Originally Posted by srini1785 Is it not?. I was under the distinct impression that viscosity is the most important, if not the only indicator of healthiness of engine oil. |
Viscosity is an important parameter, but it is not the only one. It is the one that is easiest measurable with even simple DIY tools.
Originally Posted by srini1785 All additives , are added to maintain two things
1. Thermal transfer characteristics
2. Friction characteristics
I don't know any other function of the engine oil. For a 20W50 grade engine oil, there are multiple brands available in the market all claiming to maintain excellent flow characteristics even at high temperatures ( courtesy engine oil ads) so for the wanna be Motorcycle scientist , how to find the best suitable engine oil?. |
The additives are there for the engine oil to maintain those characteristics over a long time. Additives, to some point also determine the viscosity characteristics of the oil as well. The basic purpose of the various additives is to enhance existing base oil properties with antioxidants, corrosion inhibitors, anti-foam agents and demulsifying agents. In addition antiwear agents, extreme-pressure additives, and viscosity index improvers etc. The list goes on for a modern oil.
Viscosity is not a good indicator of the state of those additives perse. Also, actual wear particles tend to have a small effect on the viscosity, whereas it has a big effect on your engine.
In my opinion there is absolutely no way to tell what the best suitable engine oil is for your car/bike. Despite the fact that every car forum in the world has many many threads dedicated to oil. The only way to actually have an informed opinion on lub oil is by extensive very precise measurements on both the oil and the engine over a prolonged, controlled period of time.
What you will see on the oil threads is endless hugely subjective opinions, quoting sounds, noises, vibrations, revving of engine, smoke etc etc. All highly subjective, very debatable.
I have said it many times: You just look up the recommended oil specification in the car / bike owners manual; Next you buy the cheapest one and stick to the recommended maintenance intervals and you (or rather your engine) will be fine!
As I mentioned before, make sure always to change the oil filter as well.
Many years ago I was involved in an extensive field trial on the effect of different brands of lub oil (same specification) on marine diesel. I wrote the details somewhere on this forum, but I can’t for the life of me remember where). For many months we ran these engines, monitor and measuring all parameters. After so many hours we took them apart, measured the bearings, the cylinders, piston (rings etc). Normalised the measurement between the engines using different brands of lub. And found no measurable difference in wear between the very expensive A brands and the very cheap B brands.
So without taking engines apart and actually measuring the effects of wear, or lack there of, any debate on what constitutes a suitable oil is completely useless as far as I am concerned. There is simply no way of telling.
As long as you use oil with a specification compliant to the manufacturer recommendation your engine will be fine. Engine wear due to people letting their cold engine idle for minutes before driving away is much, much worse. Lots of short city drives are harder on an engine, than lots of motorway driving. But even so, rarely to the point that they start showing up in undue wear till at least 150-200K.
Even a little wear of the engine, resulting is some oil consumption is no problem at all. Just add a bit of oil now and then. Rule of thumb: on most car engines; adding up to 0,5l per 1000 km is no problem. This has been debated somewhere else on the forum as well. And several members confirmed the above as the formal recommendation found in their car owner manuals.
Many people sell their car at 100-120K. With normal routine maintenance engine wear by and large would be very minimal and most engines these days will easily do double that mileage without any major overhaul. Just running on whatever the manufacturer recommended. Why put more expensive, or supposedly better oil in it? (Well, I actually love guys that do it, because I typically buy cars with high mileage, so I am the one that gets the benefits, not the guy who drove the first 100K
Testing be it for viscosity or otherwise on car / bike engines has little value in my opinion. As I explained, viscosity alone is not an indicator of the health of your oil. If you keep to the recommended oil change frequencies the likelihood of any abnormal engine wear is virtually nil. (Under normal running circumstances of course).
A lub oil is hugely important for an engine. But use the recommended one, change it at the recommended interval, together with the oil filter, and it becomes just about the most mundane aspect of your car / bike not worth bothering about!
Jeroen
