Re: Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin Quote:
Originally Posted by Funny @All, we are going a bit off-topic here. Sorry about that. |
Mate we ain't going off topic but discussing about various options available w.r.t wheels and tyres for RE Twins. Quote:
The cold weather, dusty conditions and comfort of car are the major factors for low usage of Mojo. Although I agree that I need to start riding more and have planned a short ride this weekend!
Mate it is a given while riding a motorcycle one is exposed to nature's elements. I know commuting day in day out can become a little taxing and tiring after getting used to cozy comfort of a car. But may it be car or bike they are made to run and it's good to hear that you are planning a ride shortly. Quote:
Mojo doesn't have a center stand and KTMs are way too light compared to Mojo, so the load on stationary conditions as you say will be much less compared to Mojo.
Mate I just gave one example of KTM Duke with soft compound tyres and a bike without centre stand. There are heavier bikes like Triumph Bonneville, Kawasaki Ninja 650, Honda CBR650F, etc which have soft compound tyres without centre stand as stock. Quote:
I have done it myself few times before. But this time I was on my way to office and had stopped by a friend's office, that's when he pointed out the deflated rear tyre to me. I was already late so couldn't go back home and since I didn't have the DIY kit at home, I just got all of the punctures fixed there itself.
It happens mate, in this case repairing a tubeless tyre is faster than a tube type tyre. Then again fixing punctures on a tube type tyre will add a few more minutes to the job if done by a professional tyre workshop. Cost I believe will be around same ballpark. Quote:
I know, I should've inspected the tyres periodically. But the problem is that I do visually inspect the tyres from time to time but one cannot make out minor air leaks with visual inspection alone. I will use the traditional soap water test to make sure there are no more punctures/leaks at-least once in a few weeks from now on!
| Quote:
How many times do you use RSA for a puncture? It isn't practical at all and what happens if you have punctures frequently (just saying), do you keep calling the RSA every time even when you are in a hurry to get somewhere?
Mate I was saying RSA in the context about your fear w.r.t your own words saying the roadside puncture fellow messing up and doing "improper fitting" which might affect the calipers and affect braking and ABS functioning. This is in context to while fixing punctures on tube type tyres if we are talking about RE 650 twins. Quote:
As you said, what about the situations when you are in some unknown remote location where you don't even have a puncture shop nearby. RSA might be an option in such cases, but it requires a lot of time and effort if you go by the RSA route.
One cannot have everything at the same time mate. You win some you lose some. Besides RSA will give you peace of mind w.r.t fear of improper fitting of calipers done by roadside puncture fellow. RSA works even better if your riding is done in and around city limits. Quote:
I have heard that slime is not good for long run and it affects the inner walls of the rims and also causes stability issues at high speeds. Even if we are able to swap the alloys, what about the disc brakes? The mounts may not be the same on both the bikes.
Exactly what I said about modification of tube to tubeless being a hit or miss and/or other techniques may or may not work. About swapping, the first thing that needs to be checked is whether the company will honor it's warranty in case of such modifications or not?
BTW Triumph Bonneville T100/120, Honda CB1100, Kawasaki W800, and many other retro classics also come with tube type tyres on spoked wheels. Only bikes I know having tubeless tyres on spoked rims are ADV's like BMW R1200GS, Triumph Tiger 1200xca, Suzuki Vstrom 650, etc. But those rims are special rims to accomodate spokes and are very expensive. Quote:
Originally Posted by ku69rd @ Navin, the TB 500X alloys will not match the twins as the front is 19 inches and rear is 18 inches. So the search continues for a suitable. |
Oh ok. Although the rear wheel on Tbird5350/500X is 18 inch the tyre size is different. So the search indeed continues. Quote:
Not sure what warranty are you referring to for a wheel change.
I meant the standard company warranty. I am not too sure if changing the wheel type will void company warranty, that's the reason why I said I am not sure about it.
