Originally Posted by Torino I'm not using any tubeless conversion kit on the rims. I've seen some 650 twins running on the cheaper Way2Speed tubeless conversion kit for over 2 years now and they seem to be doing fine. While the idea is to offer permanent solution the seller doesn't offer any guarantee and that's one of the reason I've stayed away from it and the other reason being the effect of wheel truing on the sealed wheels which is unknown. I think careful surface preparation and proper application determines its long lasting capability. Bhpian aravind.anand is using Way2Speed tubeless conversion kit on his Interceptor for the past 2 years and is running fine with the stock 18'' Pirelli tubeless tyres but right now he is more worried about the unavailability of stock size replacement tubeless tyres in the market than the tubeless conversion kit. |
Well, this is really an unbelievable dilemma for 650 owners and it is really surprising that neither Royal Enfield nor any of the multiple tyre manufacturers in India can offer any kind of real tubeless solution for a 205kg motorcycle.
The CEAT Zoom came in to replace the Pirellis which had supply issues and solved some of the wobbling cases, but the CEAT Zoom is a harder compound tyre compared to the Pirelli and the CEATs are not tubeless like the Pirellis. I think the rear is tubeless and not the front. Correct me if I am wrong.
With the govt. imposed taxes or ban on tyre imports, a pair of Pirelli Sportscomps is now around 30k if I am not mistaken? That's again exhorbitant.
Couple of options that I see available to fix this issue.
Convert to 17-inch mag wheels.
-Meteor rear - straight fit
-Not sure about the front mag wheel - 17-inch options that are a straight fit.
-Wide selection of high-quality tyres available in this size at reasonable prices.
-Have seen people use the Mojo front wheel setup with some machine work.
- Reduced ground clearance? Lower seat height?
Royal Ralco 18-inch mag wheel set
-Provided you have the tubeless Pirellis.
-Aftermarket - quality unascertained.
- Do not like the looks but appreciate the practicality it offers for the price - around 10-15k
Outex or Way2Speed
- Outex costs close to 14k with installation
- Way2Speed costs close to 6.5-7k with installation
- Tubeless conversion success rate subject to skills of installer. Many cases of both kits failing.
- Need Pirelli tubeless tyres to install
- If the rims bend and need to be trued then the kit needs to be reinstalled from what I understand.
While I have not faced too many punctures (touch wood), it is always a nagging thought in the back of my mind, especially on long rides.
I am surprised that despite moving to a 17-inch setup you didn't choose to go the tubeless way and chose the Desmosedici spokes setup which is not too different from the stock excel setup maybe of lower quality, and gives you a wide selection of tyres but still leaves the puncture and tube situation as is.
I'm planning to go in for the Way2Speed setup for now in the hope that I can be relieved of my puncture fears. If you can connect me to someone/ or dm the contact of someone who has installed this it would help me understand their feedback and review on the product.
Once I do the tubeless conversion I can start planning for other mods on the bike.
-Starting with moving to Motul 7100 after i clock 5k on this round of Liquid Gun
-CR Windshield (wonder if it will spoil the looks and if it's really required?)
-Relay replacement Denso Toyota (required?)
- Minus LED headlight (will it improve lighting?)
-FlashX module
-Fog lights (cheaper options than Maddog?)
-Fuel X Pro
-Powerage or AEW 201 (i like the straight pipes better - never seen them in the flesh though - any thoughts?)
-K&N / DNA air filter (rainproof?)
-Powertronics
But all these mods will be pointless if I'm stuck on the road with a flat tyre.
Am I prioritizing this tubeless bit too much?
