Old 24th April 2018, 18:47   #61
catchdoon's Avatar
Thanked: 116 Times
re: Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!
Congratulations Sir on the Creta.
Fog lamps are stock. There's nothing good available to upgrade to.
It is the headlight bulbs that I have upgraded to Phillips Xtreme Vision.
Technical specifications are in Post No. 5 of this thread.
Thanks a lot for the prompt response. Your DIY effect - Just got myself new LEDs which would replace the OE Festoon ones.
Cheers!
PS: I might bug you every now & then to understand couple of things which I might not be able to on my own.
Edit: Since I'm a Newbie here, I can't PM. Would you mind?
catchdoon is offline   (1) Thanks
Old 24th April 2018, 23:46   #62
Thanked: 21,411 Times
Great. I'll be more than happy to be of any help.
Check your inbox. I have sent you a PM via email.
Old 25th April 2018, 19:31   #63
catchdoon's Avatar
Thanked: 116 Times
We're in Sync. Thanks for being so helpful & prompt. It would help a great deal to have your share of knowledge
Old 25th April 2018, 23:23   #64
UPDATES UPDATES
ODOMETER: 20,000 kms
DURATION: 6 months
Since the odometer was nearing 20,000 kms, decided to get the 3rd Free Service done. Called up my SA and informed him that I'll be at the ASC by 9 am so I can get the car by 12 pm. Dropped the car off and asked for the following to be done.
  1. Engine Oil change
  2. Engine Air filter change
  3. Engine oil filter change
  4. AC Filter change
  5. Fuel Filter change
Off all these my request was to switch to synthetic oil from Shell (5W40 grade) but they were out of stock and if I was adamant on that being used in this service then I would need to wait for 7-8 days till stocks are replenished. Decided to postpone the switch and filled regular mineral oil).
Instructions given before handing the car:
  • No washing
  • No Stickers to put anywhere on the car
  • No wheel wheel balancing, alignment etc
  • No use of dashboard polish anywhere on the car
  • Also explained and made aware the SA on the SensAiry TPMS sensors and valve caps so they aren't stolen
Odometer at the time of servicing
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180424_114635.jpg
Car ready post service
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180424_183409.jpg
Service History updated in the Hyundai Care App
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-screenshot_20180424165826.jpg
10,000 kms Service Bill
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-10k.jpg
20,000 kms Service Bill
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-20k.jpg
20,000 kms done
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180425_193024.jpg
MODIFICATION #17: DIY Install of Rear Dashcam - DDPai Mini WiFi (1080P FHD)
Got the dashcam delivered in 19 days through Singapore Post. NO customs duty charge this time. Had $5 coupon so used it and paid ₹ 4,228 with Hard wiring Kit
Declaration on the package. Lucky to escape the customs duty charges
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-2.-declaration.jpg
Camera Package with Hardwiring Kit
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-3.-package-hw-kit.jpg
DDPai Mini Package Contents
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-4.-ddpai-mini-package-contents.jpg
Hardwiring Kit contents
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-5.-hardwiring-kit-contents.jpg
Specifications of the Camera
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-6.-specifications.jpg
The Camera
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-7.-camera.jpg
Memory Card slot; Reset button above the memory card slot
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-8.-memory-card-slot.jpg
Required URL's
DDPai Mini Website
Purchase link for the dashcam (AliExpress)
Next post will contain installation images and output shots
PS: Apologies for the back-to-back posts as 30 images per post limit requires me to split it into two. Do merge the same if required.
a4anurag is offline   (3) Thanks
Old 25th April 2018, 23:54   #65
Continued...
1. Installation Images
Camera mounted on the HMSL Cover
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-1.-cam-fixed-hmsl-cover.jpg
View from distance of the camera mounted on the HMSL cover
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-2.-view-cam-mounted-hmsl-cover-distance.jpg
Wiring path from HMSL location to the fuse box (See Yellow line, apologies for the amateur way of marking the path)
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-3.-wiring-path.jpg
Wiring coming out from the top of the boot lid beading
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-4.-wire-coming-side-top.jpg
Wired and secured
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-5.-wired-secured.jpg
Wiring passed along the existing wiring
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-6.-wiring-passed-along-existing-wiring.jpg
Crash panel under steering wheel removed
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-7.-cover-removed.jpg
Connectors un-plugged (Yellow Circle - Traction control + Illumination Control; Orange Circle - Head lamp levelling switch)
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-8.-connectors-unplugged.jpg
View of the Cam from outside
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-9.-view-cam-outside.jpg
Close-up view from outside
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-10.-close-up-view-outside.jpg
Battery inside the Remote Button
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-11.-battery-remote.jpg
Remote mounted
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-12.-remote-mounted.jpg
Light when the camera is ON
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-13.-light-when-cam-.jpg
Found this cute little stamp of Hyundai logo while working today
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-img_20180425_164446.jpg
2. Firmware Update
Link for the DDPai App from Play Store
Firmware Update sequence and steps involved (it does all on its own). Takes 7-8 minutes depending on size of the update and internet connection speed
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-firmware-update.jpg
Version of the Firmware and Camera
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-screenshot_20180425184543.jpg
A few settings in the DDPai App
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-screenshot_20180425184654.jpg
3. Output shots from the Camera
Image taken just after completing the output
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-1.-just-after-completing-install.jpg
Day time - Sun behind the camera
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-2.-day-time-sun-behind-cam.jpg
Day time - Sun facing the camera
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-3.-day-time-sun-facing-cam.jpg
At a toll booth
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-4.-toll-booth.jpg
Night time - Brakes pressed
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-5.-night-time-brakes-pressed.jpg
On a highway, vehicles tailing
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-6.-highway-vehicles-tailing.jpg
High beam follower (it's a Maruti Baleno Alpha with HID's)
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-7.-high-beam-baleno-alpha.jpg
In traffic
Hyundai Creta 1.6L CRDi SX(O) - An Ownership Log - Update: 1,00,000 km up!-8.-traffic.jpg
Video Sample
a4anurag is offline   (14) Thanks
Old 26th April 2018, 00:04   #66
catchdoon's Avatar
Thanked: 116 Times
Subscribed to MRF STAMP (Special Tyre Care Annual Maintenance Package) for ₹2,375 for Hyundai Creta as per their website. Here's the thread link
MRF STAMP (MRF Stamp: Annual Maintenance Program for tyres)
Apparently, they don't serve in Mumbai! I can't believe this. Any alternative to this in Mumbai/Navi Mumbai?
UPDATES UPDATES
DURATION: 6 months
Hello Anurag,
I saw your previous & this servicing details but apparently I didn't see you getting your tyres rotated.
It's so good that HMIL provides the spare tyre w/ the same specification - 215/60 R17 - So it would be easier to rotate & since the tyres aren't directional, the issue of RHT & LHT wouldn't come into picture & all 5 tyres can come into play.
So, you don't get your tyres rotated or do you? If you do, I'd like to know the rotational scheme you follow.
PS: I apologize if I missed it in your post somewhere.
Last edited by GTO : 7th May 2018 at 09:43. Reason: Please quote ONLY the relevant bits of a post. Quoting a full, long post inconveniences our mobile readers. Thanks!
Old 26th April 2018, 08:50   #67
No idea if such services exist in Mumbai.
But the scheme of MRF STAMP is applicable I think only on Andhra Pradesh, Telangana and Karnataka.
I do all the wheel alignment, balancing and rotation at MRF T&S. I'll prefer them over ASC both in terms of pricing and work satisfaction.
I do get the Wheel alignment, balancing and Rotation done at MRF every 5,000 kms.
I follow the 4 tyre rotation method as given in the manual.
Old 26th April 2018, 09:21   #68
catchdoon's Avatar
Thanked: 116 Times
I just checked & found that they have only a handful of SC. Below are the list of Cities it serves as on date.
Noted. But don't you think that after couple of years the spare would not really be of that great use, provided the rubber would get old.
Isn't it wise to get the 5th Tyre into regular rotation?
Old 26th April 2018, 09:28   #69
Fully agree with the point.
I'm getting a 5th alloy for the spare wheel after which I'll follow the 5 tyre rotation.
a4anurag is offline
Old 26th April 2018, 10:15   #70
catchdoon's Avatar
Thanked: 116 Times
Are you getting Stock Alloy? (Else you'd need to change all 5)
If yes, then from HMIL?
When you get one do post the details.
I'm myself eyeing to get the Stock Alloy for the spare - My Pegasus has already clocked 3.7k & I plan to introduce the spare during the 5K rotation.
Old 26th April 2018, 10:35   #71
Stock alloy only. I'll update once I get the alloy.
Cost is the main factor that's delaying the purchase. It is an eye-watering ₹ 17,455 per alloy.
a4anurag is offline
Old 26th April 2018, 10:54   #72
catchdoon's Avatar
Thanked: 116 Times
Are you kidding me?
I just had a word w/ my HMIL advisor & he quoted INR 11,500 per alloy.
Would you recheck with the HMIL advisor?
Old 26th April 2018, 12:02   #73
Dr.Naren's Avatar
Thanked: 16,915 Times
That's too expensive . I am sure you would be able to get this for much cheaper from alloy wheel shops or OLX. I see lot of Creta's with after market alloys.
Dr.Naren is offline
Old 26th April 2018, 13:25   #74
Are you kidding me?
Enquired at 3 dealerships for the 17" alloy. Two of them quoted ₹17,866 and 1 dealer quoted ₹14,999. Pricing looks to be dealership dependant.
Have shot an email to Hyundai Customer care for a better and clear response on the issue.
a4anurag is offline
Old 26th April 2018, 13:40   #75
catchdoon's Avatar
Thanked: 116 Times
Cool! Keep me posted with the response from HMIL.
Hope this would give a transparent pricing.
