256 kms update Time for another update eh?
Last visit to the service center had me opening up the transfer case, and replacing some critical parts, gearbox parts, and clutch plates etc.,
I paid around 20K, but then, a stitch in time saves 9,
But now July was coming.
There are a lot of important dates in your life. For example, your marriage anniversary. Your b'day, the day you get a first job. The day you graduate.
Safari owners are fortunate. There is one extra day which they have to keep track off. Its called Extended warranty expiry day.
And that day was 25th July.
And the car was far from perfect.
First of all, the brand new clutch had developed a drinking problem. A clutch fluid drinking problem. The pedal was near the bottom, clutch super hard, and it did not feel like a clutch I had spend many thousands on. It was worse than before.
To top it all, the snake who lives in the steering box had gotten more agitated. Earlier he used to hiss only on full lock, now it would hiss all the time, and the steering had become so vague that often I would end up turning for Delhi, but ending up in Faridabad.
The 4x4 system was still making some weird noises.
Lastly, the drivers side power window had started requiring manual power to pull it up.
So, the vehicle spend another two weeks, and I had a new steering piston, new RHS hub, new master and slave cylinder for the clutch. And guess what the speedometer packed up too, so a new speedometer
A now extinct service station called Automobile Sterling had forgotten to put clutch oil at 30,000kms service, hence extended warranty for master and slave cylinder was denied.
Mail to tata had no effect, as it was my fault. After all, as a customer I have to ensure what all has to change(remember that folks).
So after a bill of 3000rs, and no extended warranty, we came home.
And it was a miracle. A miracle because we did not crash. The steering was now vaguer, every pothole caused a "Death wobble", and power window was still jamming.
So today, it was again time to head to service center. Power window was sorted with some WD-40 type of spray, and it will work for the next 3 days. As for the steering many things were tightened, which I suspected would be loose soon.
However, the actual surprise happened, when Star wheels Gurgaon said that alignment cannot be done. Camber is out, and only one shim remains, they cannot remove that.
Back to drawing board.
A tech at Autolinks recommended a third party workshop called Vivek wheel alignment center.
He checked the camber, and suggested sandpapering off a little bit of the upper wishbone.
The tata techs concurred, this is the only solution if you run out of shims. If I left my vehicle at autolinks, I would save some 200-300rs as they would get cheaper rates. However, coming to Gurgaon costs that much in fuel I guess, so I decided to bite the bullet.
So after 4 long hours, everything was fixed.
Cost
Alignment = 250(alignment)+250 camber + 250 camber - 750
Wishbone fit and removal = 500
Wishbone sandpapering thingy = 300
Wheel balancing for 2 wheels = 300
After 150rs discount, I was 1700 poorer.
But atleast now I have a car which goes to noida when steering is turned towards noida.
Lets see how long it lasts.
Lesson has been learnt. For all suspension type of jobs, go to an expert, thats what everybody recommends.
Cost of full suspension overhaul(all dampers change) = 24000 at TASS
Outside - 12000-13000.
I also got to know about an interesting fact. Autolinks guys, rather than replacing parts left right and center, use wishbone sandpapering to adjust camber when you run out of shims. Kudos to them for pointing me in the right direction.
On the negative side, they do not have an alignment machine which can work with allow wheels. I guess, once they make a separate dedicated workshop for Taxis, this workshop will get better equipment.
I also saw a HR numbered dark colored 4x4 there with 21000kms on the odo.
Lastly, you must be wondering, why 256kms update? Well thats what the ODO shows now. just had 80526 to this figure, eh? |
