Originally Posted by COMMUTER I have added a Hella Single trumpet to my Ford Figo 1.5D. I have honked only once after installing them and thus haven't honked enough to comment in detail about the sound. It's loud enough to make me refrain from trying it in town. I am planning to take a long trip this weekend and will be able to use it often enough to comment upon. |
I was using Hella single trumpet, Bosch Europas and the OEM Minda HN09s. One two way rocker switch was positioned on the plastic sheeting in the area under the steering wheel. The first position of the switch was wired to make the steering horn pad sound the 312watt Hella single trumpet. The second position of the switch disconnected all three horns and left the car mute and the third position sounded the Bosh Europas along with the OEM Minda HN09s in unison.
This was working for me as long as my running was regular. My running became erratic a few months after installing the trumpets and I was doing 1600km round trips every month with the car lying idle for the rest of the time. Though the car was covered with TPH armour covers, the dust accumulation degraded the trumpets and the 26.5amp/312 watt power draw started leaving the battery drained during the month long breaks the car was left idle. The impact of the trumpet was lowered by it getting positioned behind the bumper rather than being open and pointing forward.
Further, there was a nagging inconvenience in the setup. First the the process of toggling between the horns required me to reach for the switch between my knees with one hand on the steering wheel. Second was a the inability to sound the OEMs alone when I want to be polite in town. Shortest blips of the Bosch Europas sounding together with the OEM Minda HN09 weren't sounding as polite as the HN09s, which are apparently acceptable to the public even in pretty long blasts.
There are instances where we want to sound the horn just to make others know that we are there without evincing a reaction from them.
With these in mind, I looked up switches to be mounted on the steering wheel to sound the extra horns while leaving the stock horn pads to sound the stock mindas. I was initially suggested to opt for long stalk momentary switches like the ones used in buses. Those would prove to be a safety hazard and the idea was discarded.
The next idea was to put some switch connected by spring-like wires found on telephones that will allow the steering wheel to be turned fully. This idea too got discarded because those wires will start drooping overtime and might get stuck in the slit between the steering wheel and dash leading to s dangerous situation.
Finally I started looking for wireless switches. I looked through Arduino remotes, which were filmsy, and the domestic remotes used to operate domestic appliances which were bulky and to mount on steering wheel.
I chanced upon the WOLO RC100 switches even before buying the hella single trumpets but the Amazon India link was too expensive to purchase from. I came to know via repeated searches that the WOLO switches were not that expensive in the Amazon USA site. After thinking over many more options, I decided to source these switches from USA through friends.
These switches have a sleek wireless relay that gets mounted on the steering wheel and wirelessly operate a receiver which has a tiny stalk toggle switch. There are two modes, momentary (horn) and on/off(lights). I decided to buy two of them. One for the extra horns and the other for the Aux lights. The switch receiver is rated for 30amps. I chose to retain the hella relay in the trumpets for the Europa horns while adding a Hella Red Grills to sound along with the Europas(in the place of stock Mindas) powered through the hella relay that came came in the box. These two relays were connected to the WOLO RC100 receiver. The switches were mounted on the steering wheel as shown via a VELCRO strip.
We need to program switch to the receiver by powering on the receiver and pressing a small button on the wireless switch for the time it takes for the switch to blink thrice. The led ring that illuminates in blue is not very bright and when they are mounted behind the steering wheel they don't irritatingly illuminate the foot well when operated. They don't even put a faint glow inside the car at night.
The last pic shows the way I wanted to position them at first. I decided against this positioning because, firstly, they would not be discrete. In addition to that, this required extending the thumbs to operate them which reduced the grip on the steering wheel. Hence I decided to mount them on the other side of the steering wheel and use one finger to operate them without compromising on the grip.
I have used the second switch with the receiver set to on/off mode to operate the extra lights.(4nos Hella 500ff running 100w bulbs, detachable, mounted only during long drives).
