Old 17th July 2019, 10:34   #1426
Thanked: 1,318 Times
Default re: The First Grand Vitara on Team-BHP [14 years & 150000kms]
The hum in the AT box must be because of wear in the flanks of the gears.
It could also be due to bearing wear, but that has a different whining noise.
Just try a change of the AT oil. If the noise reduces the hum may be because the oil has deteriorated. In my experience AT oil needs to be changed,in Indian conditions, after 5-6 years.
sridhar-v is offline
Old 17th July 2019, 12:18   #1427
sudev's Avatar
Thanked: 3,121 Times
Originally Posted by vigsom View Post
^^ The dead GV is an MT.
More interested in transfer case gear box which is common for both MT/AT cars.
Did that and still the hum persists. Also tried XADO treatment.
It's like the differential hum that was so much common in Ambassador cars. And the hum has some sort of frequency related to speed. The hum is pronounced around 40kmph, 60, 80 and 100kmph. In between it's slightly goes down.
Other than that no problem but
sudev is offline
Old 22nd July 2019, 18:58   #1428
Thanked: 12 Times
Any GV groups in Bangalore , i have recently shifted here , need help with some trusted mechanics around here
Freedom4037 is offline
Old 22nd July 2019, 19:34   #1429
Jaggu's Avatar
Thanked: 13,916 Times
You can check with authorised centres like Surakshaa (Electronic City) & Mandovi (JP Nagar). These two places I know, and has worked on my car.
Jaggu is offline   (1) Thanks
Old 25th July 2019, 22:24   #1430
wanderernomad's Avatar
Thanked: 1,246 Times
The hum could be because of a worn cross and pinion? I also have that hum and it is diagnosed as the worn out C&P in the front diff. The ordered parts have come to Motorcraft but I am not finding the time to go there as yet and get it replaced.
wanderernomad is offline
Old 25th July 2019, 22:35   #1431
sudev's Avatar
Will await your experience inputs.
Maybe we can meet and compare hum's
sudev is offline
Old 25th July 2019, 22:56   #1432
How about a visit to the city beautiful then? Its much better, the weather that is, here than the NCR
Old 26th July 2019, 18:43   #1433
sudev's Avatar
Was there on 7th for Trail Blazing,.. Let's see when the next visit pans out
sudev is offline
Old 1st August 2019, 11:35   #1434
vigsom's Avatar
Thanked: 16,063 Times
Dedicated to all those of us who placed our bets on the Grand Vitara
Yesterday, in the torrential downpour in Vadodara (approx 17in. Rainfall in 5 hrs), the Grand Vitara and I came out virtually unscathed, standing in traffic in upto waist deep and at times, wading through even deeper water.
There was approx 8 inches water inside the car and the seat belt warning sign started coming on even with the driver side belt in place.
The experience that I've gone through today should never ever happen to any of you, but I've seen the Grand Vitara go through water with water flowing over the bonnet at times.
Engine was always on, in idle, and I was either standing in water OR just inching forward, having to turn around at a couple of places too.
It was like doing a river crossing OR better still, standing in the middle of a river.
Somewhere I'd assumed that I'll have to desert the Grand Vitara, but nothing happened.
There were portions where the road would dip and that was where the tension would mount too, but this fellow just went on and on.
A 35 minute ride back home was finally over in 4hrs 45 minutes and I can only say, Take a Bow Grand Vitara.
Some pics I took
At 5pm in the Office Parking
The First Grand Vitara on Team-BHP [150K Makeover complete]-p_20190731_171922.jpg
At 6:37pm on the road where I was stuck
The First Grand Vitara on Team-BHP [150K Makeover complete]-p_20190731_183608.jpg
At 7:07pm - note the water level with reference to the Scorpio and the Safari
The First Grand Vitara on Team-BHP [150K Makeover complete]-p_20190731_190704.jpg
Watch this space for more.
vigsom is offline   (16) Thanks
Old 1st August 2019, 15:35   #1435
vigsom's Avatar
Okay, here comes part2 - Inspection and Treatment
I checked the engine bay last night and again this morning - no abnormality observed
1. Engine Oil - check
2. AT oil - check
3. AC Compressor - check
4. ABS - check
5. Air filter - check
6. Brakes - check
The boot carpet was intact, but the passenger area carpet was all soaked with standing water underneath, especially in the front. I had to remove all the insulation material, which was holding most of the water. There are only 2 drain plugs driven in the floor and both of those are in the rear passenger footwells.
Since I am a doctorate in car cleaning, having done an Etios in 2016 and other cars prior, this wasn't difficult to strategize, but was quite taxing to execute.
I've left all the stuff to dry and will do another round of cleaning.
The air inlet path
The First Grand Vitara on Team-BHP [150K Makeover complete]-p_20190801_105447.jpg
The engine bay
The First Grand Vitara on Team-BHP [150K Makeover complete]-p_20190801_105814.jpg
The First Grand Vitara on Team-BHP [150K Makeover complete]-p_20190801_105822.jpg
The front right and left footwells
The First Grand Vitara on Team-BHP [150K Makeover complete]-p_20190801_123242.jpg
The First Grand Vitara on Team-BHP [150K Makeover complete]-p_20190801_125602.jpg
The soaked foam/insulation
The First Grand Vitara on Team-BHP [150K Makeover complete]-p_20190801_143614.jpg
In yesterday's ordeal, water was in the cabin till the mark shown
The First Grand Vitara on Team-BHP [150K Makeover complete]-p_20190801_104914_1.jpg
vigsom is offline   (8) Thanks
Old 3rd August 2019, 12:35   #1436
sudev's Avatar
Just check the diff oils too...sometimes in deep water breather pipes intake water. Though honestly I am not aware of the location or if indeed GV diff's have breathers. This is common problem in many vehicles.
sudev is offline   (1) Thanks
Old 3rd August 2019, 20:50   #1437
vigsom's Avatar
Thank You Sudev.
The differential oil inspection is on the cards. Service centers and FNGs are flooded with cars now.
vigsom is offline   (1) Thanks
Old 4th August 2019, 20:23   #1438
vigsom's Avatar
Three days on and the floor pan has been cleaned from this
Right front
Left Front
to this
Right Front
The First Grand Vitara on Team-BHP [150K Makeover complete]-p_20190804_132834.jpg
Left Front
The First Grand Vitara on Team-BHP [150K Makeover complete]-p_20190804_123040.jpg
This time, I kept the carpet in place, removed all the insulation and dried out every corner of the carpet using newspaper.
The easier way out is to remove the seats and the carpet but with no support and all garages packed, I decided to finish this off all by myself.
Some parts of the carpet just need a sunny day to go bone dry; after that all the foam and insulation will get back in.
Old 12th August 2019, 17:22   #1439
Guys the magnetic clutch of the AC compressor is gone. Boodmo shows a part number 95210-64JB0 for the same and the cost is around 9300 INR. The magnetic clutch for GV is also available on Ali express for about 2500-3500 INR. However, the OEM part numbers mentioned on Aliexpress are different, though it mentions, that the said clutch is for the GV 2.0 AT, 2007 model. What is your opinion? Stick to Boodmo or go for Aliexpress? How can I ensure that the part ordered from AE is the right one?
Old 17th August 2019, 08:47   #1440
khan_sultan's Avatar
Thanked: 5,383 Times
What's the "extension case" as mentioned in the manual?
The First Grand Vitara on Team-BHP [150K Makeover complete]-gvoilquantity.jpg
It even says that it will take .47L of oil.
I can understand the following:
- engine oil
- gear box oil (transmission oil)
- Diff-oil (rear & front)
- t-case oil (transfer oil, for 4x4)
What's this extension case oil? Anyone changed this?
khan_sultan is offline
