Old 21st March 2019, 22:52   #541
d3mon's Avatar
Thanked: 1,801 Times
Default re: My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!
Takes off after 2000rpm and doesn't let go until close to the red line! 60-120 happens in blink. Great stuff!
d3mon is offline   (2) Thanks
Old 21st March 2019, 23:05   #542
Dr.Naren's Avatar
Thanked: 13,160 Times
Yes, it's brutal after full boost is achieved. No loss in low end is something which I did not expect and really happy about it .
Dr.Naren is offline   (5) Thanks
Old 22nd March 2019, 09:21   #543
Dr.Naren's Avatar
Few Points :
1. I have driven around 500 Kms on present Stage 3 Map.
2. Wolf had tried five Stage 3 files and the last one was the best.
3. This tune is not final. I would be getting a more powerful tune after the pending hardware mods. Wolf has also assured to work on race / drag tune .
4. S-Cross 1.6 has very tall gearing. The car revvs till 5000 RPM easily even in 3rd and 4th gears now.
5. Huge difference is seen in top end with Stage 3 Map ( 3000 to 5000 RPM ). There is good improvement in mid range and no loss at all in low end.
6. I did not notice any change in fuel efficiency. Need to do a long drive for proper analysis.
7. I have noticed that clutch slips occasionally. This happens only during 0-100 / quarter mile runs. I would blame myself here as I have launched the car hundreds of times .
8. MRF Perfinza's are holding very well. I was expecting lots of wheel spin if I floor the car in lower gears. There is nothing and what I get is only torque steer at times.
9. There is no madness or drama or violence in this tune. It doesn't feel after market at all. I don't know if all would like it. The car is quick with linear power delivery all the way till 5000 RPM.
10. I would like to thank few guys who helped me with this.
  • Rajiv from Wolf Moto for tailoring a good tune and providing great customer support.
  • Binoy from TVARA Performance for sourcing the turbo
  • Venkat from Blackworks for Turbo Installation.
  • Akshay from GT Tunerz for giving the ECU connection diagram. This helps to do remap without opening ECU. Thanks a lot man, this saved lot of time and I could test couple of maps from Wolf.
Dr.Naren is offline   (13) Thanks
Old 23rd March 2019, 21:29   #544
theredliner's Avatar
Thanked: 1,344 Times
Originally Posted by Dr.Naren View Post
40-120 KMPH in 3rd gear
The drivability looks very good for a bigger turbo. Seems to pick up well from 1750 RPM. There seems to be sufficient juice even at 1500. Just curious, is the engine completely dead now at 1000 RPM in 3rd or is it comparable to stock?
How many kms have the tyres covered? My T-Jet has tyre change coming up in the next 10k. Perfinza is a strong contender (along with the can't go wrong Michelin Primacy 4). Since tyre life is an unknown area currently, I'd watching this space. The MRFs would definitely last longer for me than what they would for you with 420 Nm .
I wouldn't be surprised if you see better FE when cruising on the highway as many owners with upgraded turbos report the same (at least on the petrols)
Did you talk to Rajiv ?
Yep, all the interactions were with the man himself.
theredliner is offline   (3) Thanks
Old 23rd March 2019, 22:00   #545
Dr.Naren's Avatar
Dead ? Not at all. The stock car would struggle and engine might also get lugged and switched off at 1000 RPM. My car still picks up from 1000 RPM .
Around 2500 Kms. Extremely happy with grip, steering feel, stability and braking.
Dr.Naren is offline   (8) Thanks
Old 25th March 2019, 10:12   #546
Dr.Naren's Avatar
50,000 KM Done
I drove around 500 km in last 24 hours, round trip to Davangere. The car was fully loaded with passengers and few bags in boot. Stage 3 setup is just effortless, perfomed very well even on ghats. Perfinza never fails to impress on curvy roads
I got 13 kmpl too, happy with it for a fully loaded car with Stage 3 tune on not straight level roads.
Missed taking pic of ODO at 50k Km
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20190325_101116.jpg
Need to get the car serviced, will do it after few days.
Dr.Naren is offline   (10) Thanks
Old 26th March 2019, 19:30   #547
Dr.Naren's Avatar
Horn Upgrade :
I got FIAMM AM80S - AM80SX installed at Auto Harbour, Manipal. It doesn't sound very loud inside the cabin , but very effective .
Video
Few Pics
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20190326_191710.jpg
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20190326_191729.jpg
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20190326_191804.jpg
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20190326_191826.jpg
Oh Yes, 200 HP S-Cross deserves better horns
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20190326_191854.jpg
Dr.Naren is offline   (6) Thanks
Old 26th March 2019, 23:28   #548
amit_mechengg's Avatar
Thanked: 2,046 Times
What are your IATs and EGTs at wide open throttle and cruising?
amit_mechengg is offline
Old 27th March 2019, 00:13   #549
Dr.Naren's Avatar
IAT is usually 10-15 degrees higher than ambient while "cruising". I noticed this is slightly better than my stock turbo.
But under WOT, it shoots up very quick ( thanks to 2 bars constant boost )..Say IAT is 40 degrees while cruising in 4 th gear , it will touch 70 degrees when I hit 5000 RPM. That reduces the power and MAF values too. Intercooler upgrade should solve this , as of now looking into intercooler cores from Garrett.
EGT : No idea !! S-Cross 1.6 doesn't have EGT sensor. Planning to install EGT sensor and Boost gauge as per recommendation by Rajiv .
Dr.Naren is offline
Old 27th March 2019, 00:22   #550
Yes a good intercooler will help with a good plumbing. When you start a stage 2/3 its better to have EGT sensor, boost (not 100% needed) and AFR(petrol cars). I had all these in place to tune perfectly without blowing out anything.
amit_mechengg is offline   (1) Thanks
Old 27th March 2019, 00:31   #551
Dr.Naren's Avatar
There's a reason why Rajiv adviced to install boost gauge. ECU doesn't give reading more than 1.55 bars (actual boost ) even though the MAP sensor is rated till 3 bars.
Our target was to hit 2 bars constant boost , but we couldn't log. Rajiv is smart , he logged MAF and checked if boost change in ECU maps are making any difference .
15.1 seconds quarter mile timing in a cross over weighing close to 1.3 tons made my day. If not I would have never believed car is doing close to 200 HP .
Dr.Naren is offline   (2) Thanks
Old 29th March 2019, 12:19   #552
Dr.Naren's Avatar
EBC Ultimax2 rear pads have arrived, bought it from KS Motorsports Mumbai. These are entry level OE replacement pads, sadly EBC doesn't have even Greenstuff for rear.
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20190329_121643.jpg
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20190329_121633.jpg
Old 3rd April 2019, 16:22   #553
Dr.Naren's Avatar
50k Kms Service Update !
What was done ?
1. Engine oil and filter change
2. Cabin filter change
3. Joint , Front stabilizer replaced ( Both sides )
4. EBC brake pads Installed ( Front & Rear )
5. Routine inspection / lubrication of various parts
6. Body wash and Interior cleaning
Total Bill : Rs. 6691
Dixcel EC pads at rear ( uneven wear ) : ~10k Kms
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20190403_155057.jpg
Dixcel ES pads at front ( almost done ) : ~6k Kms
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20190403_155038.jpg
I could have run little more on them , but the brakes were noisy at times. EBC pads were installed and no extra labour was charged as it comes under PMS.
EBC Greenstuff at Front
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20190403_155145.jpg
EBC Ultimax2 at Rear
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20190403_155131.jpg
Joint, Front Stabilizer ( New )
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img_20190403_155255.jpg
Current ODO
My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 70,000 km up!-img20190403wa0056.jpg
The engine was very smooth and silent immediately after oil change. Thanks to my high speed runs, old engine oil would have been in bad state. I will post the initial feedback on EBC brakes after 1000 Kms. Dixcel experience was just average and not at all worth the premium price. I have tried 3 different types of pads and slotted rotors from Dixcel. Rotors are good, but none of the 3 pads from Dixcel were up to the mark, all had one or other issue. Not going to try anything from Dixcel again.
The car is running without any issues with Stage 3 Wolf map. I have observed that smoke has reduced a lot after service and Reliance diesel. Clutch might give up anytime , should be ready to spend at least 20k .
Dr.Naren is offline   (7) Thanks
Old 3rd April 2019, 16:48   #554
Leoshashi's Avatar
Thanked: 31,296 Times
Sorry to say but all your issues with Dixcel point towards poor quality(pads cracking/shims melting/uneven wear). Surprisingly, you didn't face such issues with stock pads IIRC. Dixcel isn't worth the premium IMHO.
Shashi
Leoshashi is offline   (6) Thanks
Old 3rd April 2019, 17:00   #555
Dr.Naren's Avatar
Dixcel pads are advertised for performance / fast road use. The life of brake pads purely depends on driving and Yes, i usually get lesser life when it comes to brake pads.
My take on Dixcel products :
Dixcel Extra Speed pads : Satisfactory, these pads are advertised for fast road use and high temperature resistance. The shims just melted and the reasoning by Dixcel is they are made of rubber and would melt at high temperatures.
Dixcel Extra Cruise pads : I have used them at rear. Surprised by the uneven wear. Maruti suspected brake system and everything was good. Do note that OE pads lasted for good 40k kms in same car before.
Dixcel M type pads : These were the costliest pads I ever tried and they were the worst, just horrible. It lasted only 2500 Kms.
Dixcel SD Slotted Rotors : I hope they are good. Not faced any issues till date. I have spent more than 30k on these rotors .
Copyright 2000 - 2021, Team-BHP.com
