Team-BHP > Motorbikes
Old 4th September 2021, 16:49   #691
Thanked: 230 Times
Re: The KTM 390 Adventure Ownership Thread!
Originally Posted by neoakshay View Post
Hi Derek,
I bought my Adv 390 about a month and a half ago, and just like you I'm looking to optimize. Initially the bike felt very hard-edged, with the vibes and hard gearshifts (especially 2nd to 3rd). Now that I've crossed 2k kms on the odo, it has definitely settled down and smoothened out.
I'm planning to purchase a Powertronic piggyback soon, the chaps at RaceDynamics told me it will be ready 2nd week of September. Seems they have a new model coming out for the Adv. Instead of performance I'm only looking for the benefits of correcting the overly lean BS6 tune - smoother and more relaxed engine.
I'm not sure if RaceDynamics will let me try the box before I purchase, but I've only heard good things about the piggyback, even on international forums.
Thanks for the update. After u told me this, I spoke to the race dynamics guys. They are coming up with something called fuel x, which is going to be some kind of fuel optimiser approximately costing 7-8k.
The powertronics is available with 2 maps or you can custom ur own map as per them.
And yes, my bike has a lot of vibrations, seems to struggle a little bit to get to higher rpms too. I’m also looking at just optimising the bike and getting it to perform like it should or like it can, actually! If I wanted 90 bhp, I’d buy a tiger.
Thanks so much for your input! Keep the thread rolling!
derek is offline   (2) Thanks
Old 4th September 2021, 22:09   #692
Thanked: 12 Times
I am using the ktm 390 adv since June 2020 and clocked 10k kms
My longest trip was Bangalore to Rajasthan.
The route being:
KARNATAKA Bangalore - Chitradurga - Hospet - MAHARASHTRA Sholapur- Beed- Aurangabad - Dhule - MP Ratlam - RAJASTHAN Udaipur. Trip - Udaipur - Kumbhalgarh - Chittorgarh - Jaipur - Bhangarh - Bikaner - Pokhran - Jaisalmer- Jodhpur- Mt Abu Return journey - Mt Abu RAJASTHAN - Himmatnagar GUJARAT - Nashik - Pune - Kolhapur MAHARASHTRA - Belgaum - Hubli KARNATAKA - Bangalore ~6100 kms
Sidzmail is offline   (1) Thanks
Old 5th September 2021, 10:28   #693
Thanked: 598 Times
A bit OT : do you adv boys know good trials around blr? Preferably something that takes you up a hill
howler is offline
Old 5th September 2021, 13:47   #694
NoSugarNoSpice's Avatar
Thanked: 404 Times
Try this, its 2 hours from Bangalore. Doesn't go through active elephant areas, and the lower level of it is a popular picnic spot with some cave temples.
This is breath-taking. The trail ascends on the hill's perimeter and offers grand views. It's not too difficult when it's dry.
https://www.google.com/maps/place/Am...7!4d78.0172614 - Most people know it as Kailashagiri.
If you do decide to venture off the trails, exercise extreme caution as it's full of hand sized spiders and their webs. Oh and these spiders can also fly.
NoSugarNoSpice is offline   (7) Thanks
Old 6th September 2021, 13:42   #695
Thanked: 29 Times
Originally Posted by Red Liner View Post
I am sorry but the "mod" you have made does nothing for the bike in terms of actual performance as you have just found out.
Get rid of the extra extension on the back of the wheel and you have an actual high fender that eliminates the issue of mud sticking to the under of the fender and preventing the wheel from moving.
Install a high quality radiator guard to prevent the radiator from dying early from mud being splattered all over. Wash radiator often and immediately with an unpressured hose. Still,it will probably have a far more reduced life.
Can't agree with you more on this. Eliminating the rear flap on the front stock fender would be the best option under such circumstances.
Case in point - There was another ADV with me at the same time, majority of the stock fender has been sawed away and had no issue ploughing though. A couple of inches of the plastic remain only to hold the fork covers in place.
Arv1990 is offline   (5) Thanks
Old 6th September 2021, 13:52   #696
Thanked: 29 Times
Originally Posted by derek View Post
Thanks! I see the uni pre filter looks like a sock and comes in a pair. It's available on bigbadbikes. Where exactly does it fit? I can't seem to find any video's or clear pics of where it's supposed to go.
The link below has a good illustration on the fitment for the pre-filter
https://www.uniflow.com.au/contents/en-us/p10215.html
Arv1990 is offline   (1) Thanks
Old 7th September 2021, 10:20   #697
Thanked: 12 Times
I completely agree with your BMC filter review. Mee too feeling the punch after changing to BMC. Low end torque is good and after I changed the ECU version to V11, the results are amazing - combined effect of V11, BMC and NGK.
Originally Posted by Arv1990 View Post
2. After Market Filter - I have been on the BMC filter with a UNI pre filter for the last 8,000 odd kms, I have also switched back to the stock filter for comparison. Result - With the BMC and UNI, I find the low end to be much more accessible and a lot more smoother.
On another note, had a good trail hunting session last Sunday. With the front mud guard cut off to about mid point (just ahead of the forks) and having it replaced it with the Xpulse fender, I must say it hasn't helped much With a mixture of roots, twigs and clay, CAKED was an understatement.
Attachment 2202056
One thing I learnt during such times is to try and clear the clogged mud/clay as soon as possible no matter where its stuck - front fender, bash plate, rear suspension, calipers, swing arm, pegs. The longer you leave it, the harder it gets, especially anything stuck ahead of the engine or over the exhaust since the heat will cook all the muck and is almost as good as a block of rock. Just one allen key bolt on the right hand behind the fork removed to access the underside of the left over stock fender and almost everything was scrapped off with a random piece for twig.
Attachment 2202057
Also something I learnt post this incident, frequent hard taps on the stock fender before it can get completely caked will also help, must be realised sooner though.
Old 10th September 2021, 19:07   #698
shyamg28's Avatar
Thanked: 3,533 Times
Can anyone here vouch for (or against) the pillion comfort on the Adv390?
I may consider transitioning to it if the pillion comfort criteria is sorted. Might either way lol, and hand over keys to Himalayan to wife permanently
shyamg28 is offline
Old 10th September 2021, 19:24   #699
Red Liner's Avatar
Thanked: 18,889 Times
A girl-friend (not girlfriend) sat on the back for a ride over to my house. She was pleased.
Not sure about day long or weeklong rides. I would think a longer wheelbase bike with more seat space would be ideal. A used versys for close to the price of a new 390 adventure is always my answer to those seeking pillion+luggage capacity.
Red Liner is offline   (5) Thanks
Old 18th September 2021, 08:42   #700
Thanked: 230 Times
Has anyone received/tried/ reviewed the new fuelx from race dynamics? I’m very eager but I’ll wait for some pros to give a feedback.
derek is offline
Old 18th September 2021, 13:30   #701
swiftnfurious's Avatar
Thanked: 9,784 Times
Himalayan is not comfortable for the pillion ?
swiftnfurious is offline
Old 18th September 2021, 15:57   #702
shyamg28's Avatar
I can see how my question might've led you to ask this Suffice it to say, Himalayan is an excellent motorcycle for 2-up riding.
You can load as much luggage as you want and still maintain enough space for a pillion to comfortably do 700+ kms in a day.
I asked because I am considering upgrading (yes, that's the word I would use for my purposes) to the ADV390. And since I primarily go long distance riding with my wife, pillion comfort has to be guaranteed.
I'm not in the financial state to afford big bike service costs yet. And also lighter bikes just make sense, especially with a pillion and after luggage is loaded on. The ADV seems to make the most sense for what it offers today.
shyamg28 is offline   (2) Thanks
Old 18th September 2021, 20:42   #703
Red Liner's Avatar
If you want a pre owned but used just 3000 kms first batch 390 adventure, let me know and I will put you onto a friend who is selling.
Red Liner is offline   (2) Thanks
Old 19th September 2021, 06:19   #704
Thanked: 230 Times
I think for touring and riding with a pillion and luggage nothing beats a Himalayan on a budget. The 390 while she can tour, is not really that comfortable ergonomics and seat comfort wise. Compared to a Himalayan.
Old 20th September 2021, 09:06   #705
Thanked: 1,276 Times
How are RK Takasago chains (http://global.rk-japan.co.jp/) compared to the OE Rollons , any idea ?
The ones that we get here are made in Malaysia as far as I know.
rb2399 is online now
