Old 25th December 2009, 16:37   #376
adishenoy's Avatar
Originally Posted by kingofmyworld View Post
How can the santa who got this gauge for my ride forget it?
Santa ko short term memory loss hogaya?
Yeah mate, Look good too, I'm going to do the install this evening and ill post the installation pics along with a DIY thread if time permits. Tried mounting it on the right end of the dash but because of the inclination of the dash im unable to mount in a proper angle, I'm trying to make some changes to fix it in a correct position. Hopefully by tonight ill do the install and keep the thread updated.
Thanks for your help and thanks for santa " adishenoy" for getting the tacho for my ride
Like I told you before, if you don't get a place to mount it on the dash mount it on the roof.
Waiting for the Pics of the Installation. I'm happy i could help.
adishenoy is offline
Old 25th December 2009, 16:42   #377
kingofmyworld's Avatar
Thanked: 536 Times
gimme some time till 9pm, Ill do the install b ythen and post pics in here
kingofmyworld is offline
Old 25th December 2009, 17:23   #378
black12rr's Avatar
Thanked: 339 Times
where can I get Autometer COBALT( 5 Inch one ) in Bangalore ? ,are there any direct dealers ?
Also how is the reliability of these ?
black12rr is offline
Old 25th December 2009, 17:32   #379
Thanked: 536 Times
reliability is not a problem with automechs, You hardly come across problems in a tacho, Just maksure that you install a fuse to it.
Old 26th December 2009, 08:47   #380
Thanked: 536 Times
Did the install last night. Mounted the gauge toward the right end of the dash. Inclination was a problem so dint install it permanently. I have an idea to install it but with some custom made brackets and stuff, I'll get that thing done after sunday as my entrance exam is on sunday
till then here are the pics.
Old 26th December 2009, 10:48   #381
amit_mechengg's Avatar
Thanked: 2,251 Times
^^^ how much did the tacho cost you. its the same one as mine, with 7 colors display.
amit_mechengg is offline
Old 26th December 2009, 12:11   #382
sumeethaldankar's Avatar
Thanked: 3,308 Times
I am glad your display feature works because mine never worked since day one.I didn't actually knew that the color display button was "the" color display button till someone pointed it out on the forum.
sumeethaldankar is offline
Old 26th December 2009, 12:19   #383
adishenoy's Avatar
Got the tachometer for Rs 2500 from Milan Subway, Mumbai
Old 26th December 2009, 15:36   #384
Thanked: 536 Times
How can that happen? You should have got a replacement for that right? Which color do you have as standard?
Old 26th December 2009, 16:54   #385
wildchild4lyfe's Avatar
Thanked: 7 Times
anyone knows where i can get a shift light in mumbai?..i dont want the whole thing.
thanks!
wildchild4lyfe is offline
Old 26th December 2009, 18:43   #386
Well i found out that a little bit late that the button was for changing colours.I wanted a tacho in the 800 was so long and this was my second attempt at getting a tacho fixed.The 1st one i tried from a different shop conked out 2 mins after i drove away from the shop.It left 2 holes on the inside of my front right A pillar where the tacho was mounted.
When i got the autogauge i was so happy the tacho worked proprerly that i really didn't bother to ask why the color button wasn' doing anything upon being pressed.Anyways my default is the light red color and i am quite ok with it.Had it for more than a year,touchwood,no issues so far.
Old 26th December 2009, 19:15   #387
Thanked: 536 Times
My gauge is working all good. My previous tacho was a 4cylinder one, Came to know that its a 3cylinder one after i got it installed but just for the sake of it i dint take it off...i loved its look. Now i sold that off and got this 3cylineder one. This is just cool!.
Nest are the oil press. and the volt meters
Old 26th December 2009, 19:28   #388
Thanked: 536 Times
here is the pic of my previous tacho.
MODS : Changed the image format so that it will be visible on the post itself. Do the needful. Thanks
Old 29th December 2009, 18:34   #389
did you get the custom installation done,am dying to see what you have done ?
Old 29th December 2009, 19:32   #390
Thanked: 536 Times
Not yet dude, Situation out here is sick! there is this telangan issue going on and every alternative day is a bund. The other days are most probably sundays or some soe other holidays. I'm fedup with this stupid issue
