Old 2nd February 2018, 18:26   #376
Dr.Naren's Avatar
Thanked: 13,160 Times
Default re: My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!
Hmm..IMHO a lot can happen to those parts in 5K kms given the # of 0-100 launches you do.
Hahaha. The life of my brake pads are little more than 5K km .
And remember, disc rotors are not measured for run-out in a normal service at the ASC unless you tell the service advisor about have symptoms that you are experiencing OR the car clocks a certain # of kms. Take the SA for a test drive and let him experience/hear it for himself.
Service centre guys were not very interested. As I was running with non MGP pads, they blamed it on them. I have extra set of MGP pads lying around. I will install them and check again with Maruti. Also this had reduced by big margin after they did caliper greasing. It was back within 500 KM.
Also see if you can get performance brake shoes (S-Cross has rear drum brakes, right?) for your car.
S-Cross has rear discs
Dr.Naren is offline
Old 2nd February 2018, 18:42   #377
R2D2's Avatar
Thanked: 5,040 Times
In a world where vehicle owners grumble if pads wear out in 30--40K kms this has gotta be a new record in my view at least for domestic non competition family cars.
Just 500 km? Ok so here's what I think is happening and I could be wrong. MSIL's caliper grease loses ability to lubricate due to very high temperatures experienced during your performance runs, calipers do not release fully, as a result of which brake pads and rotors remain partially in contact and run hot continuously. Which also means they don't get to cool off and this leads to warped surfaces (rotors and/or pads) over time. Since you have a spare set of MGP pads install them and take the car right back to the ASC for a rotor check.
I stand corrected
R2D2 is offline   (5) Thanks
Old 2nd February 2018, 18:57   #378
Dr.Naren's Avatar
I think your analysis is right . Dad messaged me to try out something and I am back home after a short drive. He told me to drive normally and not to use much brakes. He wanted me to check if discs become very hot. I observed that discs did become really hot, even without braking. Guess we found out the culprit .
Dr.Naren is offline   (3) Thanks
Old 3rd February 2018, 20:15   #379
Dr.Naren's Avatar
AC Vent Cleaning :
I got 3M AC Vent Cleaning foam from Amazon for Rs. 200. I had used the same in Baleno and it was totally worth for the price. 3M store charges more than Rs. 1000.
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180203_144444.jpg
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180203_144504.jpg
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180203_151908.jpg
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180203_152139.jpg
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180203_152903.jpg
I could clean only 2 vents and the bottle was empty . I am not sure if the bottle had less quantity or AC vents in S-Cross took in more. One bottle was sufficient for 4 AC vents in my Baleno. I will order one more bottle.
Road Force Balancing and Wheel Alignment at Madhus, Mysore
It was more than 7500 KM post WB and WA. I got it done today. The service was good like last time.
Hunter Elite : Road force machine
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180203_172334.jpg
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180203_181241.jpg
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180203_173619.jpg
Total Bill : Rs. 1050
The car is doing good. I have filled Shell V power diesel. The performance is slightly better as per Butt dyno. But I have observed that car is smoking more. I will fill regular diesel next time.
Dr.Naren is offline   (8) Thanks
Old 3rd February 2018, 20:31   #380
QuickLink's Avatar
Thanked: 19 Times
AC Vent Cleaning :
Have you noticed any perceptible difference in the performance after the cleaning of AC vents? Just asking you because I had used one such product from another manufacturer but it didn't make any difference.
QuickLink is offline
Old 3rd February 2018, 20:39   #381
Dr.Naren's Avatar
Do not expect big difference. There is some difference for sure. Air flow gets slightly better. There is pleasant smell too, but it lasts only for a week . I do this mainly to clean the dust inside AC vents.
Which product did you use?
Dr.Naren is offline   (2) Thanks
Old 3rd February 2018, 20:57   #382
QuickLink's Avatar
Thanked: 19 Times
At least there is a pleasant smell in your case because in my case, it had absolutely no effect
I don't remember the exact brand name because it was a long time back but I do remember that it came in a bottle containing around 450 ml of cleaning foam.
Old 3rd February 2018, 21:22   #383
Awaiting Email Confirmation
Thanked: 7,093 Times
AC Vent Cleaning :
Attachment 1723770
Attachment 1723772
Attachment 1723771
Attachment 1723773
Attachment 1723774
I got six bottles of these for myself (three from mine and three from another) because the price was really good compared to what the shop charges for cleaning AC. I emptied two bottles in the i10 through the center vent into the evaporator coil. After some time I could see some liquid collected on the ground which drained through the drain valve and it looked dirty, so i guess it did work.
Reg quantity i think only this much is there and the cans are not really old like some reviews said, they are all late 2017 manufactured. Even using two bottles per car its better than what the shop charges.
PS: If you pump all that in and still the foam does not rise till the vents then there could be leak at the ac ducting joints. When I dumped it in mine expecting the foam to rise till the vent I saw foam leak out through the duct joints behind the dashboard. I could observe this only because the stereo was out as i was doing the HU swap when i decided to clean the AC, with the stereo in place I wouldn't have known.
Sankar is offline   (6) Thanks
Old 3rd February 2018, 21:49   #384
Dr.Naren's Avatar
That explains it all. Thanks
I had cleaned only side vents today and the bottle was empty. It did take really long time for the foam to come out from the vents. The bottle got empty after that. After I started driving, my foot got wet. The foam water was leaking. Now coming to LHS vent, there was leak again. I could see it on the floor and inside glovebox. I had no such experience in Baleno. It was all good.
Dr.Naren is offline   (4) Thanks
Old 8th February 2018, 17:11   #385
Dr.Naren's Avatar
I wanted to change sliding pin set and brake pads to fix steering vibration issue under braking. I got sliding pin set from MGP store and also got EBC green stuff brake pads. Unfortunately the pads did not fit in, I have asked the seller to send the correct part. Do note that S-Cross Europe has different brake pads, we get slightly smaller ones. S-Cross India brake pads are same as old SX4.
Sliding Pin Set :
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180207_131406.jpg
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180207_131536.jpg
EBC Green Stuff (Received the wrong part, did not fit)
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180207_134819.jpg
I would be receiving the right part in 2-3 weeks. But, the current pads were almost gone. I had to drive 300 KM. I had old ASK brake pads in boot (more than 50 percent life left). Dad wanted me to try Rane pads when I changed rotors. ASK was still good, but you have to listen to DAD haha. I went to FNG and installed new sliding pin set and old ASK brake pads. Labour was only Rs. 250. I am happy to report that steering vibration under braking has disappeared now. I am not sure when it would come back though .
Brake Pads History :
1. OE Pads : 14,500 KM
2. OE pads : 7,500 KM
3. Roullunds pads : 4,000 KM
4. Rane pads : 4,000 KM
5. ASK brake pads : 3000 KM and still running
People change their first set at around 35K km and I am on 5th set already . ASK brake pads were the cheapest, but it has got the best bite and lesser brake fade. Love this VFM and good brake pads. Amazon is out of stock now.
I will post more details about EBC brake pads, part number mystery etc after I get the right parts.
Cheers!
Old 10th February 2018, 14:00   #386
Dr.Naren's Avatar
I observed that only one horn was working. I took the car to service centre and they adjusted / tuned the horn. Now it is working perfectly .
Mysore to Kasaragod drive was effortless as usual. There was no steering vibration under braking. I was driving with grandparents and did not push the car this time. I got 17 kmpl .
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180210_114102.jpg
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180210_113938.jpg
Old 14th February 2018, 19:30   #387
Dr.Naren's Avatar
~5000 KM in last 1 month
S-Cross has been doing lot of highway trips now. Dad did Kasaragod - Mysore - Bangalore - Mysore - Kasaragod in last 2 days.
All meters reset before leaving home
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180211_142305.jpg
2 Adults and full boot
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180211_140728.jpg
Back Home today, Happy me
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180214_184853_hht.jpg
ODO after the trip
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180214_190521.jpg
Observations by Dad :
1. Power is too much. He says this much is not necessary, revert to stock
2. Engine braking has reduced. He did not like it while descending ghats. This has actually become more prominent with latest Wolf map.
3. Overall FE was impressive considering the driving conditions.
4. Dad was not at all tired, loved the cross over for highway cruising.
5. He is suspecting some issue with clutch cylinder / release bearing. According to him, clutch doesn't release fully. It takes some time. But this happens very occasionally. I will drive the car more and look for it.
Overall the car performed beautifully. Now it's my turn to put 1000 KM more on ODO.
Dr.Naren is offline   (11) Thanks
Old 22nd February 2018, 15:36   #388
Dr.Naren's Avatar
Update :
I drove around 100 KM today. Kasaragod to Mangalore Airport round trip. I did not notice any issue with clutch. I think dad got confused with really quick revving .
Overall FE was 16.5 KMPL. I also observed that car was less aggressive. ECU had adapted to driving style of dad . Thanks to passengers and luggage, I too dint not push the car. I need to get the ECU adapted to my driving style haha.
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180222_124206.jpg
Dr.Naren is offline   (1) Thanks
Old 23rd February 2018, 16:51   #389
Dr.Naren's Avatar
It's been few months since I had washed the car on my own. I got time today .
These were used
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180223_150226.jpg
75 percent done
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180223_161111.jpg
Before & After
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180223_150351.jpg
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180223_162738.jpg
One more pic
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img20180223wa0043.jpg
Dr.Naren is offline   (9) Thanks
Old 28th February 2018, 21:08   #390
Dr.Naren's Avatar
Temple Runs :
I had to drive with full passengers to few temples. I did not go above 80 kmph and average FE was 19.5 kmpl. The car was pulling very well and no issues with taking steep inclines.
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20180228_180532.jpg
Dr.Naren is offline   (6) Thanks
Copyright 2000 - 2021, Team-BHP.com
