![]() | #1396 | |
Distinguished - BHPian ![]() ![]() Join Date: Jan 2008 Location: Gurgaon
Thanked: 3,121 Times
| ![]() Quote:
Last edited by Samurai : 5th April 2019 at 09:38. Reason: Adding context to the question. | |
![]() | #1397 |
Team-BHP Support ![]() ![]() Join Date: May 2004 Location: Bangalore
Thanked: 13,913 Times
This was specially ordered through a friend for two of us. Yes I have also fitted the same in my GV and it is awesome ![]() Instal news app to catch up on news while stuck in traffic. Just loving it. Cost wise I am guessing with proper import and GST bill ~25k landed in India, maybe little lesser. Will check with the friend and update. Edit: Adding some images of how the reverse cam image is and the minimal window of google map with the app update. ![]() ![]() ![]() ![]() ![]() Last edited by Jaggu : 5th April 2019 at 13:43. |
![]() | #1398 |
BHPian ![]() Join Date: Mar 2008 Location: New Delhi
Thanked: 451 Times
Sudev Ji This can be ordered through AliExpress too : https://www.aliexpress.com/item/Andr...60432e0eGcfyX8 I for one have a Phisung E06 rear view mirror mounted unit which has front and rear cameras, 4G Sim Slot for hotspot, remote monitoring and tracking in addtion to all that this one does. That costed me about about $ 110 on Ali-Express : Styler |
![]() | #1399 |
BHPian Join Date: Sep 2010 Location: Pune
Thanked: 1,318 Times
| ![]() Over the past 1 year I have consciously tried to minimise use of Google maps for the following reasons:- 1. You start loosing your conventional navigation skills as also a sense of direction. 2. Google maps nowadays tries to take you on the shortest route. If you do not know the city you are driving in it is actually a problem. And invariably it takes you through extremely small lanes and Jhuggi Jhopdis. Just to save a minute or two at some traffic light. That is a big problem in a large vehicle like the Grand Vitara. 3. If one is returning to the hotel at a different time it selects a different "so called optimal" route. Now that is a bit of a bother in a strange city, with heavy traffic, as one at least has some idea of the previous route. I am also looking to upgrade my existing 1 Din head unit to a double din one. The requirement is for ease of handling music playback. Some of the units I have shortlisted are: https://www.aliexpress.com/store/pro...79913eadBvmTsr https://www.aliexpress.com/item/IPS-...312a2e0eXd8bcD https://www.aliexpress.com/item/Euna...312a2e0eXd8bcD My primary requirement is that there should be a SD Card slot in the front panel itself. And a good audio amp chip in the circuit. |
![]() | #1400 |
BHPian ![]() Join Date: Oct 2007 Location: Shorapur
Thanked: 65 Times
| ![]() Hello guys, Can anyone please tell me what's average life of clutch and pressure plates on an automatic grand vitara. Mine is a 2007 model run about 100 thousand kms and do I need to check for the wear and tear of the clutch and pressure plates...... |
![]() | #1401 |
BHPian ![]() Join Date: Apr 2009 Location: Bangalore/Naini
Thanked: 216 Times
| ![]() I have been using this head unit for 3 years and has been issue less. Runs on Windows CE , not as dynamic as an android unit and still does the job well. Navigation supported by Map my India , has a sd card slot at front which I am using for navigation maps though can be used to load music , video files as well. Built in memory of 128 MB for music ![]() Full connectivity with steering wheel control, look and feel like a OEM unit. |
![]() | #1402 |
Team-BHP Support ![]() ![]() | ![]()
I have the same one since 5 years. It is long in the tooth, quite buggy too. Maps are old and not nearly as good as Google. |
![]() | #1403 | |
Thanked: 216 Times
| ![]() Quote:
I have not faced any issue with this unit and have been a charm without any bugs. As, for the maps it cannot do an OTA hence i always update the MMI sd card every 6 months. You need to pay a small amount to MMI to be able to download and save it on the sd. No doubt about Google maps being better. They are the best! I have an android in another car which works very well with a drawback being that Android OS cannot be updated, which has been verified by the chinese manufacturer I purchased it from on alibaba. | |
![]() | #1404 | |
| ![]() Quote:
1. Has the AT box oil been changed previously? 2. Do you get jerky gear shifts, particularly up-shifts from 1 to 2 or down-shifts from 4 to 3? A. If oil has never been changed get it changed asap. A typical oil change will need 3 litres of AT synthetic oil. After 6 months and a minimum of 2k kms running repeat the oil change. B. If oil change has been done previously then change the oil once only. C. If you are facing jerky shifts do the following:- i). Add a transmission cleaning fluid after the first oil change. I used the following:- https://www.amazon.in/gp/product/B00...?ie=UTF8&psc=1 Then use the vehicle extensively and allow the additive to clean out your valve body. After 6 months go in for another oil change. Depending on how your box behaves you may or may not add the additive again. I am planning to use either of these additives for my Santro AT box. They can be used in the GV also:- https://www.amazon.in/dp/B0002KKTTU/...v_ov_lig_dp_it https://www.amazon.in/Lubegard-60902...4612013&sr=8-9 Please note that you are adding between 400 to 800 cc of oil when you use these additives. So correspondingly reduce the oil you fill up at the time of oil change. | |
![]() | #1405 | |||
| ![]() Quote:
There is no pressure plates etc in the GV AT transmission, its slush box with impellers etc which makes it costly to repair. Last but not the least, any reason why you have asked this question in the first place? Last edited by Jaggu : 8th April 2019 at 14:53. | |||
![]() | #1406 |
Team-BHP Support ![]() ![]() | ![]() Those looking for NGK iridium spark plugs for their 2.0 GV can buy it from Amazon India. It seems that NGK has directly listed itself as a seller on Amazon so the question of fake NGK spark plugs should not be there. The prices also seem very reasonable and much less than what is quoted in open market for NGK iridium plugs. The link for GV spark plug is here on amazon |
![]() | #1407 | |
| ![]() Quote:
The OE plugs cost upwards of Rs. 1K. So the Amazon pricing is very good. Please post your feedback on the performance with the "6" heat level plugs. | |
![]() | #1408 |
Newbie Join Date: May 2019 Location: Mumbai
Thanked: 12 Times
| ![]() Planning to get the fluids & plugs changed on the Vitara. the list goes as below, can anyone suggest if there is anything I have missed. ![]() Last edited by aah78 : 13th June 2019 at 17:55. Reason: Post fixed - grammar. |
![]() | #1409 |
BHPian Join Date: Dec 2007 Location: Gurgaon
Thanked: 32 Times
| ![]() Hi, Last week my A/C stopped cooling. Went to ASS in Gurgaon. They have quoted astronomical price. Their diagnosis is change compressor along with a few other parts. Could you please recommend a good A/C mechanic preferably in Gurgaon ? Can you also advise what could have gone wrong with A/C What are symptoms of Dead compressor as claimed by ASS Thanks GRV |
![]() | #1410 |
Distinguished - BHPian ![]() ![]() Join Date: Feb 2006 Location: NSEW
Thanked: 15,974 Times
| ![]() ^^ The following link has been posted by a senior distinguished member of the forum. You could take the car there for a check up https://www.team-bhp.com/forum/delhi...w-delhi-4.html (Car Air-conditioning - Cooldays Car AC (Lajpat Nagar-I, New Delhi)) |
