Old 4th August 2019, 13:21   #586
Dr.Naren's Avatar
Thanked: 16,915 Times
re: My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 5 years & 72,000 km up!
Since when did you start using this, I mean from what reading on the odometer?
I have not used Cetane X regularly, may be 3 or 4 times. Engine used to revv smoothly .
One more question - Does the S-Cross 1.6 come with a DPF?
No DPF in S-Cross 1.6
I know that you have a down pipe now, so the question is whether you noticed any difference in black smoke levels under heavy load WOT runs post down pipe fitment?
I have not noticed any difference in smoke levels after decat downpipe.
After my second map update, I was asked to monitor black smoke but my worry is that since mine has a DPF, will I ever get to see any black smoke at all, even if it gets generated out of the engine.
Are you sure that Verna 1.6 CRDI has DPF ?
Dr.Naren is offline   (1) Thanks
Old 4th August 2019, 13:40   #587
clevermax's Avatar
Thanked: 2,640 Times
Thanks. I think the so called 'NextGen' models come with a DPF. To confirm this, I asked one sr. service Engineer in the dealership and he said they do come with a DPF. Upon inspecting the engine bay, I saw this big cylindrical unit which looks like a DPF.
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-c0f01043db2f4503b9736edda7a08b73.jpg
clevermax is offline   (1) Thanks
Old 4th August 2019, 14:00   #588
Dr.Naren's Avatar
That big cylindrical unit is Catalytic converter and A/F sensor . I highly doubt your car has DPF. Do check if there are more sensors, DPF should have pressure sensors.
Dr.Naren is offline   (4) Thanks
Old 5th August 2019, 12:06   #589
clevermax's Avatar
You're right, it is just the Catalytic converter I suppose. Since I had seen this diagram below, I had a doubt whether the unit is a shared housing which hosts the cat and the DPF. Then the service engineer's response added to the confusion. However, there are no more sensors I can see on it, which suggests that it is the cat alone.
[Courtesy:https://www.greencarcongress.com/201...921-vw2l.html]
I logged DPF parameters like pressure & temperature, and they are stuck at max & min values respectively all the time. (10000 psi and -40 degrees C). This reaffirms.
Good to know that there's no DPF, now let me add 15bhp to the perceived horsepower, LOL
Old 5th August 2019, 23:15   #590
Dr.Naren's Avatar
Yes, it's just the Cat
Get a decat downpipe and ask Rajiv to increase the power further
Old 7th August 2019, 16:37   #591
Dr.Naren's Avatar
The paint on alloy wheel caps had chipped off. Leoshashi advised me to get black wheel caps, it's available as MGP part. I ordered the same from Boodmo .
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20190807wa0025.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20190807wa0026.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20190807wa0027.jpg
Dr.Naren is offline   (6) Thanks
Old 16th August 2019, 20:04   #592
Dr.Naren's Avatar
FIAMM Horn stopped working:
I noticed that only one horn was working. I got it checked at the same place where I installed them ( Auto Harbour Udupi ). They fixed it quickly and said it was a loose connection.
New Modified Rear Suspension Beam:
The part has finally arrived at service center after a long wait. Warranty approval is also done, will get it fixed this sunday
Dr.Naren is offline
Old 17th August 2019, 18:27   #593
Dr.Naren's Avatar
I got the rear suspension beam replaced under warranty. It costs around 15k.
Old Beam (Part is discontinued now)
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20190817wa0024.jpg
New beam
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20190817wa0023.jpg
Installed
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img20190817wa0028.jpg
I will get the alignment checked again at same tyre shop. Hope the rear alignment is good now
Dr.Naren is offline   (7) Thanks
Old 30th August 2019, 07:57   #594
Thanked: 281 Times
I am very happy with Cetane-X. The performance has further improved. Engine noise at idling is much lesser now.
Sir, I've purchased Cetane-X from the link shared in your post above. I've a quick question re the usage. My car has 55 litres tank capacity, the seller suggested me to use 300ML. However, on the bottle it says 100ml for 50 litres. Not sure to add 300ML or 100ML. Any help on this please?
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-20190830_075141.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-20190830_075854.jpg
atulsian is offline   (1) Thanks
Old 30th August 2019, 13:08   #595
Dr.Naren's Avatar
Do get it clarified again from the seller. They recommend double quantity for tuned cars.
Old 7th September 2019, 19:45   #596
Dr.Naren's Avatar
Originally Posted by raystriker View Post
How bad is the torque steer? Ever feel the car want to rip the steering from you?
Replying here as it would be off topic on the thread you asked .
There is torque steer but it's mild. Wolf has made the map very linear with progressive and strong power delivery. There is no mad rush of power, but the car is very quick. 0-100 in less than 7 seconds .
Dr.Naren is offline   (3) Thanks
Old 11th September 2019, 23:20   #597
Dr.Naren's Avatar
OE clutch of S-Cross 1.6 is same as the one used in 2.0 MJD cars like Jeep Compass. No wonder the clutch is quite strong and handled all my 0-100 launches .
It's made by Valeo. The clutch is working fine under normal driving, but there is mild slipping in first n second gears when I shift aggressively at high RPM. OE clutch kit costs around 11k from Maruti.
I am thinking to upgrade with Sachs Clutch kit. It's supposed to handle 15 percentage more torque. The price is more then double compared to OE Valeo. Planning to get through friends / relatives who would be coming from Europe. Boodmo has the same part listed for around 30k. But, I am not sure if I would really get it .
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20190911_230907.jpg
https://www.sachsperformance.com/en/...h-3000950643-s
My friend with Stage 3 S-Cross 1.6 has done intercooler upgrade and there is massive drop in IAT. I need to get that done too.
I believe the gearbox used in S-Cross 1.6 is also same as the one in Jeep Compass, i.e Fiat C635. Once I confirm this, I shall order short shifter from 4H-Tech.
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-4htechgshiftshortshifterkitforthealfarom.jpg
https://www.short-shifters.com/g-shi...ifter-kit.html
Hope to get all these upgrades done by end of this year!
Old 13th September 2019, 09:58   #598
Thanked: 24 Times
May I ask what made you change the rear suspension beam?
djkher is offline
Old 13th September 2019, 10:16   #599
Dr.Naren's Avatar
Originally Posted by djkher View Post
The rear alignment was out of specs and it's fixed. Hence, I got the new beam. It's a modified beam by Maruti, the old beam is no more in production.
Dr.Naren is offline
Old 13th September 2019, 10:20   #600
Thanked: 24 Times
Is this something other pre-facelift S-cross owners should also be concerned about? Mine is a 2016 one
djkher is offline
