re: 5 years with the Ford Fiesta 1.6 sxi ABS & still going Fida I got a bit scared a couple of days back, when I started the car after a gap of 4 days. It was a cold morning start. The only thing that alarmed me was that the Engine system warning light (the exclamation mark within a circle on top of the ABS light) did not go off, though other warning lights like ABS, handbrake, engine malfunction, etc went off.
I waited for a few seconds, but it was glowing constantly. So I switched off the engine and re-started again, but the light did not go off. I also found that throttle inputs on the stationary car were not resulting in correspoding revvs from the engine, but somewhat muted.
As I never encountered this before, I switched off and fished out the manual. The manual says one can drive the car if it glows constantly, but speeds would be restricted. It also says not to drive if the light flickers, which was not the case with my car. It also said the light concerns engine system and drive train issues.
I started the car again, and the light disappeared along with the other lights! Phew, what a relief! I drove normally to work and the car was perfect in the entire trip of 15 kms, including some high revvs on 2nd gear. I called the SA of Mody Ford a little later, and he said it could be an issue with fuel not flowing freely becuase the car was not used for few days. He asked me to observe if the light comes on again, and take it to them only if it does.
I did not have the same issue over the past 2 days. The only noticeable difference is a bit of body vibration and the tacho going up to 1250 rpm on early morning starts, but I've had that symptom few times earlier in winters. The vibrations stop soon after the car is in motion, or after the engine warms up. |
