Team-BHP > Motorbikes
Old 11th January 2025, 19:22   #4666
Thanked: 16 Times
Re: Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin
Originally Posted by sab3r2th View Post
The entire lockset costs around Rs 2000 to replace. Not expensive.
I purchased the lockset and it cost ₹1980 in Bangalore. But what a waste of resources to address an issue with just one part.
Chasing_Dreams is online now   (1) Thanks
Old 13th January 2025, 18:23   #4667
Thanked: 632 Times
The idle does fluctuate a little bit. Yours is a bit too much. Should never dip below 1,000 rpm, cut out or skip a beat like it does in the video at the 7-8 second mark.
Originally Posted by InterMan666 View Post
I'm going to look into each aspect one by one. I have just found a video where a guy shows that the hose for air sensor under the fuel tank is sometimes unplugged and that's why the ECU compensates. Will check that out. Thank you for your comment.
If the vehicle is due for service then I would recommend getting the throttle body cleaned if its been a long time since it was last cleaned.
jomson13 is offline   (1) Thanks
Old 13th January 2025, 19:25   #4668
I got accelerator cables changed recently so seems like throttle body is all good and cleaned up.
The issue seems to happen after a bit of riding and after the bike has heated up a little.
I haven't faced this issue now for 2 days. But as it's a 3 year old bike that's barely ridden, I will just do a check on spark plugs, Battery condition, RR unit and valve adjustment.
Which brings me to the next question, it seems the RR unit is in a bad place and gets heated up. Has anyone here relocated their RR unit, as seen on a lot of videos on Youtube. If yes, can anyone help me doing the same?
TIA
InterMan666 is offline   (2) Thanks
Old 14th January 2025, 08:35   #4669
sandeepmohan's Avatar
Thanked: 5,922 Times
The issue seems to happen after a bit of riding and after the bike has heated up a little. Which brings me to the next question, it seems the RR unit is in a bad place and gets heated up.
I would not attempt this with the RR now. Do it later, once you isolate the issue of the fluctuating rpm.
As you mentioned that this happens only once the engine is hot, that points to the valve clearance. You should observe if there is difficulty starting the bike in hot conditions. Metal expands when its hot. If there is insufficient clearance (or play) of the valves, it will start stalling. However, you won't notice this under cold conditions as the valve play has increased again (As the metal has contracted).
I am not suggesting "It is" the valve clearance thats the cause of the issue. Its one of many things to check (When were the valves last adjusted). This behavior won't happen overnight. It will build up over time. I've got >33,000 km on my odometer and haven't adjusted the valves to date. Its still at factory setting. I have not faced wildly fluctuating rpm's cause I live in a part of the world where it does not get that hot. Seldom gets above 25 degrees in summer. I don't ride in the City at all either so there's no chance of the engine running hot to the point where the lack of clearance causes an issue.
sandeepmohan is offline   (4) Thanks
Old 15th January 2025, 17:25   #4670
Thanked: 3,261 Times
Originally Posted by surjaonwheelz View Post
I'm much slower and it took me 55 months to complete 24,000 kms.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-1.jpg
Clocked 25,200 kms in 59 months. I missed stopping at the milestone mark. The next 1000-1200 kms took even longer! May be, as I was having a friend's Scrambler 400X and another friend's Tiger 800 at different point of times to baby-sit. In addition, throw in the festivals and lack of long rides!
Meanwhile getting the bike pampered.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-2.jpg
Just after a wash and wax session.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-3.jpg
Here's a photologue of the weekend rides I manged on my Interceptor 650. Two of these weekend rides turned out to be solo rides which is rare for me!
Our favourite vantage point with bhpian waspune, with his new possession.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-4.jpg
A new bridge begged for a photoshoot!
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-5.jpg
These flowers were abundant post monsoons.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-6.jpg
Pawna to Lonavala, solo ride.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-7.jpg
Tung fort in the back drop.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-8.jpg
These poor purple flowers, Karavi; were mowed down by visitors.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-9.jpg
Lovely skies with cotton clouds.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-10.jpg
Another solo ride in the Eastern backyard of Pune.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-11.jpg
Lovely gradient to climb.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-12.jpg
It was September end with a bonus round of rain.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-13.jpg
And fog.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-14.jpg
The dark cloud was only on the hill I was riding on.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-15.jpg
The perk of riding solo, stop anywhere you want and that day I stopped a lot!
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-16.jpg
The last bit of a waterfall.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-17.jpg
First weekend of the new year didn't dissapoint!
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-18.jpg
With a very famous Multistrada V2 of abhi_tjet and kaali-peeli of sukiwa, along with a bunch of rider friends.
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-19.jpg
Clear skies and mountains, ideal winter ride!
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-20.jpg
Signing off as of now. All is good with the bike. I need to check the chain-set and brake-pads at the annual service which is due soon.
Happy riding,
surjaonwheelz
Last edited by Gannu_1 : 15th January 2025 at 20:40. Reason: Corrected the typo. Thanks.
surjaonwheelz is offline   (30) Thanks
Old 27th January 2025, 11:59   #4671
rajeevsulu's Avatar
Thanked: 2,750 Times
Originally Posted by TheHelix0202 View Post
If you don’t mind sharing, what did you pay for them? A quick Google search shows that it’s 15k…
I plan on buying a used Interceptor/Continental GT and getting the PoweRage short brushed aluminium finish end cans.
But if I get the headers as well, I’m worried about the free flow system not passing emissions.
Edit: Saw your post above later. But do enlighten me about the emissions. Thanks!
I did the emission check today. This is after installation of the header pipes. Absolutely no issues. I remembered your post asking about the emissions.
Attached Puc Certificate copy
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-img_20250127_110752.jpg
rajeevsulu is offline   (1) Thanks
Old 27th January 2025, 15:31   #4672
TheHelix0202's Avatar
Thanked: 3,164 Times
Infractions: 0/1 (5)
Thanks, haha! I did manage to get my hands on a used 2019 BS IV Continental GT. Installed PoweRage slip-ons. No issues with the emissions yet.
TheHelix0202 is offline   (1) Thanks
Old 28th January 2025, 01:41   #4673
Thanked: 319 Times
Originally Posted by adises View Post
Any idea how I can get the dent fixed?
Attachment 2711422
That's your sign to get a pair of new slip-ons
iamgyan is offline
Old 5th February 2025, 12:17   #4674
rajeevsulu's Avatar
Two years of Therapeutic Joy
November 11 2022 was the worst day in my life. I was wondering if I had hit rock bottom. By the end of December, I knew I needed something more than the mundane if I had to lead a normal life without getting into depression.
Enter Interceptor
January 20 th I booked the Interceptor and took delivery on 5 February 2023, 2 years to the day. The first 1000 kms were disposed off in a week and the first service was done away with. Then the fun started.
The next 1000 kms were also ridden a little sedate so as to break the engine in. Meanwhile I met bhpian Tharian in Bengaluru and bought a pair of Hitchcock barend mirrors which went on to the bike
Powerage slip-ons
At 4500 kms, I felt the sound to be a bit muted and decided on the Powerage slip-ons after watching a few videos on YouTube. I saw a Red Rooster sample at the show room and did not like the sound. This exhaust went on and I was surprised with the weight saved and the sound was bliss.
Tyres
The rear Ceats lasted just 13,000 kms and the bike is on the 3rd rear tyre now. The front lasted 19,000 kms and is on the second one. Nothing very great about these tyres. I had two punctures, both at home, both handled by RSA .
Vredestein tyres
I have purchased Vredestein tyres with the alloys and will fix them in a couple of weeks after using up some more tyre as the ones on the bike are good enough for another 3000 kms
Powerage headers
At 20,000 kms , I got the Powerage headers and got them installed. They look good and sound good. If there is any increase in performance, I am not sure but there is definitely very good sound. With the exhausts, I could get the emission test done too.
Service
Service has been routinely done at the ASC . Nothing much to crib and nothing much to praise at the same time.
I got the chain sprocket set, the front brake pads, clutch cable change done at the 30,000 kms mark. Otherwise it has been just the routine services.
Cons
The bike refused to start once . Via RSA, the battery was charged and the problem never happened again. The service centre guys blamed it on the cold weather. The bike had been ridden for 100 kms even the previous day. There was no battery warning at all.
The positives
IMHO, this bike delivers much more than what one pays for. My riding is exclusively out of town. Many trips to Coimbatore and back, Yercaud and back, a couple of trips to Bengaluru and back, and, most importantly, the "keep me sane" rides that I do 4 days a week, have been total bliss.
I don't ride slow, I don't go howling down the highway at unmentionable speeds either, but, I ride fast. I have been getting an average of 26 kmpl which I am very happy with. I fill up on XP 95 exclusively with the odd tankful of Speed or Power 95.
Conclusion
This beautiful machine,my Thar Diesel RWD and my Psychiatrist,in no particular order of importance,are totally responsible for my sanity after my personal loss.
I owe all three my mental health and happiness
Attaching some pictures of the journey along with.
Two years of Therapeutic joy
This picture was to be posted in the above post. I missed it some how.
To mods:
Please merge this post with the above post.
Thank you
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-save_20240218_135613_copy_1320x990.jpg
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-img_20250205_045150_copy_1351x1013.jpg
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-img_20241107_041006_copy_1351x883.jpg
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-img_20230619_113019_copy_1280x960_copy_422x316.jpg
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-img_20230504_132222_copy_800x600_copy_264x198.jpg
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-img_20240731_151447_copy_1351x903.jpg
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-img_20241017_164804_copy_1346x1009.jpg
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-img_20241229_175215_copy_1346x882.jpg
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-img_20230703_062127_copy_1320x990.jpg
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-img_20250102_142930_copy_1568x821.jpg
Ridden: Royal Enfield Interceptor 650 & Continental GT 650 Twin-img_20241228_155829_copy_1346x1009.jpg
Last edited by Rudra Sen : 5th February 2025 at 12:53. Reason: Back to back posts merged
rajeevsulu is offline   (21) Thanks
Old 5th February 2025, 14:51   #4675
Thanked: 230 Times
Conclusion
Thank you
Thanks for sharing this Rajeev. I wish and pray to god to bring you lot more happiness and success in 2025. Keep sharing your happiness and folks like me will be contended just reading it
Balaji31582 is offline   (1) Thanks
Old 6th February 2025, 09:57   #4676
PistonCrown's Avatar
Thanked: 105 Times
Hi Rajeev
Wanted to ask how was the PUC performed.
I had taken my Super meteor 650 for PUC testing sometime back last year.And since the testing centers have only one probe ,what they did was put the probe in one silencer .
For the other silencer they kept it plugged with cloth holding with hand,completely blocking the exhaust of other silencer.
Is this the right procedure ???
Kindly share your inputs please.Other members input will also help.
PistonCrown is offline   (2) Thanks
Old 6th February 2025, 10:39   #4677
rajeevsulu's Avatar
I have done the PUC test twice. This one and the previous one. The probe was placed in one exhaust. The other exhaust was NOT plugged as done for you. I am sure that the plugging process is not necessary.
Both my tests were done at different centres.
Hope this helps.
rajeevsulu is offline   (3) Thanks
Old 6th February 2025, 10:52   #4678
samcan123's Avatar
Thanked: 169 Times
I have done PUC testing multiple times for my interceptor in different testing centers in Bangalore in the past few years. Not once they plugged the other silencer. The probe is placed in any one of the silencers and the testing is done.
samcan123 is offline   (3) Thanks
Old 6th February 2025, 15:18   #4679
r_nairtvm's Avatar
Thanked: 2,608 Times
Reading in one silencer has been the norm in India from the time Pollution control was introduced in India. I have a 1985 Rajdoot RD350 and have been getting PUC Certificate from Circa 1990. The bike has a twin cylinder twin exhaust engine. They always have been placing the probe at random in any one of the silencers and take the reading
Strangely even abroad they follow the same process on twin cylinder, twin exhaust engines like Triumph Bonneville. However, in Bonnie there's and inter connection between the bend pipes, around the CAT converter area just before the muffler, and hence, presumed that value in both silencers/mufflers would be identical.
I am not sure how the exhaust system of Int 650 is designed.
Best Regards & Ride Safe
r_nairtvm is offline   (2) Thanks
Old 6th February 2025, 15:47   #4680
shabih's Avatar
Thanked: 408 Times
I have a strange observation to share as well. Recently I went to get my Street Twin's PUC done and after seeing my twin exhaust the staff said he wouldn't do it. When I asked him why, he checked whether it was BS4 or BS6. When I told him it was BS4 he proceeded to check so I asked him what happens to BS6 engines and he said that will require two probes. I went about my business thinking maybe this guy is just fooling people.
shabih is offline   (2) Thanks
