more than OE pads
My OE pads lasted only 14.5K KM and 7K km. I do not blame the pads, it's my driving . I hope Roulunds last at least 14.5K KM. Its much cheaper than OE pads and I am happy with overall improvement.
Please provide feedback on the Roulunds brake pads and a comparison with stock pads once you use them a bit.
Dr.Naren is offline   (3) Thanks
Old 29th July 2017, 21:12   #274
Dr.Naren's Avatar
23000 KM done
I have driven more than 23000 KM and I have had lots of fun in last 8K km, thanks to Wolf remap and Blackworks Downpipe. I have got updated map from Wolf few days back. The engine air filter was little dirty and I wanted to replace it to appreciate real gains from previous tune.
I had been to many MGP stores and Maruti service centres searching for S-Cross 1.3 air filter. Due to GST, most of them did not have stock. I managed to get S-Cross 1.6 filter finally. It costs 910 rs as it's SGP. My car is April 2016 make and the new filter is October 2015 . I could notice some marginal improvement post new filter change. The turbo kick is more stronger and there is mild improvement in top end.
New 1.6 air filter vs Old 1.3 air filter
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20170729_204706_hht.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20170729_204723_hht.jpg
SGP part : Made in Romania
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20170729_204827_hht.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20170729_204858.jpg
I am very happy with my S-Cross 1.6. The mods like Wolf remap, Blackworks Downpipe & TB plate delete, XP Micro Bixenon Fog Projectors, Continental MC5 tyres have just made it perfect.
Dr.Naren is offline   (5) Thanks
Old 3rd August 2017, 10:28   #275
Dr.Naren's Avatar
Rat Attack
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20170803wa0010.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20170803wa0009.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20170803wa0008.jpg
Rats have done some minor damages below the engine cover. Luckily no wires were damaged. I had seen one Maruti circular mentioning that S-Cross 1.6 had lost power due to rat bite on vacuum pipe of turbo. I took the car out and everything looked fine. Need to do something and keep these rodents away.
P.S : The rats have got into the cabin of Altura and damaged seats, floor mats etc.
Old 4th August 2017, 22:29   #276
Dr.Naren's Avatar
I had noticed some issues with my suspension setup around 1000 KM back and the dealer had told me everything is perfect. I had noticed oil leak in front right shock absorber last week. The dealer has agreed to replace only front right shock under warranty. I should be getting it done soon as the part is still in transit.
My concern is that both right and left shocks would be from same batch (potentially defective or not up to the mark??). Also if they change it only on one side, will it be balanced?? I am sure that even the left side is weak, but no visible oil leak.
Oil leak from front right shock absorber :
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20170731_112340.jpg
Old 4th August 2017, 22:43   #277
vishy76's Avatar
Thanked: 9,811 Times
I think it is better to replace both the front ones. Shocks are always to be replaced in pairs and only individually incase there is an accident of course.
To be brutally honest, your dealer seems to be very linient with warranty claims. Companies like Volkswagen only have a 6 month warranty on shocks and tie rod ends.
Taking into consideration all of this, get both the front shocks replaced. In terms of unevenness, I have no idea how damaged the second one is, but you never know. The shock is a part that can go bust or leak oil spontaneously and you wouldn't want to visit the dealer again.
vishy76 is online now   (2) Thanks
Old 4th August 2017, 22:49   #278
Dr.Naren's Avatar
Originally Posted by vishy76 View Post
To be brutally honest, your dealer seems to be very linient with warranty claims. Companies like Volkswagen only have a 6 month warranty on shocks and tie rod ends..
Haha, that is why Maruti Suzuki is unbeatable . Maruti had changed shocks in my SX4 even at 50K km under extended warranty.
If they are not willing to change left side shock under warranty, I will pay from my pocket and get it done
Dr.Naren is offline   (2) Thanks
Old 5th August 2017, 12:47   #279
Dr.Naren's Avatar
Front Right Shock Absorber Replaced :
I got call from SA that the part has arrived and I got it replaced under warranty. The front shocks and springs are slightly different in 1.3 and 1.6 S-Cross. I double checked if it was the right part and confirmed by D16 label .
They checked both sides and left side was perfect. It was not weak as I had thought. It was as good as the new replaced one. So, I believe it has nothing to do with driving pattern. They also agreed that few parts supplied by vendors will have short life span / not perfect. Good news is everything covered under warranty except rubber parts. The car was out in 1 hour. I could feel significant improvement. There is no nose diving under hard braking and also the car doesn't feel floaty on corners now. The ride has also improved.
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20170805_121933.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20170805_122405.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20170805_122420.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20170805_122727.jpg
Old 7th August 2017, 23:41   #280
Dr.Naren's Avatar
Drove 250 KM today : Mysore to Kasaragod
Ready for the drive
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20170806_103124.jpg
Nearing Coorg: Love this road!!
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-screenshot_20170807231151148_com.miui.videoplayer.png
My right foot was heavy during this drive. I got 14 kmpl . The car performed very well : new updated Wolf map, new brake pads, new front strut were all tested haha. I would be driving back to Mysore in SX4 / Kwid.
Dr.Naren is offline   (4) Thanks
Old 8th August 2017, 14:24   #281
Dr.Naren's Avatar
The car was little dirty and needed a wash. It's been long time since I washed the car myself. It's always a good practice to wash the car on your own and you will get to know all new scratches .
What was used?
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20170808wa0018.jpg
Before & After pics :
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20170808wa0012.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20170808wa0011.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20170808wa0015.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20170808wa0013.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20170808wa0016.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20170808wa0014.jpg
This is what matters the most
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20170808wa0017.jpg
Dr.Naren is offline   (7) Thanks
Old 10th August 2017, 13:07   #282
Dr.Naren's Avatar
I had given the car to dad and expected him to use the car. He says he would not use the car at all and he is happy with Maruti 800 .
So, what's the status of my S-Cross??
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20170810_101432.jpg
Locked in Arecanut godown
Old 10th August 2017, 14:31   #283
Leoshashi's Avatar
Thanked: 42,424 Times
Hope the rodents don't vandalise your car there. Rats are an issue when cars are parked in such godowns for an extended period. Kindly take care of that aspect too.
Shashi
Leoshashi is offline   (2) Thanks
Old 10th August 2017, 14:35   #284
Dr.Naren's Avatar
Haha, actually this place is completely sealed. Rat proof I say . I did take some precautionary measures as the car won't be used for months.
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20170809wa0028.jpg
Old 10th August 2017, 14:56   #285
tharian's Avatar
Thanked: 8,040 Times
Any reason for the hoods to be left open ?
tharian is online now
