Old 28th February 2018, 21:29   #391
ike
ike's Avatar
Thanked: 1,711 Times
re: My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf (~200 HP / 420 NM). EDIT : 5 years & 72,000 km up!
I did a temple run too, Chennai - Srirangam - Rameswaram - Madurai - Thrissur - Chennai. The roads were poor between Srirangam & Rameswaram.
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180219_071807.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180217_174908_677.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-20180218_133530.jpg
ike is offline   (4) Thanks
Old 1st March 2018, 22:49   #392
Dr.Naren's Avatar
Thanked: 16,915 Times
The car has been doing multiple short trips since last few days. Uncle and family had come from USA, I was their official driver .
My Uncle was very impressed with S-Cross. He appreciated the AC, ride quality, loaded with features etc. The car took all bad roads effortlessly, even with full load. I had never gone above 90 kmph and FE was very very impressive. I got close to 20 kmpl today.
Cross-Over resting at my grandparents home (in the midst of forest)
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180301_172901.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180301_181511.jpg
Dr.Naren is online now   (12) Thanks
Old 4th March 2018, 12:30   #393
Dr.Naren's Avatar
I have driven around 15k KM with Continental MC5 tyres. The front tyres have only 1.5 mm tread left before TWI mark. It is not due to my driving style this time, the tyres were not rotated .
Front tyres :
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180304_111703.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180304_112054.jpg
Rear tyre :
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180304_112303.jpg
Yes, 50 percent more tread than front. I will rotate the tyres now and hopefully run 10k km more. 25k km total life is good for me haha.
I also noticed this needle on rear left tyre, there was no leak. I removed it and started leaking. Tyre shops were not open today in my place.
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180304_112353.jpg
Dr.Naren is online now   (3) Thanks
Old 13th March 2018, 13:18   #394
Dr.Naren's Avatar
35000 KM Done!
I have run more than 35k km now. S-Cross has been doing what it is really good at, highway cruising. I drove around 635 km yesterday. Mysore - >Bangalore Airport - > E City - >Mysore - > Kasaragod. The drive was brilliant. I got very good FE too, 16.7 kmpl.
The puncture was fixed with hot patch (Rs. 500)
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180313_130311.jpg
There was no pressure drop, hope it stays this way.
Current ODO and Average FE of the trip
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180313_130523.jpg
My 5 th set of brake pads are also done now . I have also observed scratches on brake discs. It would take few more days to get EBC Green stuff from UK. My plan is to get new OE discs and install EBC brake pads.
Dr.Naren is online now   (4) Thanks
Old 13th March 2018, 14:28   #395
tharian's Avatar
Thanked: 8,039 Times
Since the puncture is on the edge, I would keep it as my spare. Even with the hot patch, I won't trust that tyre at high speeds.
I am not sure how much more better the patch is over the regular rubber strip fix.
tharian is online now   (5) Thanks
Old 13th March 2018, 15:05   #396
Dr.Naren's Avatar
The puncture is not actually on sidewall. It is on shoulder. It was fixed with plug from outside. That did not work and started leaking again. Hot patch looks good so far. The car was behaving little weird with one Elanzo and 3 MC5's . I have also reduced my top speed by 50 percentage now .
Dr.Naren is online now   (2) Thanks
Old 13th March 2018, 20:01   #397
Thanked: 9,054 Times
So you are traveling at 100KPH now?
Sankar is offline   (3) Thanks
Old 13th March 2018, 20:06   #398
Dr.Naren's Avatar
Haha. I hardly go above 110 kmph these days. I had been driving around with family since last couple of weeks. I am getting much better FE too .
Problems :
1. Brake discs : lot of scratches, uneven surface (I can't skim them again)
2. Brake pads : They are done, I was getting sound from wear indicator.
3. One not so safe tyre (fixed with hot patch)
Due to some sudden change of plans, I am supposed to drive around 500 KM. It is not possible with problems 1 and 2. EBC brake pads would take few more days. I made a quick visit to MGP store and picked up brake discs and pads. I got brake pads of SX4 and saved 750 bucks. S-Cross and SX4 have same pads, but Maruti charges premium for Nexa customers.
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180313_195628.jpg
These will be installed tomorrow.
Problem 3 : I have got an interesting solution. I am not using spare Elanzo. Stay Tuned
Old 13th March 2018, 20:11   #399
Be safe. One of my michelins got a superficial cut on the sidewall, no threads are exposed and there is no air leak either. But i have made it the spare. Just can't trust a fixed or damaged tyre with the kind of driving we do.
Sankar is offline   (5) Thanks
Old 14th March 2018, 08:06   #400
Nikhilb2008's Avatar
Thanked: 10,138 Times
Naren, I told you on FB and I'll tell you again. Dont start quoting technicalities (not sidewall, shoulder, etc) to defend this practice of running with a damaged tyre.
It could give way anytime. The shoulder too flexes a fair amount (proof in the fact that a normal puncture didnt hold).
Doesnt matter if you're doing *only* 110. A tyre deflation at even 80 can be fatal.
Dont try to be penny wise pound foolish. Buy a brand new tyre and then when you change the others, keep this brand new tyre as a spare and use 4 brand new tyres on the car.
Nikhilb2008 is offline   (13) Thanks
Old 14th March 2018, 08:53   #401
Sheel's Avatar
Thanked: 14,404 Times
That tire flex...I went too hot in a corner and I could literally feel my all terrains getting all squishy and flexing [one side] under full load after the suspension travel. So, yes, will agree with Sankar & Nikhil on this
Sheel is offline   (1) Thanks
Old 14th March 2018, 09:06   #402
Dr.Naren's Avatar
Correct. I had put this repaired tyre as spare. As mentioned before the car was behaving weird with one Elanzo . This made me try use the repaired tyre.
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-screenshot_20180314084428709_com.whatsapp.png
I liked this look without alloys!
As mentioned in previous post of mine, the car will not be running on repaired tyre or spare Elanzo .
Old 14th March 2018, 14:26   #403
Dr.Naren's Avatar
Quick Visit to Maruti Service :
Spares were not available in my regular service center. I had driven to Mangalore and picked up discs and pads from MGP store yesterday. I got them installed today at service centre. They charged around 350 as labour.
Brake pads : MGP (Rane)
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180314_094913.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180314_094830.jpg
Brake discs : MGP
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180314_094653.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180314_094851.jpg
The quality looks better now. I don't remember seeing this black paint / coating on old OE discs.
New brake discs and pads installed
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180314_111831.jpg
Service manager is always enthusiastic to sell some new stuff to me . Picked up this car perfume. It is imported from Poland and costs Rs. 200.
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180314_125146.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180314_124933.jpg
I also got the car washed. It was quite expensive, close to Rs. 500. The washing charge for S-Cross is higher. There is no labour code for only body wash like other Maruti cars. It says washing and cleaning.
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180314_133659.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180314_133714.jpg
The experience at service centre was good. Staff are friendly and I know almost everyone there.
What Next?
An interesting but funny project haha.
This will cost zero damage to my pocket, improve the safety (the damaged MC5 will be out), new looks to my car too. Till now nobody could guess what it is
Dr.Naren is online now   (9) Thanks
Old 14th March 2018, 15:33   #404
Thanked: 4,876 Times
I guess you are swapping the tyres of your SX4 and S-Cross.
romeomidhun is offline   (3) Thanks
Old 14th March 2018, 16:10   #405
Dr.Naren's Avatar
You are right .
It took some time to swap. Dad helped me with this. SX4 has 205/60 R16 Falken tyres and they have more than 70 percent tread left. My SX4 is not even used, gearbox synchro has gone kaput again. This will be fixed only after few months.
The outcome has exceeded my expectations. Both the cars are looking nice .
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180314_155708.jpg
My Maruti S-Cross 1.6L Alpha | Stage 3 Wolf (202 HP / 438 Nm) | EDIT : Sold - Pg 61-img_20180314_155523.jpg
SX4 and S-Cross are siblings. Most of the parts are shared. The tyre specs are same too. I can drive peacefully in my S-Cross now. It just took little time and energy, totally worth it!
Dr.Naren is online now   (13) Thanks
