Originally Posted by shelby GT congrats for your 100k mark, and need to say it is a incredible effort to log all those in such a manner. really appreciate the effort you have put for this. |
@shelby : Midnight black, a/c issues, one-time green fluid leak etc. Sounds almost like my Baleno, just that mine is 2005 and crossed 1 lakh on the odometer.
Inspite of being from Kerala, I haven't ever been to Kannur (will change that soon) so ofcourse no idea of good mechanics there. Do check up the team-bhp directory - maybe someone has put up details of a garage in your vicinity.
Coming to the issues, will share what info I have from my car experience :
1.
A/c : Recently I have had a host of issues with the a/c and spent around 10K or more & lot of time. Its working great now and I hope it stays that way. I don't think I had the issue you mentioned, but hope you checked for any gas leakage etc in the pipelines. Don't know if it will help, but do check out the a/c issues I had.
2.
RPM fluctuations : There has always been some rpm change when the thermostat kicks in after the cabin has cooled. Eg while waiting at a signal, if without a/c on, the car will always idle at around 750rpm. But if a/c is on, it will go 1000-1100 rpm and when thermostat kicks in, come down to 750rpm. And this cycle repeats.
Is this what you see ?
3.
We faced some incidents.... :
Did you check where the engine temp needle was at ? Any signs of overheating ?
When engine temp is higher than normal (overheating, due to low/no coolant or fan not working), the ECU will reduce load by cutting of a/c. So even if you miss the temp-gauge, the a/c not working is a signal.
4.
Suspension : Need to get it checked to know what exactly. I had a thud sound on small potholes on left side. Turned out the lower arm was damaged - replaced it.
5.
Green fluid leak : I also had it once, but never after that. Do check coolant level. As in my case, one of the pipes had a minute puncture, which wont leak in short runs, but on long runs when temp/pressure builds up, it was leaking. Check for such cases.
Like you, I also sometimes think of replacing her, but the fun of driving it makes me change my mind.
Originally Posted by CrAzY dRiVeR 1L mark is always special! Congrats!
The service details and log is really meticulous indeed! I used to visit Ignite during the 2011 - 2012 period when I was in Chennai and had my WagonR. Did their service quality come down recently, or Gulf Auto is an even better choice nowadays? |
Thanks CrazyDriver !!! Nothing wrong with Ignite's service, just that the car has been at Kerala for couple years now & hence get it serviced at Gulf Auto.
