![]() | #901 | ||
BHPian ![]() Join Date: May 2014 Location: New Delhi
Thanked: 105 Times
| ![]() Quote:
I will PM you in case I need any help post my searching for reliable mechanic here. Thanks a ton once again. Last edited by Jaggu : 17th November 2016 at 10:03. Reason: Back to back posts, please use Multi Quote or Edit original post. Thanks. | ||
![]() | #902 | |
Distinguished - BHPian ![]() ![]() | ![]() Quote:
![]() | #903 | |
BHPian ![]() Join Date: Jul 2008 Location: Delhi NCR
Thanked: 309 Times
| ![]() Quote:
Congrats Manu! Could you pls PM me your number or share your number so that I can call you? Needed some local info on the GV! | |
![]() | #904 | |
Thanked: 105 Times
| ![]() Quote:
Here is the vehicle details; I believe you need some of this to accurately identify the part numbers. Model -: 2.0 AT, Nov 2007 Thanks. Last edited by mobike008 : 18th November 2016 at 14:18. Reason: Now that your work is over. Removing the part numbers :) | |
![]() | #905 | |
![]() Posting the part numbers for 2.0L Grand Vitara AT. Steering column ![]() Steering unit ![]() Power Steering pump ![]() Do let me know which part numbers you are interested in. I'll give u the part prices. ![]() Regards, Shashi Last edited by mobike008 : 18th November 2016 at 14:19. Reason: Excluding the part numbers as info is shared :) | |
![]() | #906 |
Newbie Join Date: Oct 2009 Location: Gurgaon
Thanked: 35 Times
| ![]() Dear Senior BHP-ians, I would really need help in evaluating the GV available for sale here in Delhi. Any inputs would really be appreciated. Its a MT(2.4) 2007 model & has clocked 78000 kms,2nd owner and is asking in proximity of 4.75. The bumpers have been painted and the car has everything working. Kindly help..!! |
![]() | #907 |
Team-BHP Support ![]() ![]() | ![]() The 2.4L version became available only in July 2009. So they are trying to fool you. Walk away... |
![]() | #908 |
Thanked: 105 Times
Thank you very much for sharing this Shashi. And I regret the late response as I was traveling. I believe the part needed is first one in the attached list, steering column assembly. I am not sure if the pump is needed or not. |
![]() | #909 | |
Thanked: 105 Times
| ![]() Mods, I hope this doesnt violate any policy ![]() Quote:
If you are intersted in purchasing a Grand Vitara, here are the details of my vehicle on Olx listing ; I am in the process of posting it on Team Bhp classifieds as well (ad is submitted, pending review) https://www.olx.in/item/grand-vitara...tml#84d271d068 I am moving to US for an assignment for long term. Hence, I need to sell my Grand Vitara and Santro. Both the cars are Delhi registered and are currently in Hyderabad. Both the cars were transported to Hyderabad one year back when we moved here from Delhi. Last edited by Jaggu : 12th December 2016 at 12:34. Reason: Fixing Quotes. Thanks | |
![]() | #910 | |
![]() Regards, Shashi | |
![]() | #911 |
Senior - BHPian ![]() Join Date: Sep 2004 Location: Bangalore
Thanked: 3,469 Times
| ![]() Guys, Is the good old Grand Vitara gone for good from the India market? I, for one, am a big fan and would want to buy one in the near future, if available. Am unable to get any concrete answers from dealers, despite the MSIL website proudly listing out its capabilities - here. Cheers... |
![]() | #912 |
Distinguished - BHPian ![]() ![]() Join Date: Feb 2006 Location: NSEW
Thanked: 15,974 Times
| ![]() I noticed the Transmission Warning Light on my GV when I started the car 2 days back. This is a yellow light in the shape of a wheel that comes on for 2 seconds when the ignition is turned on , but disappears thereafter if all is well. ![]() Initial Observations The car was driving perfect , as though there was nothing wrong leading me to presume this was a momentary fault. No abnormality was seen on the wiring bunch under the car. Scanning A diagnostic scan showed error P2764 - Torque Convertor Clutch Circuit Low Voltage. ![]() Erasing the trouble code made the warning light disappear , but then reappear after 2 seconds. Diagnosis 1.Browsed the net to look for specific information on this DTC related to the Grand Vitara and found that there is a procedure to check this error. 2.The procedure required removal of the Transmission Control Module(TCM) located just to the left of the AC filter housing and check for continuity of the green-yellow wire. ![]() 3.Instead of removing the TCM , I just inspected the wiring and traced its path out into the engine bay and to my horror , find that there has been a rat attack ![]() ![]() Rectification 1.Removed the battery 2.Removed the main fuse holders next to the battery 3.Split the wiring harness sleeve open to inspect for damage - and here's where I found that the green-yellow wire was gnawed at at 2 places. ![]() 4.Inspected the rest of the wiring and found that insulation on two other wires had been chewed off. 5.Redid the wiring with equivalent colour wiring 6.Restored the wiring sleeve back to normal Test Run 1.Performed a throttle body reset and ran the car for approx. 2 kms to help the TCM get fresh data on the transmission from a new driving cycle , but the warning light remained. 2. Disconnected the battery negative for approx. 15 mins and then reconnected. 3.Performed a throttle body reset , and as soon as the ignition was turned on , the warning light disappeared after 2 seconds. MODS : 1.I haven't created a new thread for this and hence have posted this in a GV LT review for reference for GV AT owners. 2.Please help fix the pictures. |
![]() | #913 |
| ![]() My GV reached a very special number this morning. I haven't driven the car much in my period of ownership , but the driving and ownership experience has been truly exhilarating. ![]() |
![]() | #914 | |
BHPian Join Date: Sep 2010 Location: Pune
Thanked: 1,318 Times
| ![]() Quote:
I am looking at overhauling the complete suspension by changing only the bushes. My MASS is reluctant to do only bushing refitting and so I may get it done outside. I need the parts nos of replacement bushings of the following:- 1. Bushings of Front Lower Arm 2. Bushings of Rear Trailing Rod 3. Bushings of Rear Control Rod 4. Bushings of Rear Lower Arm 5. Bushings of of rear Upper Arm 6. Mounting Bushings for Rear Suspension Frame (4 nos) Thanks Sridhar V | |
![]() | #915 | |
EDIT- Sorry Sir for my negligence, noticed the variant on your signature just now. Another issue is that I am used to seeing the lesser cars with simple setups. My head is literally spinning after seeing the sheer complexity of the suspension setup of Grand Vitara. ![]() ![]() Front Suspension(Click to ZOOM) ![]() Front stabiliser(Click to ZOOM) ![]() Front suspension frame(Click to ZOOM) ![]() Rear suspension(Click to ZOOM) ![]() Rear suspension(Click to ZOOM) ![]() Rear suspension frame(Click to ZOOM) ![]() Do let me know if you need any more details. Regards, Shashi Last edited by Leoshashi : 18th January 2017 at 15:01. Reason: Merging two posts to avoid back to back posts | |
